fixed frame highgain screens having 150"+ size?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-24-2007, 10:28 AM - Thread Starter
ashit's Avatar
i am looking for a high gain screen like highpower from da-lite but am not able to get a fixed frame screen of dimensions more than 150", the max i get is 133".
could anybody please tell whether there are any types of highpower or highgain fixed frame screens having dimensions 150"+
ashit is offline
post #2 of 4 Old 11-24-2007, 12:04 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Elite EZ Frame screens are available up to 159" and their new Powergain screen material has a gain of 1.8 (not as high as the Dalite Highpower, but a larger viewing cone and more flexibility in the projector, screen and viewer geometry.
http://www.elitescreens.com/product_ezframe.htm
http://www.elitescreens.com/pdf/elit...e_v_5.15.7.pdf
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #3 of 4 Old 11-25-2007, 07:14 AM
Tryg's Avatar
I've sold some Da Lite Cinema Contour screens that were 14' x 6' with the High Power fabric. So the answer is yes.
Any company will build you the screen you want.
Tryg is offline
post #4 of 4 Old 11-25-2007, 09:27 AM
hrd
hrd's Avatar
Da-Lite will make a custom size larger than 133" diagonal, including in their 159" diagonal size. One caveat is the High-Power fabric is seamless only up to 72" high, so that if you really want your screen seamless you would max out at 147" diagonal for a pull-down or electric screen, and less than that for a fixed frame, due to some of that 147" of fabric being blocked by the surrounding fixed frame. You can custom-order one over 150" easily enough, you just have to accept one with a seam. Someone here posted he did that and did not even notice the seam.
hrd is offline
Reply Screens
