Positioning Speakers Behind Stewart Microperf Screens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-18-2001, 08:39 AM - Thread Starter
Scott B's Avatar
Quoted: 32 Post(s)
How close should speakers be positioned to the screen material? I would assume that they should be as close as possible (1-2 inches) but would like to confirm this.
Scott B is offline
post #2 of 5 Old 11-19-2001, 10:52 AM
randmac's Avatar
Try to get at least 4" inches between the screen and the tweeter. There is diminishing improvement beyond 12".
I have 5 1/2" between and can't tell the difference between the screen up and down.
randmac is offline
post #3 of 5 Old 11-19-2001, 09:37 PM
keithsimp's Avatar
Randy,
Are you using the equalizer that comes with the screen? I was told it does not make that much of a difference.
Keith S.
keithsimp is offline
post #4 of 5 Old 11-20-2001, 10:20 AM
randmac's Avatar
Originally posted by keithsimp
Randy,
I do use the Stewart-EQ, and I agree with what you've been told, it does not make much difference (it doesn't have to...microperf is very acoustically transparent). I just don't want any trouble with the THX police:)
randmac is offline
post #5 of 5 Old 11-20-2001, 10:28 AM - Thread Starter
Scott B's Avatar
Quoted: 32 Post(s)
I should be able to get 6-8" between the screen and the center channel speaker. This sounds like it should work fine.
Scott B is offline
Closed Thread Screens
