Recommended Screen Gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-01-2001, 04:37 AM - Thread Starter
edgartolerojr's Avatar
What is the recommended screen gain for DLP and LCD projector?
Any Idea?
Thanks in advance!!!
Best regards,
Edgar
edgartolerojr is offline
post #2 of 2 Old 11-01-2001, 07:00 AM
Blake Brubaker - Da-Lite's Avatar
Edgar,
The right screen gain depends on quite a few things. Obviously, the projector is one of the big items to consider, but the room configuration and lighting conditions are other factors. In order to help, simply answer a few questions:
1. What is the ANSI lumen output of the proposed projector?
2. (a) Do you have control of the ambient light in the room?
(b) If not does ambient light fall directly on the proposed screen location?
3. What is the seating configuration?
(also) How far back and wide is the first row of seats?
4. How large a screen are you contemplating?
With those bits of information, one can make a better informed decision when it comes to choosing a screen gain.
Hope this helps.
Blake Brubaker, CTS
Vice President of Sales
Da-Lite Screen Company, Inc.
Blake Brubaker - Da-Lite is offline
Closed Thread Screens
