Taking the Sony Dynaclear screen material and making and XScreen out of it... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-04-2007, 07:06 AM - Thread Starter
dssbuys's Avatar
I just purchased a Sony VPL-AW15 and Dynaclear screen for <$1k so I plan to do a little experimenting w/the screen.
The Dynaclear screen is 80" diagonal in a portable, pullup configuration. Not ideal for a "finished" home theater look.
I have read up on the Planar Xscreen which seems to be composed of a retro reflective screen material with a 4mm layer of glass on top. The Sony Dynaclear screen material seems to have very similar properties (20 degree half gain, dark gray appearance, retro-reflective). In my ignorance I am thinking about taking the Dynaclear screen material and mounting it in a frame (nice, professionally made metal picture frames can be purchased on the web for ~$80 for 70"x40" - the dimensions of the dyncaclear screen).
I haven't received anything yet, so plans may change once I set things up... My question (finally) is this: Does anyone have any knowledge/experience with what would be the best type of glass to put over this screen to minimize reflections and maximize the light transmittance?
I have looked at "glass", tempered glass, plexiglass, lexan, UV protective glass (for artwork), anti-reflective glass (also for artwork, pictures)... Any ideas?
Mike
dssbuys is offline
post #2 of 6 Old 10-07-2007, 01:21 PM
bootron's Avatar
look at some of the light fusion posts. i believe this idea was implemented and you can look at see what they were using.
bootron is offline
post #3 of 6 Old 10-07-2007, 02:04 PM
adumadu's Avatar
dssbuys,
I'm interested in buying the same Sony + Dynascreen combo. Can you please let me know where did you buy it.
adumadu is offline
post #4 of 6 Old 10-24-2007, 10:30 AM
pottscb's Avatar
Quoted: 142 Post(s)
Liked: 78
Originally Posted by adumadu View Post
dssbuys,
The big "C" warehouse has the combo for $1499...
pottscb is offline
post #5 of 6 Old 11-06-2007, 09:01 AM
tingshen's Avatar
so TS, did you manage to make a DIY Xscreen from the Dynaclear?
tingshen is offline
post #6 of 6 Old 02-15-2008, 09:35 AM
albert2090's Avatar
Check this link out, I think you can see the true protientail of the Dynaclear screen.
http://www.cine4home.de/Specials/Dyn...arEindruck.htm
albert2090 is offline
Reply Screens
