What screen would you put in this room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-28-2007, 07:14 AM - Thread Starter
drunkpenguin's Avatar
Quoted: 1349 Post(s)
Liked: 1367
The room is 22x17 rectangular with a 10' ceiling. no windows. painted dark gray and black. I am looking at maybe buying the panasonic PT-AE1000U pj. What size screen and what type and brand would you suggest? I have 100% light control in this room so will just about anything work? I'd like to spend around 500 or less on a screen if possible. I just need the screen to mount to the wall, no roll ups or anything liek that.
thanks.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #2 of 7 Old 05-28-2007, 09:11 AM
bqmeister's Avatar
If you buy a commercial screen, rollups are usually cheaper, cost less to ship and are easier to setup (no setup required, just put up to screws and hang).
I keep my rollup screen down 98% of the time.
I too have a dedicated (pitch black room) and love my highpower. Yeah, it's bright, but I like it bright.
depending on your seating, I'd probably opt for 119", but I could see trying to go a bit bigger (126-135").
bqmeister is offline
post #3 of 7 Old 05-29-2007, 12:43 AM
robter's Avatar
What is Outdoor Theater?
robter is offline
post #4 of 7 Old 05-29-2007, 05:16 AM
bqmeister's Avatar
http://www.avsforum.com/avs-vb/forumdisplay.php?f=159
post #5 of 7 Old 05-31-2007, 05:18 PM - Thread Starter
Liked: 1367
Id really like a regular screen that I can attach to the wall. Any color recomendations or site recomendations? Id like to buy one soon.
post #6 of 7 Old 06-01-2007, 04:56 PM
richlo's Avatar
Check out the Carada screens (not sure of price) but also the Elite Cinetension screen
Rich L
Go Chicago Bears
richlo is offline
post #7 of 7 Old 06-03-2007, 02:44 PM
Pete's Avatar
Quoted: 238 Post(s)
Liked: 84
Stewart FireHawk G3 would be the best you could do with this projector. Not the cheapest, but the best.
Pete is offline
Reply Screens
