***Official SmX Theater Solutions Screen Thread - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #751 of 1314 Old 02-25-2009, 09:32 AM
xyzTO's Avatar
Hey Ruben,
I have a screen on order. It seems you are using the new black hole material for the frame also. Is that correct?
The screen I ordered is 16 x 9. Is it possible to get horizonal masking panels?
xyzTO is offline
post #752 of 1314 Old 03-01-2009, 01:06 PM
shawnwalters's Avatar
The week has come where I'll be assembling and installing my SMX.
I just read through the instruction manual and it seems extremely detailed which is great.
My question pertains to the Moire test. I have the Digital Video Essentials calibration disc on blu ray. Should I be using one of the test patterns on that to determine if there is Moire? I noticed the manual said:
"Most people rotate the screen material as much as the frame allows and this method usually works for every- one."
I take it this means if I can't determine whether there is Moire present, that rotating the screen as much as the frame will allow is a safe bet?
Shawn
shawnwalters is offline
post #753 of 1314 Old 03-01-2009, 10:27 PM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 431
Shawn
When I was building my screen I read that 15 degrees should do it. That's what I did and it's just fine.
erkq is online now
post #754 of 1314 Old 03-02-2009, 06:01 PM
SmX
SmX's Avatar
Originally Posted by xyzTO View Post
Hey Ruben,
Hi,
Our frame uses another type of black hole velvet that is different from our AT masks but both are really close in blackness. We don't offer the fixed masks for native 16:9 screens as of yet. Only 2.40, 2.37, 2.35 and 1.85 native screens accept the manual mask panels to mask all the constant image height aspect ratio's.
The masks shown a few posts above are for our ProMask automated masking systems which now all come standard with our new acoustically transparent black hole mask panels.
The fixed mask panels we offer for the ProLine and ProCurv are something different.
Ruben
Follow SmX on Facebook
SmX Video Projection Screens and Masking Systems
WWW.SMXSCREEN.COM
SmX is offline
post #755 of 1314 Old 03-02-2009, 06:09 PM
SmX
SmX's Avatar
Shawn
Hi Shawn,
You can disregard that moiré test, that is no longer needed with the CineWeave HD. We need to update the manuals accordingly. For future proof projector upgrades (up to 4-8k resolution), just rotate the screen surface at the maximum degree and that will do the trick.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #756 of 1314 Old 03-02-2009, 08:00 PM
Originally Posted by SandmanX View Post
Hi Shawn,
Ruben
Awesome thanks for the info
post #757 of 1314 Old 03-03-2009, 07:13 PM
I didn't do the screen part yet, but I assembled and hung the frame. Had to carry it around the house, wouldn't fit down the stairs. It's huge
post #758 of 1314 Old 03-05-2009, 11:12 PM
Today I set up my SMX. It was much easier to assemble and attach the screen surface than I thought it would be. The build quality of the frame is top notch and the screen itself it amazing. I'm extremely happy with it Definitely worth the money.
Quick handheld snapshots I took right after hanging it.
post #759 of 1314 Old 03-07-2009, 08:22 AM
SmX
SmX's Avatar
Looking good Shawn! What projector are you using on that 150" wide screen? Looks like it is lighting it up good. Also what color is the wall behind your screen? The wall should be black.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #760 of 1314 Old 03-07-2009, 09:09 AM
Ruben
Thanks Ruben. The projector is a JVC RS10. I absolutely love the screen
The wall is black - that's all linacoustic behind there, it's just the color temperature of the shot was bad because I don't know how to use my camera in low light areas.
post #761 of 1314 Old 03-07-2009, 06:40 PM
Ruben
Here are some better screenshots
post #762 of 1314 Old 03-10-2009, 08:48 AM
chirpie's Avatar
Quoted: 177 Post(s)
Liked: 249
I like scrolling through and watching the surrounding room change colors with the screen, neat effect. ^_^
chirpie is offline
post #763 of 1314 Old 03-19-2009, 12:32 PM
Razor1911's Avatar
I contacted SMX and they say that they are not selling just the AT material. You have to buy the complete screen with the frame. Is there anyone else that is selling the cineweave material or something close to it? I see all kinds of posts earlier in the thread with people who have just the material.
Razor1911 is offline
post #764 of 1314 Old 03-19-2009, 12:53 PM
Haroon Malik's Avatar
Slightly off-topic.
There's a very nice article on electronic house about Ruben Ortiz and how he converted his two car garage into a fabulous DIY home cinema. It's worth a read. Well done Ruben.
Here's the link:
http://www.electronichouse.com/artic...creen_company/
Reading this brought back good memories of following Ruben's massive DIY Home Theatre Construction thread on a daily basis taking the journey along with Ruben through AVS.
Haroon Malik is offline
post #765 of 1314 Old 03-19-2009, 01:35 PM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 431
They sold the material a few years ago. That's when a bunch of us got "lucky". I have a 120" wide 16:9 that hangs in the air with no frame or border of any kind. It's very cool and unfortunately not an available option from SMX. I really like "just the image" suspended in mid-air.
erkq is online now
post #766 of 1314 Old 03-22-2009, 09:45 AM
Briands's Avatar
I had thought about this option in the past... Do you have any pictures ... I'd like to see how this looks... maybe the way to go for my next theater...
Brian
Briands is offline
post #767 of 1314 Old 03-22-2009, 05:11 PM
SmX
SmX's Avatar
As previously requested above, here are some pictures of our audio transparent ProPanels for our ProLine and ProCurv fixed screens.
Our ProPanels are available in sets of any requested aspect ratios and seamlessly mask our ProLine and ProCurv fixed screens exclusively. Our ProPanels are available as solid or audio transparent with our new black hole mask material.
Shown in the pictures below is a native 2.37:1 ProCurv being masked to 1.33:1 (4:3).
Standard available ProPanel sets include masking of 1.78:1, 1.85:1 and 1.33:1
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #768 of 1314 Old 03-22-2009, 06:22 PM
Those looks pretty nice. Are they expensive?
post #769 of 1314 Old 03-23-2009, 12:40 PM
SmX
SmX's Avatar
Not at all, you can get more details on the ProPanels HERE
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #770 of 1314 Old 03-24-2009, 05:56 AM
aquafire's Avatar
Please pm me distributors in Ontario Canada.
thanks!
aquafire is offline
post #771 of 1314 Old 03-24-2009, 07:03 AM
JoshMKiV's Avatar
Can't wait to get my manual masking panels!
JoshMKiV is offline
post #772 of 1314 Old 03-25-2009, 03:32 PM
skydiverfloyd's Avatar
Is there a screen available in electric or pull down? I looked at the website but looked like everything was fixed.
Jack
skydiverfloyd is offline
post #773 of 1314 Old 03-26-2009, 10:08 AM
amillians's Avatar
Ruben,
To clarify on the new ProPanels, you purchase a pair for each desired AR, correct? So if I wanted to mask a 2.37 down to 1.85 *and* 1.78, I'd buy a 2.37->1.85 ProPanel pair *and* a 2.37->1.78 ProPanel pair?
Alex doesn't live here anymore
amillians is offline
post #774 of 1314 Old 03-26-2009, 10:53 AM
jamis's Avatar
On my SMX screen, the cineweave is splined into the channel that puts the material flush with the frame (there is no gap between the material and the back of the frame).
Does the material have to be moved back to the channel that is usually used for optional blackout material to make use of the masking panels?
jamis is offline
post #775 of 1314 Old 03-26-2009, 12:53 PM
SmX
SmX's Avatar
Originally Posted by amillians View Post
Ruben,
Correct. So if you have a 2.35, 2.37 or 2.40 native aspect ratio ProLine or ProCurv fixed screen, you can specify a ProPanel set for masking 1.78 (16:9) a ProPanel set for 1.33 (4:3) and another set for 1.85.
We will also have ProPanels available for native 1.78 (16:9) ProLine fixed screens next week. They will mask for 1.33 (4:3) = (side masks) and 1.85:1, 2.35 =(top and bottom masks).
We can also manufacture ProPanels for any other specific aspect ratio requested.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #776 of 1314 Old 03-26-2009, 01:01 PM
SmX
SmX's Avatar
Hi Jamis,
Correct. Plus we supply a track kit to slide and lock the ProPanels in place so there is no risk of popping the screen surface out of the T-Spline channel or damaging the screen surface.
Existing ProLine and ProCurv owners will have to get a replacement screen surface from us to utilize these new ProPanels. New screen orders will have to specify if they intend on doing the ProPanels in the future so we can prepare the frame for it.
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #777 of 1314 Old 03-26-2009, 01:28 PM
jamis's Avatar
Hi Jamis,
Ruben
Thanks for the reply, Ruben.
I assume there is an added cost for the replacement screen material for existing customers?
I am very excited about these panels. I am seriously considering them for masking my 2.37:1 screen down to 16:9 (no need for 4:3) later this year.
jamis is offline
post #778 of 1314 Old 03-26-2009, 04:10 PM
SmX
SmX's Avatar
Jack
Hi Jack,
Please check your PMs
Ruben
WWW.SMXSCREEN.COM
SmX is offline
post #779 of 1314 Old 03-30-2009, 10:30 AM
Taz1's Avatar
Hello Ruben,
I have sent you an email this morning regarding 120" 2:35 AT curved screen.
I am planning on getting Panasonic 3000U. Do you think I should go with 2:35, 2:37 or 2:40? my room size is 19'W X 22'L 8'H.
Tas
Taz1 is offline
post #780 of 1314 Old 03-30-2009, 11:48 AM
SmX
SmX's Avatar
Originally Posted by Taz1 View Post
Hello Ruben,
Tas
Hi Tas,
Are you using an anamorphic lens and scaler with your 3000U?
Ruben
WWW.SMXSCREEN.COM
SmX is offline
Reply Screens
Projection Screens
