The official SeymourAV center stage screen thread! - Page 93 - AVS Forum
 24Likes
post #2761 of 2777 Old 09-05-2014, 12:01 PM
R Harkness's Avatar
Quoted: 104 Post(s)
Liked: 325
Originally Posted by DavidK442 View Post
Two thumbs up for constant area. Not sure why more people don't go this route,
And since projectors (using zoom) allow you so much variation in image sizes, I'm sometimes amazed more people don't go even further to a Variable Image Size system. See links below my name.
Rich H
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
R Harkness is online now
post #2762 of 2777 Old 09-05-2014, 12:04 PM
Sonyad's Avatar
Quoted: 27 Post(s)
Liked: 30
Deromax, the links to the pictures in your thread are all broken.
Sonyad is offline
post #2763 of 2777 Old 09-05-2014, 05:34 PM
deromax's Avatar
I know! The first paragraph on the first post explains why!
deromax is offline
post #2764 of 2777 Old 09-05-2014, 07:46 PM
Sonyad's Avatar
Quoted: 27 Post(s)
Liked: 30
Oh, I missed that part. Anyway I found your pictures.
Sonyad is offline
post #2765 of 2777 Old 09-09-2014, 12:19 PM
greg1292's Avatar
Quoted: 17 Post(s)
Originally Posted by chriscmore View Post
Here's an unaltered screenshot of the new Matinee Black material. I've been enjoying working on these new materials over the past couple years, even though they're not AT. In my world, every home theater should be a dedicated, darkened, wall full of audio/video perfection (btw, looking forward to David's open "theater" tomorrow!), but also need to realize that not everyone can have true batcaves. There are ceilings that the boss won't allow to be painted, and windows that need stay open.
Cheers,
Chris
Chris is this screen free of artifacs,shimmering,noise in the image? And what is the lead time once the screen is ordered?
Thank Greg
 Specialize in maximizing performance on a beer budget!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
greg1292 is offline
post #2766 of 2777 Old 09-11-2014, 10:55 AM
mike_orst's Avatar
Any pictures of how the curved frames mounting brackets will work. I'm in the process of building a false wall which my screen will be attached to and want to make sure I won't have any issues when I order my screen in a couple weeks. (I've seen the fixed frame instructions, but doesn't talk about the curved options - http://seymourav.com/articles/Center...structions.pdf, or maybe its the same french-cleat option)
Mike
mike_orst is offline
post #2767 of 2777 Old 09-12-2014, 01:51 PM
brwsaw's Avatar
Quoted: 78 Post(s)
Liked: 77
Chris, is the XD material discontinued?
What was the rated attenuation? I've lost my notes.
2015 it is.
brwsaw is offline
post #2768 of 2777 Old 09-13-2014, 07:44 AM
jeffleonard's Avatar
Mike
I have a 150" curved 2.35 Seymour...the mounting cleat is a just a curved french cleat. Center cleat is about 24-30 inches...then there are 2 L brackets that attached at the bottom outside edges of the frame to keep screen locked in place. Super easy to install...sorry for no pics.
jeffleonard is offline
post #2769 of 2777 Old 09-13-2014, 09:00 AM
mike_orst's Avatar
So is the wall you mounted the frame to curved? Or does the back of french cleat go against a flat wall, but the actual cleat comes out of the wall and is curved to align with the screen frame? If you happen to have a picture maybe that would help me...
Mike
post #2770 of 2777 Old 09-15-2014, 01:16 PM
AVS Club Gold
chriscmore's Avatar
Liked: 39
No, the XD is still all over the site. The attenuation averages -1.4dB. Additional information is on the screens page: http://www.seymourav.com/screens.asp
Cheers,
Chris
Seymour AV
Seymour-Screen Excellence
chriscmore is offline
post #2771 of 2777 Old 09-15-2014, 01:19 PM
AVS Club Gold
chriscmore's Avatar
Liked: 39
Mike
You can do either. If you curve your wall or mounting surface to a 40' radius, then you can simply mount it to that by flexing the hanging brackets (smaller ones are recommended and they can be trimmed). If you mount it on a flat wall, it comes with a welded steel wall adapter bracket for the top center ~50" and two, adjustable L-brackets for the bottom corners.
Cheers,
Chris
Seymour AV
post #2772 of 2777 Old 09-16-2014, 10:27 AM
brwsaw's Avatar
Quoted: 78 Post(s)
Liked: 77
Cheers,
Chris
Thanks, I must be blind (looking in the wrong spot).
brwsaw is offline
post #2773 of 2777 Old 09-18-2014, 07:14 AM
Mike
The wall I mounted to is flat. The cleat is curved, the steel mounting strip mounts to a flat or curved wall. You don't need to do any special prep to your wall for a curved screen. I was planning for a normal "flat" screen during my build and decided to go with curved at the last minute.
No picture...I don't want to take the screen down. Trust me, you'll be fine.
post #2774 of 2777 Old Today, 01:55 AM
ripclawsa's Avatar
I apologise in advance if this isn't the right place to post these questions. Here goes:
  1. What's the price difference between SeymourAV screens and the Seymour Screen Excellence products?
  2. I see that one can order SeymourAV screens from their website. If I wanted a Seymour Screen Excellence screen, how do I order one?
  3. The Seymour Screen Excellence Absolute range looks excellent. Can someone please point me in the direction of pricing?
ripclawsa is offline
post #2775 of 2777 Old Today, 01:55 AM
ripclawsa's Avatar
post #2776 of 2777 Old Today, 06:58 PM
cgott42's Avatar
Quoted: 42 Post(s)
I'm looking to purchase a used 2.35 seymourav AT center stage screen, I sake the seller if it was the center stage XD and he said it's the original. was there an earlier version? How doe it differ?
Thx
cgott42 is offline
post #2777 of 2777 Old Today, 07:55 PM
DavidK442's Avatar
Quoted: 66 Post(s)
Liked: 78
Thx
Yes, the earlier version was just called "Center Stage". The material had a courser weave and I believe less gain.
Center Stage XD is the updated fabric, though it has been around for several years itself (5 or 6??)
I would pass on the used screen.
DavidK442 is online now
Reply Screens
Seymour Av
User Tag List
chriscmore
