screen material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-20-2001, 03:48 PM - Thread Starter
mebaker's Avatar
Greetings all! I've been looking around and getting some ideas for cheap alternative screen materials.
I have a very limited budget which does not include
a 2 to 3 hundred dollar screen. So if you have some time, I would greatly appreciate getting some of your cheap alternatives. Thanks, Mark.
P.S. Happy to be on board!
mebaker is offline
post #2 of 6 Old 11-20-2001, 06:08 PM
jkaiser's Avatar
So you want to go cheap...
Do a search for DYI screens - as in Do It Yourself.
You should find lots of information.
Topics include
1. Painting the wall white or light grey
2. Dry Wall screens
3. Wall board screens
4. Blackout Cloth (My personal choice since I need 81" x 61")
Failure is not an option. It comes bundled with every Microsoft product
jkaiser is offline
post #3 of 6 Old 11-20-2001, 11:55 PM - Thread Starter
mebaker's Avatar
thanks J:)
mebaker is offline
post #4 of 6 Old 11-22-2001, 04:29 AM
Central Scrutinizer
Bob Sorel's Avatar
Quoted: 191 Post(s)
Liked: 149
I assume that you see that DIY was accidentally and incorrectly written as DYI, although DYI could be a Freudian slip (Do Yourself In)....hehe.
Nothing is what I want - a true Zen saying.
Marantz AV7005 pre/pro cheap
Bob Sorel is offline
post #5 of 6 Old 11-22-2001, 06:00 PM
Ron Geyer's Avatar
I made a screen using a 4 x 8 sheet of 1/16" white plastic material I found a Lowe"s Home Store. I posted information on this and a picture. Check-it-out. (High Quality Screen at a very low cost) This is brighter, with now hot spots than those you can purchase for $1000.00 up.
If interested I can give you more details.
Ron Geyer
Ron Geyer is offline
post #6 of 6 Old 11-23-2001, 08:26 AM - Thread Starter
mebaker's Avatar
Ron, I found some plastic material but it had line going through it. But I did fined some blackout choth, so i'm going to give that a try.
Thanks, Mark. :)
mebaker is offline
Closed Thread Screens
