Screen for Sanyo Z4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-08-2007, 12:50 AM - Thread Starter
paradigm's Avatar
I currently have a Sanyo Z4 with a HCCV (Da-lite permwall -gray screen). When I first got a projector (Z1) I thought the gray screens were going to be the best. But my projector is in a dedicated light controlled theater so I do most of my viewing when the lights are OFF. I have a perm-wall screen and just need the actual material. What does everyone recommend? I want to just snap the material right on to my permwall screen.
Thanks for any input.
paradigm is offline
post #2 of 5 Old 01-09-2007, 01:04 PM
KeithfromCanada's Avatar
Contact any screen distributor and tell them that is what you have in mind. They should be willing to sell you just the screen material to fit your frame. What do you plan to replace the screen with?
KeithfromCanada is offline
post #3 of 5 Old 01-09-2007, 10:48 PM
seatlsteve's Avatar
Let me know what you find out as I have the exact same situation as you do. Old Z1 and now Z4 and I am contemplating a change of screen material. I too have the same screen as you....Thanks, Steve
seatlsteve is offline
post #4 of 5 Old 01-10-2007, 11:07 PM - Thread Starter
paradigm's Avatar
I've been in contact with Jason Turk. I know he's prolly extremely busy. He's just asked for pieces of info and am awaiting his response. Will let you know.
paradigm is offline
post #5 of 5 Old 01-12-2007, 05:44 AM - Thread Starter
paradigm's Avatar
He told me Cinema Vision as its a lot like HCCV only a white material and it wont hurt the blacks too much. I'm in a light controlled room.
paradigm is offline
Reply Screens
