The official SeymourAV center stage screen thread! - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 263Likes
post #1621 of 3450 Old 03-26-2012, 10:43 AM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4648
Originally Posted by TedO View Post
Chris,
Is the EN2 material on the Seymour/Screen Excellence web site the same as the XD material?
Besides the mounting technique (O-rings and grommets vs groove tensioning) can you tell me or show me the difference between the EN4K frame and the frame that comes with the XD screens?
Can I order either screen from you or do I need to work through a dealer for the EN4K screen?
Do you have a showroom or the screens on display in your plant in Ames?
Can you PM me pricing for both screens H120 and F160 in the EN4K material?
Not Chris, but I can answer some of your questions. The EN4K material can't be used with an O-ring grommet install due to the fabric, that is why it is installed with a bead type system. The EN4K screens are sold through dealers. If we can help you, please give us a call.
mjgarrett100@gmail.com
Mike Garrett is online now
post #1622 of 3450 Old 03-27-2012, 08:09 PM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
Just received my XD screen. Frame came together nicely however I noticed the bottom section of the frame does not rest perfectly level on one side of my false wall. I'm sure this is likely due to my false wall being off slightly as the frame is perfectly level. Any thoughts on how to secure the bottom side the the frame so it stays securely on the wall? The hangers are also perfectly level so that's not the cause either.
adidino is online now
post #1623 of 3450 Old 03-27-2012, 08:18 PM
ADDUpstate's Avatar
Scribe the false wall panel to match.
ADDUpstate is offline
post #1624 of 3450 Old 03-27-2012, 08:26 PM
Brad Horstkotte's Avatar
Liked: 72
Could use a bit of velcro - but make sure you can still get the projector lens perpendicular to the screen, or it will drive you nuts.
Brad Horstkotte is offline
post #1625 of 3450 Old 03-28-2012, 03:53 AM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
It's just lifting off the wall on one side towards the bottom. If I press the bottom edge with finger with hardly any pressure at all, it will stay flat. Velcro is an option. I'm surprised there isn't any hardware included to secure the bottom like the Stewart frames.
post #1626 of 3450 Old 03-28-2012, 06:02 AM
SteveHorn's Avatar
How far off the wall is it? If, as you say, the screen is "flat" (i.e not twisted or warped) and that the wall is the culprit, you could shim the french cleats that the screen hangs from off the wall by enough so that the entire screen is plumb. (You would likely have to shim out the bottom of the frame so the screen is plumb and not "aimed down" due to the cleats.)
But if the gap is not as severe, the velcro option sounds like a plan.
SteveHorn is offline
post #1627 of 3450 Old 03-28-2012, 08:47 AM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
Velcro seems to make the most sense at this point.
post #1628 of 3450 Old 03-28-2012, 09:07 AM
Liked: 4648
You can use an "L" shaped clip. If you want the clip to be hidden. place one leg of the clip so that it is behind the screen and then screw through the clip into the bottom of the screen. Other leg of clip is fastened to a stud in the wall. You will have to remove the screen to install the clips. This is the method that most marker boards and tack boards are installed by, except four or more clips are used. It is similar to how Stewart hangs their screens.
post #1629 of 3450 Old 03-28-2012, 10:28 AM
adidino's Avatar
Quoted: 365 Post(s)
Liked: 277
That would require drilling into the frame though. No? I don't recall seeing holes on the frame to support an L bracket.
post #1630 of 3450 Old 03-28-2012, 04:12 PM
Liked: 4648
Correct you would need to drill into the bottom of the frame or use self drilling screws.
post #1631 of 3450 Old 03-29-2012, 09:29 AM
Chuck Miller's Avatar
I'm in the process of building my HT. I've seen several comments about recommendations for 1" to 2-3" between speakers and AT screens. I notice that those are for LCR speakers. This leads me to believe that subwoofers are a no-no behind AT screens. My setup could place not one, but two subwoofers behind a false wall. So, what's the party line on subwoofers and AT screens? The AT material is very interesting, just want to see if it comes with limitations on sub location.
PS: The speaker system I plan to buy includes two subs and they are recommended to be placed side by side at the front of the theater. Hence my question :-)
Chuck
"The Ginky Weeds" Theater Design and Construction Thread
Sherbourn PT-7030, PA 7-350, PA 7-150, PA 4Z-75, C-12, Oppo BDP-103D
Klipsch La Scala I LCR with Crites AA crossovers & tweeters; Heresy I S&R surrounds with Crites crossover upgrades
Bill Fitzmaurice DIY THT subwoofers (2)
Chuck Miller is offline
post #1632 of 3450 Old 03-29-2012, 09:33 AM
Mopar_Mudder's Avatar
Quoted: 27 Post(s)
Liked: 37
Normally with a false wall your subs would be below the screen. I can't think of too many situations where the sub would actually be firing through the screen any way.
Mopar_Mudder is offline
post #1633 of 3450 Old 03-29-2012, 09:48 AM
studlygoorite's Avatar
Quoted: 104 Post(s)
Liked: 44
Are you more apt to get hot spotting with a curved screen than without.
My sub will be behind an AT Screen also.
Anthem AVM 60, Paradigm Sub 2, Paradigm S8s with C5, Anthem Statement M1 Amps, 174" Curved AT Scope Screen, Epson Pro Cinema LS10000 Laser 3D Projector, Samsung 4K Blu-ray Player, Oculus Rift VR, Xbox One, PS4, Clark Synthesis Transducer For Chair
studlygoorite is offline
post #1634 of 3450 Old 03-29-2012, 10:21 AM
Jedirun's Avatar
Liked: 55
Chuck
I think that subs will be much less affected by being behind acoustically transparent material than your LCR's, and I certainly have no issues with my LCR behind my Seymour screen. I do not think this will be a problem.
Someone please correct me if I am wrong.
Jedirun is offline
post #1635 of 3450 Old 03-29-2012, 01:31 PM
deromax's Avatar
Quoted: 14 Post(s)
I never had any trouble with powerful subs near or behind my screen causing ripples. On the other hand, my shelf mounted projector is being rattled at some frequencies on reference listening and the image will slightly blur. Aftermarket Soborthane (SP?) feet under the projector helped a lot but not completely.
deromax is offline
post #1636 of 3450 Old 03-29-2012, 06:10 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 423 Post(s)
Liked: 447
Zero hot-spotting with any weaves, curved or otherwise because they have very uniform luminance.
Subs behind AT screens are of no concern acoustically; that frequency range will go through any such material like it's not there. Forward-firing ports are another matter. They can have a screen (or fabric like 701) jumping quite noticably on explosions, etc. It is an easy fix, though, to rotate the sub 90 degrees so that the port isn't aimed at the screen. There is absolutely no acoustic downside to doing this.
Cam Man is offline
post #1637 of 3450 Old 03-29-2012, 08:41 PM
Thanks for all the replies. What I was concerned about was the effect of the subs on the screen, not the ability of the screen to pass the audio. I think that the subs would be located below the screen, so maybe it's not so bad. Whatever I put in front of them I expect will be vibrating or moving. I'd prefer that it not be the screen!
Chuck
post #1638 of 3450 Old 03-29-2012, 09:44 PM
chriscmore's Avatar
Quoted: 161 Post(s)
Liked: 185
No, actually a curved screen helps reduce hot spotting for screens with high gains, but for screens under perhaps 1.3 gain there are no uniformity benefits to curving the frame.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #1639 of 3450 Old 03-30-2012, 03:04 AM
Liked: 4648
Chuck
Subs located below the screen will not have any affect on the screen.
post #1640 of 3450 Old 03-30-2012, 06:28 AM
Thanks Mike. That's good to know. I'm sure I'll have plenty of other vibrations to deal with.
Chuck
post #1641 of 3450 Old 03-30-2012, 01:19 PM
ADDUpstate's Avatar
Hey Chris,
Stopped by the house today to drag in the new frame and masking panels...
Unboxed everything and man, those masking panels are no joke.
I was expecting something lightweight... these are high quality, sturdy aluminum frames with the AT material wrapped around them...
Can't wait to get them in use, but first need to swap out the frames...
Thanks so much for your flexibility and attention to detail. Top notch organization and quality product produced in the USA! I'll get the original frame back to you ASAP.
post #1642 of 3450 Old 03-30-2012, 04:37 PM
Quoted: 104 Post(s)
Liked: 44
[quote=Cam Man;21845382]Zero hot-spotting with any weaves, curved or otherwise because they have very uniform luminance.
Cheers,
Chris
Good to know, thanks guys.
post #1643 of 3450 Old 04-02-2012, 01:33 PM
BroncoSport's Avatar
I just received my sample from Chris (well a couple days ago) and put it up on the screen wall next to the Carada samples. I had my wife come down to sit in the estimated location of the front row and give me her thoughts. She thought the XD looked very similar to the Brilliant White from Carada but prefered the XD. I also asked her and I looked myself and at 9.5"....we couldn't see the weave at all. Note that this is just with a very bright shop light shining on it from behind.
The cool thing about this material is the feel. I was a little concerned about what I would be in store for if I used it for my DIY scope screen (have had the vinyl Carada screen samples for a while and they don't seem to be very sturdy), but having the sample in my hands assured me that this XD fabric WILL take tensioning quite well.
I also like how small the holes are and until you hold it up close, it is hard to see the holes.
Anyway, I will be starting my screen wall possibly tonight and soon Chris will be getting my order for screen fabric.
Thanks for promptly sending out the sample, Chris.
BroncoSport is offline
post #1644 of 3450 Old 04-02-2012, 07:04 PM
toref's Avatar
My EN4K screen material with mounting accessories arrived a couple of days ago. Seeing the beautiful fabric put a big smile on my face. Today I got it all mounted in my DIY frame construction. I'm excited to see it in action. I must say this is an amazing fabric. Testing it with the yet-to-be-worn-in Klipsch speakers behind the screen revealed only a very marginal attenuation of the treble. Nothing some calibration on the RX-A3010 cannot fix.
Despite some long weeks waiting I'm very happy about this choice. Now, if would just be able to decide on the projector...
toref is offline
post #1645 of 3450 Old 04-03-2012, 12:39 AM
adude's Avatar
Quoted: 50 Post(s)
How did you managed to get the EN4k material? I thought you have to buy it with the frame, not diy.
adude is offline
post #1646 of 3450 Old 04-03-2012, 12:43 AM
adude's Avatar
Quoted: 50 Post(s)
I have a question about backing to be used behind a screen. I read in another thread that if we use white backing behind AT screen, it helps with the screen gain. does that makes sense, instead of using black? I want to do approx 128" wide, 16:9 screen, so brightness is quite important for me.
Also, has anyone here used black muslin as the backing? It would be interesting to hear the experience.
adude is offline
post #1647 of 3450 Old 04-03-2012, 12:56 AM
toref's Avatar
SE has a DIY product called "Craftsman" which consists of the fabric, mounting profiles, the black backing and a particular tool to attach the fabrics to the profiles.
toref is offline
post #1648 of 3450 Old 04-03-2012, 04:54 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
The Craftsman product is EN4K
Larry M is offline
post #1649 of 3450 Old 04-03-2012, 05:28 AM
http://www.screenexcellence.com/products/craftsman.html
"The Craftsman is only for skilled installers"......
How skilled are we???
Chuck
post #1650 of 3450 Old 04-03-2012, 08:15 AM
adude's Avatar
Quoted: 50 Post(s)
Dang, and I just bought XD mateial last week. Oh well.
adude is offline
Reply Screens
Seymour Av
