The official SeymourAV center stage screen thread! - Page 113 - AVS Forum | Home Theater Discussions And Reviews
 241Likes
post #3361 of 3377 Old 05-07-2017, 07:48 PM
ScottJ's Avatar
Quoted: 317 Post(s)
Liked: 158
mycview2, does your scaler or sources have the option to move the image to the bottom of the screen?
That applies to the format I have (1.78 screen with CIW mask). I use the Lumagen Radiance's electronic image shift. Projector lens shift could also work. A third option would be to move the bottom of the screen up when moving the mask down.
For the 2.35 screen that mycview2 was asking about, you'd need to zoom or scale, not shift, when changing ARs.
ScottJ is offline
post #3362 of 3377 Old 05-11-2017, 01:17 PM
DRC3's Avatar
Quoted: 90 Post(s)
Liked: 112
Just made the jump to AT Screen- Center Stage-UF
Just got home from Fedex Freight and getting ready to open things up. 2.0:1 Aspect ratio ~130" Diagonal. Going from a 2.35:1 128"Diagonal Carada Brilliant White. By the way Projector is Panny 8000. Excited to finally be able to reposition the center channel and subs
Thanks much Chris and Jon!
Don
chriscmore likes this.
DRC3 is offline
post #3363 of 3377 Old 05-12-2017, 03:36 AM
jmone's Avatar
Quoted: 12 Post(s)
Liked: 37
Q on Harmony Elite control IR control. I've got the RP60 230V Controller, LVT-BUS JP6 and IR Sensor and I'm in the process of setting it up over the next couple of weeks. Trigger is working well, but can I confirm what device to add to a Logitech Harmony Elite to trigger UP and Down for the screen? Is it the ESI RP-60?
Nathan
jmone is offline
post #3364 of 3377 Old 05-12-2017, 05:32 AM
BrolicBeast's Avatar
Quoted: 1206 Post(s)
Liked: 1260
Nathan
Safest bet is to learn the command from the screen remote. I've been using Harmony remotes for the last 12 years, and in my motorized screen setups, I had to learn the command in order for it to work properly. There are usually three commands: up, stop, and down.
Sent from my SAMSUNG-SM-G935A using Tapatalk
BrolicBeast is online now
post #3365 of 3377 Old 05-12-2017, 06:26 AM
Fazzz's Avatar
Quoted: 91 Post(s)
Liked: 58
Don
I have UF with a Panny 8000, as well. You're going to love UF. Nothing but rave reviews from me.
DRC3 likes this.
Fazzz is online now
post #3366 of 3377 Old 05-12-2017, 01:53 PM
jmone's Avatar
Quoted: 12 Post(s)
Liked: 37
Unfortunately I don't have a remote to learn from...
jmone is offline
post #3367 of 3377 Old 05-12-2017, 06:11 PM
DRC3's Avatar
Quoted: 90 Post(s)
Liked: 112
Thanks-got it built...held it up and looks good! Thanks for sharing Fazzz!
DRC3 is offline
post #3368 of 3377 Old 05-15-2017, 01:44 PM
Quoted: 112 Post(s)
Liked: 84
As earlier described in this thread, the UF material isn't very good for behind the screen lighting to reveal the speakers. I laid down a 16' LED light strip behind the screen and a velvet wrapped 2X2. I doubled the LED light back so I had two runs of the lighting casting on the speakers. Although it doesn't reveal the speakers well, it casts a pretty cool effect, especially when set at a 7 color fade. If I fire up the star ceiling with the LED's, the rear speakers with the LED's and the LED's behind the screen, it gives a pretty cool intro to the theater for folks that are seeing it for the first time. The rainbow effect in the pano picture on the bottom is due to the way the phone took the picture.
chriscmore and DRC3 like this.
Jerry
Fairbanks, Alaska
DIY In Progress Home Theater Build: http://www.avsforum.com/forum/19-ded...tic-build.html
Star Ceiling Build: http://www.avsforum.com/forum/19-ded...am-boards.html
arcticbowman is online now
post #3369 of 3377 Old 05-19-2017, 10:49 AM
Fazzz's Avatar
Quoted: 91 Post(s)
Liked: 58
Jerry,
Looks great. How close are your speakers to the screen?
Fazzz is online now
post #3370 of 3377 Old 05-20-2017, 12:03 PM
Quoted: 112 Post(s)
Liked: 84
Jerry,
They are roughly 5-6" behind the screen.
Jerry
Fairbanks, Alaska
post #3371 of 3377 Old 05-20-2017, 02:50 PM
schmidtwi's Avatar
Quoted: 216 Post(s)
Liked: 151
I'm very happy to soon join the Seymour Center Stage XD crowd. I just purchased an XD screen from Jon yesterday - great customer service!
I plan a ~158" diagonal (146" x 62) 2.35 screen to fill the stage in the pic below. I will use 1x4 poplar or maple for a DIY frame. I have an Epson 5040UB (4K eShift) projector, currently projecting on a 135" 16:9 Elite screen in another room. Can't wait to get the new screen built - will post after pics when completed.
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #3372 of 3377 Old Yesterday, 10:33 AM
chriscmore's Avatar
Quoted: 140 Post(s)
Liked: 152
We have the new Enlightor-Neo stock imported from the UK for immediate availability. It's roll width causes a height limitation of around 72". As we'll be looming it locally I'll be making a few tweaks, so as the old disclaimer goes "subject to change," but as it is now it's a fantastic screen material. Higher gain than the Enlightor-4K, much more matte, 0.5dB more AT (still flat), a whiter looking color and while the pattern is not randomized like the Enlightor-4K, its structure is shrunk down so small it passes the challenges I make at demonstrations to come up and put your nose on the material and tell me if you can see anything.
The next show it will be demonstrated at is in the Dolby Atmos room at the LA Audio Show (LAAS) with JVC (their new laser 4K RS4500), Trinnov, and Stark Sound.
Samples are available if you contact me, Jon or Cody.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #3373 of 3377 Old Yesterday, 03:20 PM
RapalloAV's Avatar
Quoted: 1451 Post(s)
Liked: 384
Cheers,
Chris
Chris would the listed gain of 0.95 be the same or better than my XD from you?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #3374 of 3377 Old Yesterday, 03:53 PM
chriscmore's Avatar
Quoted: 140 Post(s)
Liked: 152
Gain isn't "better" one way or another, but the Neo (similar to the UF) is about -20% lower gain than the XD.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #3375 of 3377 Old Yesterday, 04:12 PM
Quoted: 1083 Post(s)
Liked: 591
Will it be able to have grommets and fit in a Seymour frame or does it install like the Enlightor 4K with the grooves and spatula installation. I am thinking about upgrading my screen from the UF if you think it is better.
Ellebob is online now
post #3376 of 3377 Old Today, 09:53 AM
chriscmore's Avatar
Quoted: 140 Post(s)
Liked: 152
It's too fine for grommets, staples, or other point source loading. It'll be used in the grip channel tension systems that S-SE has.
Compared to the UF, it's as if the structures were shrunk down by 1/2. If you find at your seating distance you can make out any visible structure, then perhaps the Neo would be an improvement. I watch the UF at 11.6' viewing distance and have no plans to switch that to the Neo.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #3377 of 3377 Old Today, 10:45 AM
Liked: 591
Thanks. I'm about the same distance so good to know.
Reply Screens
Seymour Av
