The official SeymourAV center stage screen thread! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 266Likes
post #361 of 3458 Old 02-09-2009, 06:38 AM
bmwracer3's Avatar
Here's a link to my XD gallery.
Let me know if there are any problems viewing it or if you have any questions. Thanks!
The source material in these screen shots was either the HQV 1080p test disc or Ratatouille on BluRay, via a Pioneer 51FD and a Mits HC6500. I still have some pattern, especially on faces, but it's better than before. I'm not sure how to get totally rid of it, and I think maybe I sit too close.
Oh well, stop staring at pixels and enjoy the show, that's what my mum used to say.
bmwracer3 is offline
post #362 of 3458 Old 02-09-2009, 06:56 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
oman321 is offline
post #363 of 3458 Old 02-09-2009, 07:18 AM
scottyb's Avatar
Quoted: 29 Post(s)
bmw,
Is the brightness about the same?
If i have original without any moire problems would you switch?
scott
scottyb is offline
post #364 of 3458 Old 02-09-2009, 07:48 AM
bmwracer3's Avatar
Originally Posted by scottyb View Post
bmw,
scott
Scott,
I'd say the brightness is about the same, but there is a hair more ANSI contrast. If you don't have any moire problems with the original, I would think you should be ok. The only way to check for sure is to have Chris send you a sample. Everybody's pj's and throw distance is different, so I can't throw a blanket statement on saying that this material will be unequivocally better for everybody. It probably will be though, based on what I've seen on my setup.
Chris
post #365 of 3458 Old 02-09-2009, 08:31 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Hey bmw, I know you had your old A lens on the block before. What new lens did you get if any? Are you happier with it?.
oman321 is offline
post #366 of 3458 Old 02-09-2009, 09:23 AM
bmwracer3's Avatar
I'm zooming for now until I can save my nickels up for a Prismasonic/Panamorph. Then of course I'll rebuild my screen yet again. ACK!>!>!(*@#$(*asdljhasdfn
post #367 of 3458 Old 02-09-2009, 10:29 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Well at least one of your options is now cheaper since they did away with dealers. I think it's prismasonic, can't remember which.
oman321 is offline
post #368 of 3458 Old 02-11-2009, 09:57 AM
mustang5o's Avatar
Quoted: 34 Post(s)
I'm thinking about switching to an acoustically "transparent" screen. I'm trying to decide between the newer Elite perf screen or a DIY screen. Anyone have any comparisons between these two? So far this seems like the better route but a brief review at projector reviews said the Elite was decent.
Of course if I go AT I'm going to have to switch speakers. I just don't have room for my existing speakers unless I just fire the rear ports in to the furnace room behind that wall. I might try the other side but I'd still lesson my room length by like 1 1/2-2'. Then again, I kind of don't have that room now with my speakers sitting out on the floor.
"Like a Ninja, only better!"
mustang5o is offline
post #369 of 3458 Old 02-11-2009, 01:34 PM
BKEW's Avatar
BMWRACER3,
Just a question, are the material pictures posted in your the link posted backwards??
It could just be the pictures but if you scroll back a page on this thread, the material you posted as "OLD" looks a lot like the "New" material posted on page 12?
Again it could just be the picture. I am just wondering as I am going to order from Chris some material and I am still leaning towards the "original" as the pattern looks smoother.
EDIT:
Ok I had the page 12 pictures up with your pictures and honestly it is hard to tell. I think the 3rd picture of the new material on page 12 gave me the impression above.
Can you tell me which what has a smoother texture?
BKEW is offline
post #370 of 3458 Old 02-11-2009, 01:46 PM
bmwracer3's Avatar
Originally Posted by BKEW View Post
BMWRACER3,
EDIT:
The XD is definitely smoother. I'll take a more like for like picture tonight to compare. My XD shot before was taken while I was standing over the material in while it was laying out on the floor.
post #371 of 3458 Old 02-11-2009, 08:50 PM
BKEW's Avatar
BMWRACER3,
Much appreciated. I am going to contact Chris and order the new XD.
Off topic question, in your pictures "new material laying on the floor". The white column on the left of that picture and the one in the back ground along the wall. Are they support post covered that way? Or just decorative? I know off topic but we are working on our basement and my wife saw it loved the look. We have two supports I can not hide in walls. Either way I think we found an answer in your pictures =)
Thanks for the feed back on the XD
BKEW is offline
post #372 of 3458 Old 02-11-2009, 09:13 PM
bmwracer3's Avatar
BMWRACER3,
XD is the way to go.
Those are support posts in the pics. Basically you take 4 rips of MDF, glue them together, flute them with a router, and they slap crown at the top and 1 or 2 pieces of shoe on the bottom. Pretty easy really, although I hired my trim guy to do it. I wanted to buy some time back.
post #373 of 3458 Old 02-20-2009, 08:03 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I just ordered the XD material for my DIY screen (115" wide 2.35:1) build. The evolution of this thread with all the user comments and along with Chris from Seymour AV, sold me on this product.
Thanks for sharing all of your experiences.
laugsbach is offline
post #374 of 3458 Old 02-20-2009, 06:33 PM
BKEW's Avatar
I received my XD in the last few days and I have to say it is excellent material. Very pleased with the material and Chris. Would highley recommend to anyone looking at the DIY route.
BKEW is offline
post #375 of 3458 Old 02-24-2009, 11:10 AM
V.X.Donique's Avatar
Quoted: 52 Post(s)
Liked: 45
Screen ordered, thanks Chris...
V.X.Donique
Introducing the Vier Systems Xero.1/Midbasiks Subwoofer builds....
Creator of the AVScience DIY Speakers and Subwoofers Forum
"Don't concentrate on the finger or you will miss all that heavenly glory." -Bruce Lee
V.X.Donique is offline
post #376 of 3458 Old 03-02-2009, 11:30 PM
mapitc0's Avatar
The projector central review of the elite material was for their new woven, not the perforated vinyl they're still stelling at sizes of 110" and below (16:9). No one has seen their new material to compare to the old or new center stage, shearweave 4500, or anything. I go with what's been tested and proven by the community.
mapitc0 is offline
post #377 of 3458 Old 03-04-2009, 06:24 AM
Quoted: 52 Post(s)
Liked: 45
Screen delivered in perfect shape!
Thanks again Chris for your help and patience!
V.X.Donique
post #378 of 3458 Old 03-07-2009, 05:52 AM
sonofdbn's Avatar
Are the Center Stage screens available ONLY as retractable screens? Or are they sold as fixed screens as well? From the Seymour AV website it seems as if they are only retractable (or DIY).
sonofdbn is offline
post #379 of 3458 Old 03-07-2009, 07:04 AM
mlbrand's Avatar
They only sell retractables ready made, but sell the screen material and possibly frames to make your own fixed screen.
mlbrand is offline
post #380 of 3458 Old 03-07-2009, 12:53 PM
kainers's Avatar
Hello hello,
I received a sample of the Seymour, and Seymour XD material last week. Can definately see the weave is smaller and tighter on the XD. I taped the material up to a wall, and a sample of Carada BW. Both Seymours, and the Carada look great to me, to be honest...I have a hard time telling the difference from 9-10 feet. I thought it would be obvious (higher gain. no holes), so I am wondering if that sounds right? Could it be some of the high gloss paint is reflecting from behind the holes on the AT material, thus making it brighter? Or both just that good ?
kainers is offline
post #381 of 3458 Old 03-08-2009, 05:34 AM
mlbrand's Avatar
That good, of course! Actually, I think it's harder to pick out a screen that is brighter, if the gain of ALL the material you are looking at is adequate. But if you are on the edge, with the lower gain screens being obviously too dim, then the brighter screens will be more obvious, because you really needed the extra brightness. Testing screen gain side by side would also be influenced by the brightness of the movie scene being viewed, and room ambient light. The darker the room and movie scene, the more the difference might stand out as well. All that said, I have always been impressed with the gain and brightness of my SeymourAV AT screen.
mlbrand is offline
post #382 of 3458 Old 03-09-2009, 11:23 PM
chriscmore's Avatar
Quoted: 166 Post(s)
Liked: 186
Originally Posted by kainers View Post
Hello hello,
Hi Kainers -
You should place something dark behind any AT fabric to more realistically see how it will look. If the surface behind the material is reflective enough, it can introduce artifacts that wouldn't occur in a proper installation.
Also, make sure you're evaluating it with projected light, similar to how you'd be watching a movie with respect to ambient light and throw distance.
I'm a huge fan of the Carada BW material, so if you don't need AT, they're a great product and what I typically recommend. Regarding brightness differences, I've had some people comment that we look nearly as bright (if you're within about 10% it's hard to tell without a meter), and some people notice the BW is definitely brighter. While the BW is certainly higher gain, the real world differences depend on your application. Hence, samples...
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #383 of 3458 Old 03-10-2009, 09:46 AM
will1383's Avatar
Ok, how do I email Chris? I need to begin with ordering a couple of samples to make sure I'm getting what I need/want.
will1383 is offline
post #384 of 3458 Old 03-10-2009, 11:26 AM
mlbrand's Avatar
chris@seymourav.com
mlbrand is offline
post #385 of 3458 Old 03-10-2009, 12:06 PM
will1383's Avatar
will1383 is offline
post #386 of 3458 Old 03-10-2009, 06:39 PM
MarkDub's Avatar
Just ordered my XD material today from Chris. I'm excited to get the screen built next week and try this out as it's the first AT screen I will try. Mine will only be 97" wide for a 2.37 scope screen, but at a 10' viewing distance and with my FPJ1 it should be plenty big. I'll post some pics when it's in use.
Mark
Oh...Johnny, I apologize; I forgot you were there. You may go now.
Dub Theater HT Build In Progress
MarkDub is offline
post #387 of 3458 Old 03-11-2009, 01:05 PM
will1383's Avatar
I still haven't heard back from him. Is he on vacation?
will1383 is offline
post #388 of 3458 Old 03-12-2009, 10:35 AM
Doug G's Avatar
Anyone in the eastern MA or southern NH area still have their box for an x090 retractable?
If so, please PM me.
Doug G is offline
post #389 of 3458 Old 03-13-2009, 04:46 AM
yourtoys7's Avatar
bmwracer3'
I'm having Moire' isue with my just build 135" 2:40:1 screen. I've used 4500 material and didn't get the 96" or something inch., but the smaller one (that might have been my mystake). Look in the link http://www.avsforum.com/avs-vb/showt...1109260&page=3
I'm using Epson 1080UB, will xd material eliminate my problem? I try to order XD sample as well. Thanks...
EluneVision 106" Reference Studio 4K Tab-tensioned - 1.0 Gain, Benq 1070, psb T6, Rotel, OPPO, Velodine (Now),
135" AT screen, JVC-X35, 3x RF82, 3x Emotiva XPA100, Velodine, Rotel, OPPO (Sold with house).
yourtoys7 is offline
post #390 of 3458 Old 03-13-2009, 07:53 AM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
yourtoys7, I just finished my XD DIY screen build (115" wide 2.35:1 with a 4.5 degree tilt). I have a Panny 3000 PJ and sit between 11' to 16' from the screen and I have zero moire issues.
Reply Screens
Seymour Av
