Black Diamond from Screen Innovations? - Page 124 - AVS Forum
 9Likes
post #3691 of 3700 Old 09-29-2014, 08:15 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 487 Post(s)
Liked: 469
Originally Posted by gonzalc3 View Post
How does the pure white 1.3 screen compares to the stewart studiotek130?
Chris
Stewart is a little bit smoother. Not talking a huge difference here.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is offline
post #3692 of 3700 Old 09-29-2014, 07:31 PM
Liked: 0
Hi all,
I am new to the forum but certainly would appreciate help with your input as I build my home theater. I have decided on an Epson 5030 projector and considering a slate Screen Innovation screen, 110". Although it will primarily be a movie theater room with light control, I would also like to use for watching football games with some lights on as well. Does anyone have experience with this screen or other suggestions? Also, if you have your choice of AT (not this screen) or not, what would you choose?
ewshook is offline
post #3693 of 3700 Old 09-29-2014, 07:36 PM
deewan's Avatar
Quoted: 24 Post(s)
Liked: 62
Originally Posted by ewshook View Post
Hi all,
I have the SI Pure Gray in a light controlled room. I can't recommend it enough. It is insanely good! IMO with a light controlled room you don't need to worry about the slate or black diamond features.
deewan is offline
post #3694 of 3700 Old 09-30-2014, 09:29 AM
AVS Club Gold
Quoted: 487 Post(s)
Liked: 469
Hi all,
In a light controlled room, I generally would go with a white screen. Gray will help with black levels, but would need to size screen and projector to work with the room. Give us a call and we can discuss what would work well for you and provide pricing.
Ftoast likes this.
post #3695 of 3700 Old 09-30-2014, 03:45 PM
Liked: 2
I received a few PMs for the DIY LEDs. Here's what I did.
I bought the HitLights IP-65 kit from Newegg:
*link blocked*
and the 5M extension:
*link blocked*
The kit includes the AC transformer, IR receiver, and remote.
It's important to buy the outdoor, IP-65s because their backing is stronger and they're a bit wider, so the press fit into the zero edge's channel. I learned the hard way by starting with the indoor.
I started the strip under the SI logo at the bottom of the screen. The transformer will hide in the rails behind the screen. I mounted the IR receiver just above the SI logo. The receiver is not visible, and it likely works for me because my walls are white. Black walls may need to hang it a bit lower.
Simply press fit the strip all the way around. Total cost: About $60.
(The pictures show my strip started on the left side of the screen.. this is when I transitioned from the indoor to outdoor strips. Half were indoor, half outdoor. The pictures show the outdoor strips only. The LEDs are also on their dimmest setting)
** I don't have enough posts, so I cannot post links. Awesome.**
ID:	288385   Click image for larger version
ID:	288393   Click image for larger version
ID:	288401   Click image for larger version
ID:	288409   Click image for larger version
Sebastian1029 and Ftoast like this.
Law Jolla is offline
post #3696 of 3700 Old 10-01-2014, 07:40 AM
AVS Club Gold
Quoted: 487 Post(s)
Liked: 469
Nice job on the speakers.
post #3697 of 3700 Old 10-01-2014, 03:39 PM
deewan's Avatar
Quoted: 24 Post(s)
Liked: 62
Thanks..They turned out exactly as I wanted them too. But now I have another idea for a cabinet design so I have the speakers up for sale. This hobby never ends.
deewan is offline
post #3698 of 3700 Old 10-03-2014, 10:59 AM
AVS Club Gold
Quoted: 487 Post(s)
Liked: 469
The Black Diamond fixed and Zero Edge screens are now available in sizes up to 150". Call us for details and pricing.
post #3699 of 3700 Old 10-12-2014, 06:35 PM
ConradC's Avatar
Trade-ins?
ConradC is offline
post #3700 of 3700 Old 10-17-2014, 07:47 AM
AVS Club Gold
Quoted: 487 Post(s)
Liked: 469
Originally Posted by ConradC View Post
Trade-ins?
Just a reminder. SI's price increase goes into effect, end of the month.
Reply Screens
Projection Screens , Pure Acoustics Supernova C 250 Watt Center Speaker , Speaker Systems , Screen Innovations
User Tag List
