The official SeymourAV center stage screen thread! - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 194Likes
post #451 of 3315 Old 05-11-2009, 12:39 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Originally Posted by mkanter View Post
Well, I've now got the screen installed but my wiring and control solution is a no-go so far.
I've posted a more detailed explanation in the home automation thread linked above. I don't think I understand the wires coming out of the 4-wire motor. Chris (or anyone) have any suggestions for me?
Hi Max -
Since you have a 4-wire motor, the basics are:
green wire: ground (yellow/green for the 230v folks)
white wire: common (blue for 230v)
black wire: screen down
red wire: screen up (brown for 230v)
It is a 210w motor, so make sure any switching device you use is rated for that. If you end up either needing just a wall switch, let me know and you can get a maintained 3-position. If you end up needing more control options, let me know and you can get the motor control box and control it any way you want.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #452 of 3315 Old 05-11-2009, 01:52 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Originally Posted by phansson View Post
Hey Chris,
I sent you a message via your website. A couple of last questions before I order.
1. If you order a satin white case can you get a black batten?
2. If I order the 115" 2.37 screen, can I get an 8" left and right border instead of the standard 2"?
3. Are you using the XD material in your electric screens yet? The website says it is beta consult factory.
Patrick
1. Yes, because the weight bar is rolled in 4" black velvet, black is the only color option for the batten.
2. This one is tougher. I could stitch on 4" black velvet along the sides, but they'd need to steer clear of the tension hardware on the bottom of the pipe. It would be unusual for us to do, but if it's critical we'll figure it out.
3. Only for select applications. Either wide scope screens, smaller than standard, where the customer has a real need (e.g. sitting closer than typical), and/or where the smooth screen type projectors are used (e.g. Panasonic, D-ILA/LCOS/SXRD)
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #453 of 3315 Old 05-11-2009, 02:01 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Originally Posted by sonofdbn View Post
In this post some figures were given comparing reflectivity and light opacity of Seymour AV Swiss Velvet and its black backing (BB) (as well as other materials).
Anyone have a picture of how the two look next to each other? I might place my LR speakers adjacent to the screen, rather than behind. If I hide them behind the Seymour AV BB, would the difference between the screen border and the BB be very noticeable or jarring?
I'll see if I can snap a picture sometime, but if you need samples let me know. It really depends on how much light is expected to go through it from behind, vs. direct reflection absorption (e.g. overscan), vs. how much AT is needed. Our BB is not quite as dark as GoM, but is more acoustically transparent. How dark they are in comparison to a black velvet I'd say is noticeable, but I don't think jarring in a bad way. Another way you can get the effect is to try a really thin, cheap velvet. Some of them are so thin that they are quite acoustically transparent, but maintain some velvet look. If we focused on masking panels, I'd have direct options I could offer, but you're swimming in less familiar DIY waters.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #454 of 3315 Old 05-13-2009, 11:39 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Wider 2.35 (or custom variation thereof) ratio screens are now available. We added the 120" wide and 130" wide image sizes. I can't go that wide in the 16:9 ratios at this time because only so much material fits into the case, and images with that much height push the standard material too hard.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #455 of 3315 Old 06-01-2009, 10:41 PM
hulkss's Avatar
I took advantage of the Seymour AV screen upgrade policy and installed a new 115" wide, 2.35 aspect ratio, XD retractable screen. What a great product Works perfectly with my panasonic PT-AE3000U projector (no tilt in the material micro hole pattern). The screen hangs almost perfectly flat.
hulkss is offline
post #456 of 3315 Old 06-05-2009, 12:48 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
The retractable screen manual was WAY overdue for updating. I finally got it finished up with a lot more photos and details about unpacking, installation, control and troubleshooting.
http://www.seymourav.com/articles/Ce...structions.pdf
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #457 of 3315 Old 06-09-2009, 10:44 PM
jrm1504's Avatar
So are the fixed mount screens still anticipated for release on the 15th? Are they going to use the new material???
jrm1504 is offline
post #458 of 3315 Old 06-10-2009, 01:13 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Yes and yes.
I'll have more photos and of course pricing up on the 15th. While the XD will be standard and available on all screens on the 15th, I'll need a bit more time to get it's new specs and pictures of the XD on the site.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #459 of 3315 Old 06-10-2009, 01:55 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Looking foward to pics of your new screen. Congrats on moving foward with what I'm sure will be another fine product. Already recommended someone to look at it when it comes out the 15th. Good luck.
oman321 is offline
post #460 of 3315 Old 06-13-2009, 03:49 PM
kitkat99's Avatar
interested in the retractable screen. I called last week, spoke to chris, Is there a new screen fabric coming out, when? what was the difference? thanks
kitkat99 is offline
post #461 of 3315 Old 06-15-2009, 12:22 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Just checked out your new fixed frame and also looked at the install instructions to see how it comes together. Very Nice!! Install seems as simple as it could possible get. The pricing seems very fair too, good luck on your new product.
oman321 is offline
post #462 of 3315 Old 06-15-2009, 12:25 PM
Taz1's Avatar
I was looking at them this morning. I like what I see.
Taz1 is offline
post #463 of 3315 Old 06-15-2009, 12:27 PM
will1383's Avatar
Yes, they are very reasonable, indeed.
will1383 is offline
post #464 of 3315 Old 06-16-2009, 07:33 PM
jrm1504's Avatar
I want one...do you stock the sizes, or is there a delay while they are built to order?
jrm1504 is offline
post #465 of 3315 Old 06-16-2009, 08:18 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
We got the first batch of our new Center Stage XD last winter, but in the 63" roll size it was (is) quite limited to nice wide scope screens. We now have in stock the 98" roll size Center Stage XD, so we can make any and all of our screens with the upgraded material.
I'm way behind updating the site for the XD pics/specs - it's high on the list to do - but in a nutshell it's our new weave where we:
1) tripled the hole density from ~500/sq.in. to 1500+/sq.in.
2) tweaked up the gain a tad to 1.2
3) improved the acoustical transparency +0.5dB from 2k-20kHz
4) much finer weave allows closer seating and an invisible texture at normal seating distances.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #466 of 3315 Old 06-16-2009, 08:23 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
We don't stock sizes, since everything is hand made to order here in Ames, IA. They take about a week to make, although I had a visitor at the end of the day yesterday pickup a fabric order and when he saw the new fixed frame screen he insisted that we make one for him right now. Jon lasted until about 12:30am and I sealed it up at 2am.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #467 of 3315 Old 06-19-2009, 08:33 AM
amps's Avatar
Will the wider XD fabric be available for DIY soon?
I'd like to build a 110" screen but after working in the tilt, I don't think it would work with the 63" fabric.
amps is offline
post #468 of 3315 Old 06-19-2009, 11:01 AM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
The 98" wide XD is in, standard on all manufactured screens, and available for DIY.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #469 of 3315 Old 06-19-2009, 12:07 PM
TomBonge's Avatar
I really need you guys to help me decide, I just not convinced that a AT screen will look as good as a solid screen.
I just think way too much light passes though the screen and is lost. I also can't decide on 2.35 vs 16:9 but that's another issue. I got the XD sample, and it looks fine but it is really hard to judge from the small area and I am afraid that full screen it will not look the same. And now there is a new wider XD fabric with a slightly different weave.
Tell me how happy you are to convince me.
TomBonge is offline
post #470 of 3315 Old 06-19-2009, 03:58 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Tom -
If the letter size doesn't suit you (larger than most other companies send), you could get the $20 sample that is 24"x24". On 4 sq. ft. it's pretty easy to tell if you'll like it or not. Just make sure to put something dark behind the sample, as an AT screen over something white looks terrible.
Also, we offer 30 return guarantee on everything but cut DIY material orders. The most you'd be out is shipping, but again the 24x24 is even lower risk.
Finally, the upgrade policy enables you to upsize later in case you feel that you want more later on.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #471 of 3315 Old 06-19-2009, 07:11 PM
sCiEnt's Avatar
Chris,
I will be buying the backing and fabric from you and I already have the roller, I am just trying to work out the tensioning system before I decide on the material width. Can we have detailed pictures of the tab tensioned screen? I would like to see how its done for a DIY build. Thanks!
sCiEnt
sCiEnt is offline
post #472 of 3315 Old 06-19-2009, 09:12 PM
laugsbach's Avatar
Quoted: 130 Post(s)
Liked: 199
Hi Tom,
I have the XD material on a 115" wide 2.35:1 DIY screen and I absolutely love it. I can not tell that the screen isn't "solid" until about 3-4 feet from the screen.
BTW, the picture, as well as the sound (L/C/R speakers behind the screen), is fabulous with my Panny 3000.
laugsbach is online now
post #473 of 3315 Old 06-20-2009, 11:07 AM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
I put up a couple short video clips. First, while the o-ring tension system seems easy to install, in reality it actually is. The clip is here: O-ring installation
Second, to demonstrate the robustness of the tension system, here's a clip of something you'd never try on other screens that use snaps, rods, t-trim, etc: Tension durability
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #474 of 3315 Old 06-20-2009, 03:32 PM
KenLand's Avatar
Hey everyone,
I'm looking at a 105" wide extended drop 16:9 electric.
My install is kind of tricky and I need some dimensions such as exactly where is the mounting rail located w.r.t. the bottom of the case.
I also need to know exactly where the screen drops out of the case front to back. (is it closer to the audience or closer to the wall?)
Anyone have these dimensions or maybe a closeup pic showing the underside of the case?
The installation guide doesn't seem to have much detail on this. I only know the case is 5.5"Deep x5.8"High.
Where along the 5.5" does the screen actually go in and out of the case and where along the 5.8 is the center of the mounting bar?
Ken
KenLand is offline
post #475 of 3315 Old 06-21-2009, 11:03 PM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
The standard method is that the screen unrolls from the back, or closer to the wall. There's only ~0.5" clearance from the bar to the wall. If you prefer that it unroll on the opposite/front side, we then need to do a reverse roll. That's no problem, but since the front of the case doesn't have a mounting feature, reverse rolls need to use their ceiling mount side to install.
The wall and ceiling mounting bar features in the extrusion are in the middle of each dimension.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #476 of 3315 Old 06-22-2009, 03:37 AM
KenLand's Avatar
Chris,
So I can't have it as this sketch shows?
KenLand is offline
post #477 of 3315 Old 06-22-2009, 10:39 AM
chriscmore's Avatar
Quoted: 122 Post(s)
Liked: 111
Chris,
No, the extruded aluminum doesn't allow for that. You show the mounting feature where the designed, curvy part of the case is. In hind sight, perhaps we should have nixed the design goal on the "front" and just put another french cleat mounting feature.
Other options include: 1) caseless screen, which you can mount in any orientation you want with the two end L-brackets, and 2) we can drill/tap threaded mounting holes on the ends of a case so that you can L-bracket it to the wall like you drew.
Cheers,
Chris
Seymour AV
515-268-3369
515-450-5694
post #478 of 3315 Old 06-22-2009, 01:56 PM
tony123's Avatar
Liked: 38
Just placed my order (XD in 98"x180") and am very excited!!! Thanks for answering all my questions Chris.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #479 of 3315 Old 06-23-2009, 07:53 AM
sCiEnt's Avatar
Hello Chris,
Anything on pictures of the tab tensioning system? (Only if you don't mind sharing them, of course)
sCiEnt
sCiEnt is offline
post #480 of 3315 Old 06-28-2009, 01:38 PM
airliner's Avatar
Quoted: 20 Post(s)
Hi Cris, I bought some center stage from you almost one year ago and still did not use it. Do you think I can use it to replace a retractable screen of mine? If yes do you think is going to be difficult? Tks Marco
airliner is offline
Reply Screens
Seymour Av
