The official SeymourAV center stage screen thread! - Page 102 - AVS Forum | Home Theater Discussions And Reviews
 73Likes
post #3031 of 3052 Old 07-02-2015, 05:30 AM
coolgeek's Avatar
Quoted: 485 Post(s)
Liked: 241
Originally Posted by pgwalsh View Post
This is something I would really like to see. I can't stand 3D glasses or any glasses for that matter.
You would still need 3D glasses. With 2 projectors the image will just be crisper, brighter, and better colors.
coolgeek is offline
post #3032 of 3052 Old 07-02-2015, 05:39 AM
pgwalsh's Avatar
Quoted: 183 Post(s)
Liked: 103
Bummer. Probably still be n eat to see.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
post #3033 of 3052 Old 07-02-2015, 05:55 AM
BrolicBeast's Avatar
Quoted: 650 Post(s)
Liked: 607
Originally Posted by jago1911 View Post
I've watched your "Lumagen Radiance 16:9-to-2:35 using NLS (Non-Liner Stretch)" video several times and was going to get the same for my 2.35 screen build out in a few months. Your video is what convinced me to stay away from getting a 16:9 screen. Do you think masking a giant 16:9 is superior to doing NLS on a 2.35 screen now?
Greetings! Well, my situation has changed somewhat. In many theaters, there are height and width limitations that affect screen size. In my last theater, I could only get a 92" 16:9 screen in my room (which I used happily for three years). After it started to look "small" to me, I kept the height constraint (center speaker on top of credenza) and increased the width to a 2:35 image, and the screen was huge!! The NLS was an amazing way to get 16:9 content onto a 2:35 screen.
In the new theater I am putting together, there aren't any applicable height constrains, which means I can go as high and as wide as I want. So, I figured--why not use the whole height of the room since it's available? on a 2:35 screen, the NLS is superior to raw 16:9 with masking, in my opinion. And, once Lumagen releases a 4k processor, I'll probably NLS most programs anyway, just because the 2:35 aspect ratio looks awesome. Now, what I look forward to testing is how the Lumagen treats 2:35 content reformatted to 16:9 displays. I wonder if it'll be as impressive? I'll know soon! I know ith as the capability because I tested it out a few times before switching to 2:35...but the screen was small and not a good representation of large-scale performance.
I hope this dissertation answered your questions. I tend to be long-winded when I'm excited about something
BrolicBeast is offline
post #3034 of 3052 Old 07-02-2015, 06:56 AM
mv038856's Avatar
Quoted: 18 Post(s)
Liked: 24
The Dolby 3D that Dolby lincensed from Infitec and that is/was used in a number of cinemas as an alternative to Real3D also uses glasses. In contrast to Real3D, Dolby 3D works with color band filters, i.e. RGB are split for the right and the left eye. The channel separation is outstanding, so there is no ghosting. The glasses are much lighter than the active shutter glasses. They are comparable in weight to the Real3D glasses one wears in the cinemas.
mv038856 is offline
post #3035 of 3052 Old 07-02-2015, 09:47 AM
simon_templar_32's Avatar
Quoted: 25 Post(s)
Originally Posted by Dirk44 View Post
Hello Simon T.
i plan to build a deep curved screen by seymour XD material like nils here (aka follgott)
My Room "Restructions" give me viewing distance of max. 10-11 feet by screen wide 157".
How wide is your sceen ? Your post make thing to switch from XD to UF again.
Best dirk
My screen is a 95 inch wide 16:9 screen. I happen to be very sensitive to screen artifacts. I would get some samples (the larger size if you can afford it) and do some careful test viewing with bright, panning scenes. The Seymour screens are a good value; just make sure you get the right material.
simon_templar_32 is offline
post #3036 of 3052 Old 07-02-2015, 09:48 AM
AVS Club Gold
chriscmore's Avatar
Quoted: 48 Post(s)
Liked: 49
Is that like the system Sim2 uses, with precision magenta and green lenses? While it's easy to cringe at the thought of the anaglyph / color method of 3D, the Sim2 system had lab-grade glass filters and everything blended perfectly with no color artifacts.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #3037 of 3052 Old 07-02-2015, 09:53 AM
AVS Club Gold
chriscmore's Avatar
Quoted: 48 Post(s)
Liked: 49
Originally Posted by simon_templar_32 View Post
The UF banding is a more subtle artifact, and I can live with it. I can see both the XD weave and the UF banding from 12 feet, and even further, but I know what to look for and when to look for it. Having said all that, it is all dependent on my eyesight, my processing chain, and my viewing environment--YMMV.
As much as I love all the Panasonics I've owned, their convergence isn't perfect and I've found that they can therefore sometimes not play nice with the UF. Test if tilting either the screen or projector helps and we can one-off a replacement UF with tilt (if we didn't do that already on your screen). We don't do that as standard because 99% of projectors are converged ok. But as a longtime Panny fan, I admit that its convergence sometimes causes problems. I think this is overall a temporary issue in projection.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #3038 of 3052 Old 07-02-2015, 04:34 PM
lovingdvd's Avatar
Quoted: 911 Post(s)
Liked: 152
Yes that is essentially the same mindset I had in planning my room. I went with the tallest screen I could fit and then will go with the width that makes that a 2.40 AR (in my case about 140"w). I've had a Lumagen for years but never a 2.35 screen. Does the NLS work THAT well whereby you can stretch most 16:9 materials and even sports to 2.35? If its that good I wonder if I'll even need to do a masking screen then (since I'd likely always have everthing at 2.35 or 2.40)...
lovingdvd is online now
post #3039 of 3052 Old 07-02-2015, 04:36 PM
lovingdvd's Avatar
Quoted: 911 Post(s)
Liked: 152
Has anyone with the XD screen and a black pit room measured their ANSI CR at the screen, and if so, what did you get? All weave screens Seymour or not are pretty poor at ambient light rejection, so I have some concerns that even with black velvet on the side walls and ceiling that it may be hard to get really good ANSI CR with this (or any) weave screen. Thoughts?
post #3040 of 3052 Old 07-02-2015, 05:54 PM
Gary Lightfoot's Avatar
Quoted: 175 Post(s)
Liked: 112
I think with some weave screens, there are some potential issues with a drop in intra-pixel ANSI CR because the light bounces off the weave and may affect dimmer adjacent pixels, and we don't get that with perf pvc because the pvc is still flat. I think if you did a normal ANSI test using the chequerboard pattern, you'd get similar results compared to another screen with the same gain. Hopefully Chris can give us a more definitive answer though.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #3041 of 3052 Old 07-02-2015, 07:04 PM
lovingdvd's Avatar
Quoted: 911 Post(s)
Liked: 152
Gary
Thanks Gary. I think the issue is more about ambient light control. One thing I noticed about all the weave screens I tested (a half dozen or so) is that they all were very poor with any ambient light. The manufacturers even state this up front - that it is not intended for use with ambient light. In my case I'll be filling a 140" screen with 1500+ lumens. That is a LOT of light to go scattering all over. I am specifically designing the room to have a velvet screen wall, 5-6 feet of velvet on each side of the screen, velvet on the ceiling and dark carpet. This should really help control the reflections, but even so there will be a fair amount of light still bouncing around. This can have quite an impact on the ANSI CR. And in a room without dark walls I imagine it would be even more significant. That is why I am wondering if anyone has measured it at their screen (not at the pj).
post #3042 of 3052 Old 07-02-2015, 10:12 PM
DavidK442's Avatar
Quoted: 254 Post(s)
Liked: 162
It seems to me that unless you are looking at a high priced retro-reflective screen specifically engineered to fight ambient light all typical wide angle white screens (woven or not) will reflect ambient light right along with the projected light.
(Hey Mr. Seymour sir: Please make me a screen that has at least 1.0 gain with near perfect color accuracy, negligible impact to audio and no noticeable weave at 8 feet...and oh ya, please make it suck up ambient light so I can watch my horror movies with the lights on so I don't get scared. Thanks.)
DavidK442 is offline
post #3043 of 3052 Old 07-03-2015, 04:01 AM
Quoted: 175 Post(s)
Liked: 112
Grey screens, or grey screens with a little gain work best to combat ambient. Lower gain weave screens are better than unity screens because they reflect less light, but ambient light will kill the black floor of any projector.
Black velvet will certainly help with reflections, but ambient (I assume you mean some actual light in the room rather than reflective walls etc) will negate a lot of what you do.
What is the source of your ambient light?
Gary
post #3044 of 3052 Old 07-03-2015, 05:41 AM
Quoted: 227 Post(s)
Liked: 76
One option for rooms with ambient light is to use a screen material for ambient light that is perforated. There are tradeoffs with woven vs. perforated but depending on the situation it might be a solution to consider. Like other aspects of audio and video it is about finding the right product for your application, there is no perfect screen, speaker, etc. that works in all situations.
Dirk44 likes this.
Ellebob is offline
post #3045 of 3052 Old 07-03-2015, 06:04 AM
lovingdvd's Avatar
Quoted: 911 Post(s)
Liked: 152
Gary
Ah yes, I should clarify. In my case, by ambient light I mean the light that is reflected from the screen back into the room and the reflections from that. No other light sources or outside room light or daylight etc.
I will have 140"w with screen edges (not frame edges) just 4" from ceiling and only 15" from each side wall and about 2feet from floor. So with 1500-1700 lumens it'll be throwing light all over the place.
The velvet should help a great deal but with this much brightness and this close to the surfaces (even the blackest of velvets have some sheen and are not a complete black hole) and this many lumens it's going to be a challenge maximizing ANSI CR with any woven screen and especially one like the XD which has among the best gain (which is one thing I love about it since I have a large screen to fill).
post #3046 of 3052 Old 07-03-2015, 01:17 PM
Quoted: 25 Post(s)
Cheers,
Chris
Chris,
Thanks for the quick response! The UF screen came tilted. I saw that you made a comment about the Panasonic projectors in another thread so I had asked Jon to make sure the UF material was tilted. My suspicion is that if you have a textured screen, then you will be aware of that from time to time under typical viewing distances. In my room, for example, the regular room ceiling light alone will produce some angled banding (following the weave tilt) that can be seen from my viewing distance of 9.5 feet..
post #3047 of 3052 Old 07-05-2015, 11:11 PM
mv038856's Avatar
Quoted: 18 Post(s)
Liked: 24
Cheers,
Chris
Hi Chris,
I don't know what SIM2 uses, but Infitec licensed their system to a number of companies. The color filters are said to consist of 200 layers to acchieve the channel separation.
Infitec is a spin-off from Daimler (Mercedes) where engineers were not satisfied with the available technology for 3D visualization... Like a Mercedes, the system is of high quality... but not cheap. I think the cost of the glasses were the main reason why Real3D was/is used in way more cinemas.
Cheers
Markus
mv038856 is offline
post #3048 of 3052 Old 07-06-2015, 09:29 AM
AVS Club Gold
chriscmore's Avatar
Quoted: 48 Post(s)
Liked: 49
Gary
The last I measured ANSI on the XD was 99% vs a reference solid target. We have a final baking and flattening step in the XD manufacture that flattens it just enough to solve cross-pixel light interaction but not too much to squash the AT properties of the weave. A summer or two ago we were out of stock of the XD for two months because four batches (~9000 ft) failed this final step.
There was an oft-sited white paper written by Stewart against woven screens and they chose the thickest, lowest ANSI material at the time which was Screen Research's Clear Pix. I measured them at 92% ANSI, but these are incremental differences that are hard to distinguish on their own. Elunevision's material is also thick and Scotch-brite-like that too, a performance aspect that was the only valid point of Stewart's paper.
Cheers,
Chris
Gary Lightfoot likes this.
Seymour AV
515-268-3369
515-450-5694
post #3049 of 3052 Old 07-06-2015, 10:48 AM
Quoted: 175 Post(s)
Liked: 112
Thanks for the info Chris, it's very useful.
SMPTE recently produced a report that weave screens are better than perf, so Stewart have now produced their own weave screen. Have you seen a comparison report of that new material yet?
Gary
post #3050 of 3052 Unread Today, 03:27 PM
Quoted: 20 Post(s)
Liked: 6
New Seymour AV Center Stage XD owner here! All I can say is WOW!
I decided to use Seymour simply for the fact that it was acoustically transparent. My original screen was 92" and since I want to move up to a 110" screen my main speaker would definitely be covered so AT was the only route.
First off I'd like to say that both Jon and Chris were extremely helpful in the selection and ordering process. It took me awhile to make a decision and after Jon sent a few samples I ultimately chose the XD as it most closely resembled the Studiotek 130 from Stewart that I was replacing. Initially I was very concerned that I'd lose the beautiful bright screen that the industry standard Stewart provided simply because the new one would be AT and using simple logic I felt I'd lose some of the gain and clarity. Boy was I wrong! I know upgrading my older JVC RS1 with the newer JVC 57U probably helped my case but I swear the new combo is twice as nice, and I was happy with the old set up to begin with, I just wanted a larger screen.
The new screen is INCREDIBLE! Not only do I feel it's just as nice as my old screen but the fit and finish are excellent! The case is sleek and modern compared to the bulky and industrial looking Luxus A and the motor is at least 50% quieter. The remote is comfortable and sleek and the RF receiver works flawlessly from any position in my 200 sq. ft. viewing area. Just the appearance of the case along with smooth operation of the motor puts the Seymour well ahead of the Stewart in design and function.
I will disagree with Chris on one point, I can't see any moire inside of 10 ft where I was told I might and that's a huge plus as some of my seat are as close as 7 ft from the screen. From my seating position I cannot tell it's an AT screen at all. My ears however are very happy with the screen. The only drawback is I now have to move any electronics. Out from behind the screen or create an AV cabinet as any bright indicator light will show thorough the screen reminding you that it's transparent.
The only complaint I have is not discovering AT screens and Seymour earlier! You simply cannot find a better screen for the price IMHO. If you are considering a new screen in the future you'd be doing yourself a favor by giving the good folks at Seymour AV a call!
ScottJ likes this.
Dr. Jekyll is online now
post #3051 of 3052 Unread Today, 03:46 PM
ScottJ's Avatar
Quoted: 169 Post(s)
Liked: 90
My equipment is all behind my XD screen and I can't see any lights shining through, thanks to these: http://www.lightdims.com/
Dr. Jekyll likes this.
ScottJ is online now
post #3052 of 3052 Unread Today, 04:07 PM
Quoted: 20 Post(s)
Liked: 6
BOOM, thanks bud!
Reply Screens
Seymour Av
