Best screen to match NEC LT150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-16-2001, 06:19 PM - Thread Starter
Herman's Avatar
Any suggestions? I'm sitting about 11 feet away from the screen. What size would be appropriate? Name brand? Gain? Should I paint the wall black/gray or use a material?
Herman is offline
post #2 of 8 Old 11-19-2001, 09:30 AM
sinhas's Avatar
I have 72 by 96 Da-Lite Hi-Power and it works great
sinhas is offline
post #3 of 8 Old 11-19-2001, 09:42 AM
John Kotches's Avatar
I'm using a Stewart Greyhawk with fabulous results at about 10' on an 84" diagonal 4:3 aspect ration screen.
There will be lots of disagreement on which is best, with the camps split between the Dalite High Power and the Stewart Greyhawk.
Contributing Editor & Surround Music Reviewer Widescreen Review
Opinions are mine, not the publication I write for.
John Kotches is offline
post #4 of 8 Old 11-19-2001, 07:24 PM - Thread Starter
Herman's Avatar
Thank you all for the replies. So with the Dalite Highpower, I get better contrast and colors, but lose on the blacks. And on the Greyhawk I get much better blacks but lose on colors. Sounds like the Dalite might be better suited if I'm viewing with some ambient lighting? Ok. Now....should I go with a 4:3 screen or 16:9?....My sources are a panasonic rp56 prog dvd player and direct tv. I would say 80% DVD and %20 Satellite. Thanks again for the help guys. This is a great forum.
Herman is offline
post #5 of 8 Old 11-19-2001, 11:16 PM
MrWigggles's Avatar
Unless you have an anamorphic lens you need to do a 4:3 screen with the LT150.
I think both screens have their merits.
The Gray hawk is well designed for the smaller (<100") screens in a ceiling projection set-up.
While the Da-lite Hi-power (IMO) is THE screen to use for tabletop set-ups due to its retro-reflective nature.
-Mr. Wigggles
The Mothership is now boarding.
MrWigggles is offline
post #6 of 8 Old 11-20-2001, 09:42 AM
Dammit Mr. Wiggles,
Stop being objective and rational, this is no place for that ;)
post #7 of 8 Old 11-20-2001, 01:18 PM - Thread Starter
Herman's Avatar
Where can I get an anamorphic lense for the NEC LT150? Thank you for all the replies.
Herman is offline
post #8 of 8 Old 11-21-2001, 05:42 AM
Wireless's Avatar
Check with Jason here at AVS for the ISCO II
Wireless is offline
Closed Thread Screens
