Need help choosing a screen for an HD1000U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2006, 02:35 PM - Thread Starter
omegatek's Avatar
I'm completely lost in choosing a screen to go with my Mitsubishi HD1000U
My room size is 14' L x 12' W x 8'H
I will be ceiling mounting it about 13' from the screen
I think the offset is 33%
Any suggestions? My budget is $200 or less.
omegatek is offline
post #2 of 7 Old 12-26-2006, 05:07 PM
GG_Guy's Avatar
*bump*
omegatek,
What did you end up getting? I am looking for something similar.
GG_Guy is offline
post #3 of 7 Old 12-26-2006, 08:26 PM
Terrantula's Avatar
Im about to pick up this projector as well and was wondering the same. I want a 100" fixed screen and was considering a Do-Able solution. Would this be a good choice for this projector?
Terrantula
Terrantula is offline
post #4 of 7 Old 12-27-2006, 01:02 PM
ellisz's Avatar
I am in a similar boat but I need a pull down or electric. My room is 14x19x8. I was considering a 100-106" screen. There is another thread about the Monoprice screens which are a bit over $200 shipped but they are electric. My only concern is the size is 108". Not sure if you can use a larger screen than the projected picture size. I am sure you can but not sure what it looks like...
Less than $200 does not give you a ton of options unless you go to a fixed DIY screen.
ellisz is offline
post #5 of 7 Old 12-27-2006, 01:16 PM
PatrickB101's Avatar
sounds like you need a greywolf screen
PatrickB101 is offline
post #6 of 7 Old 01-09-2007, 04:35 PM
taywu's Avatar
I'm also trying to decide on a screen for the HD1000U. I'm looking at the Da-lite HC or HP Model B. Any thoughts on either one? or a better suggestion?
My setup
Room: 19 L x 9 W x 9 H
Mount: Ceiling
Lighting: Completely dark or some ambient for sports.
taywu is offline
post #7 of 7 Old 01-26-2007, 01:28 AM
nightfly13's Avatar
FYI Monoprice also has a 135" screen but both are out of stock, back ordered expected in a few weeks.
nightfly13 is offline
Reply Screens
