Entry level AT screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-14-2007, 07:42 PM - Thread Starter
Naveed148's Avatar
I'm looking to upgrade my screen to something acoustically transparent. So far everything I've looked into seems to be way out of my price range. I wouldn't mind a DIY fixed screen, but due to my room lay out and my wife's preference its pulldown or bust.
Is there anything available in an AT pulldown in the $500 range, or is this too much too hope for? I know you get what you pay for, but as it is I am throwing my Panny onto a cheap eBay screen, so anything is really an improvement.......Thanks in advance for any tips or advice
Naveed148 is offline
post #2 of 9 Old 02-15-2007, 09:59 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Naveed148,
Want Acoustically Transparent? Want affordable? Go see my Stewart Studiotek 130 Microperf for sale in the Display Devices For Sale section... Great screen at a Great price!!!
...Glenn
Glenn Baumann is offline
post #3 of 9 Old 02-15-2007, 01:43 PM
McCall's Avatar
I assume you have checked out Smx?
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
post #4 of 9 Old 02-15-2007, 03:44 PM - Thread Starter
Naveed148's Avatar
Yes, SMX does appear to be great quality at a great price. But i would like to avoid fixed frame if possible, and I can't find a tutorial for applying the material to a DIY pulldown application.
Has SMX released an electrical model? Or will they in the near future?
post #5 of 9 Old 03-17-2007, 09:35 PM
f430's Avatar
I too am searching for a cheap acoustically transparent solution. After viewing some projectors this week I found where the sound comes from (top/bottom) to be distracting. Being my first FP setup I also don't want to jump in with too much $$ so is it possible to do AT on the cheap?
BenQ W1070 - DENON AVR-E400 7.1 - SLS Q-Line Gold - Hsu VTF-2 MK4
Watch the progress http://www.avsforum.com/t/1517374/budget-build
f430 is offline
post #6 of 9 Old 03-18-2007, 06:32 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Go to http://www.northsolarscreen.com/index.html and inquire about having them make you a pull down window shade out of Shearweave 4500. Cost about 500.00. Now a window shade is going to have a smaller roller and that likely means some waves in the screen. For no compromises, it is going to cost more and you should check out SMX.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #7 of 9 Old 03-18-2007, 08:45 AM
f430's Avatar
Thanks. I checkd out SMX and the prices are great! I just need to make a frame then.
I'm still deciding wether to build in the speakers or just make a stand for the screen and use speaker stands too (saving $$)
f430 is offline
post #8 of 9 Old 03-19-2007, 11:14 AM
McCall's Avatar
Be very careful with the idea of "build in" the speakers. there are a lot of acoustic considerations and you don't Build in speakers that are not built in speakers.
Many of us with dedicated theaters build a false screen wall that has platforms for the speakers allowing them the room they need, My entire screen wall is covered in Black stretch velvet with the speakers on platforms behind the Smx screen, I have no velvet behind the screen.
Enclosing speakers not designed to be enclosed will ruin your sound.
McCall
McCall is offline
post #9 of 9 Old 03-20-2007, 06:03 PM
f430's Avatar
Thank you for that! Your method would also make it easier to service and slightly move and tweak things. I think a false wall is the way to go.
f430 is offline
Reply Screens
