blackout cloth - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-23-2001, 08:19 AM - Thread Starter
mebaker's Avatar
I bought some blackout cloth with white on both
sides, which side would give me a higher gain. I haven't received my projector yet and want to get to work on something. So I'm building my screen. Any ideas?
thanks, Mark.
mebaker is offline
post #2 of 3 Old 11-23-2001, 07:01 PM
Andrew Y's Avatar
Mark, I'm not sure what side of your fabric would provides the highest gain -- the brand of blackout fabric I purchased also had two white sides, however, one side was smooth and "vinyl like" and the other side was more textured "fabric like"...anyways I tested both sides and ended up with the smoother side.
You might want to wait until your projector arrives before attaching the fabric to your frame. Test out both sides in different lighting conditions and from different seating postiions. Pick the side that gives you the best perceived picture.
Best of luck with your setup!
Drew
Andrew Y is offline
post #3 of 3 Old 11-23-2001, 11:40 PM - Thread Starter
mebaker's Avatar
Thanks, Drew. Much appreciated.
mebaker is offline
Closed Thread Screens
