Cut to size da-lite fabric mounting - AVS Forum | Home Theater Discussions And Reviews
Old 10-25-2001, 01:09 PM - Thread Starter
theprophe's Avatar
im thinking of getting some hi-power fabric for my lt150, but want to make my own screen 92" how can you mount it to the frame? staples like normal fabric?
theprophe is offline
Old 10-25-2001, 11:02 PM
johann's Avatar
Some, including myself, have used window screen railings. I screwed mine to the front of my frame made of 1x3's. Then inserted the screen material in the railings with rubber spline just like you would do with window screen mesh. After the screen is "splined" in, covered the railings with trim.
johann is offline
