Dalite High Power vs Matte for ceiling mounted CRT fps? - AVS Forum | Home Theater Discussions And Reviews
Old 11-19-2001, 12:17 PM - Thread Starter
RobertWood's Avatar
I have a Dalite model B High Power. I have been using it with my
table mounted CRT projector. I am about to ceiling mount my projector. In this configuration will the High Power give me at least the reflectivity of an ordinary matte screen material? Or will I have even less brightness than with a matte screen? I'm asking because if the two will be comparable there's not much sense in my purchasing a matte screen to replace the HP.
Bob Wood
RobertWood is offline
Old 11-19-2001, 02:51 PM
dinode's Avatar
It is my understanding (and I have eyeballed this) that the HP has a gain of about 2.8 with a floor mount setup and about 1.3 to 1.6 with a ceiling mount. It's probably not worth replacing with the Matt white. I would give it a try.
dinode is offline
Old 11-19-2001, 05:11 PM - Thread Starter
RobertWood's Avatar
Thaks, dinode. I will.
Bob
Old 11-19-2001, 10:59 PM
Robert Clark's Avatar
Quoted: 49 Post(s)
Liked: 47
I would agree with dinode here Bob. I have a Dalite beaded screen with a high gain and have used it both with a ceiling mounted CRT and a ceiling mounted DLP. Though you do lose gain with a ceiling mount on a high reflective screen, it's still more than a matte white screen...
Robert Clark
Robert Clark is offline
