Draper Screen Size Recommendation for Sony 1251 - TIA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-14-2001, 10:32 PM - Thread Starter
Killer's Avatar
Hello all,
I currently have a 106" Draper M1300 16:9 Screen with a Sony 1251 and Pioneer DV-37 going to it in a complete light controlled basement. I'm going to add a HTPC in the not to distant future. My question is, I think I'm looking for a little more brightness, the images dont have the "pop" my old Elite Pro 610 had, granted I know they are different animals, but that was my reference before. Should I go to a smaller screen ( 92") or a higher gain material like the M2500? I'm also the kind that likes to sit close to the screen (as close as possible without turning my head). I will also upgrade the DVD output to a scaler a year or two down the road. and finally I'd say the FP is 75-80% tweaked, to my limits anyhow.
Opinions?
L8r,
Killer
Killer is offline
post #2 of 3 Old 11-15-2001, 07:30 AM
sgp
sgp's Avatar
Killer
do a search for m2500 in the screens forum, I was considering this material based on the large size of screen I needed but decided against it for two reasons, one the multiple reports of a visible streaking affect, and two it is not cleanable ( two kids ), so because I didn't want to spend the extra money for stewart, the highest gain I could find that was cleanable was the da-lite pearlescent fabric with a gain of 1.5
wish there were a reasonable priced 2.0 to 2.5 gain screen out there
Shawn
sgp is offline
post #3 of 3 Old 11-18-2001, 04:08 PM
Tom Rosback's Avatar
Killer,
I have an M2500 surface that will fit your frame, if you'd like to try it out.
JVC RS 500, Stewart 106" Studiotek 130
McIntosh MC 2301 x 3, MC 602
McIntosh MX 151, C500T, MCD 1100, Oppo BDP-95
Sonus Faber Amati Futura, Amati Homage Vox, Proac Response 1sc
Nottingham Dias TT, Ace Space Arm, Sumiko Palo Santos cartridge
Tom Rosback is offline
Closed Thread Screens
