Please help me choose a pull-down screen for use with my CRT projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-28-2001, 12:00 PM - Thread Starter
RobertWood's Avatar
I'm going to purchase a pull-down non-tensioned screen (92" wide) to use with my ceiling mounted CRT projector. I have narrowed my choice down to one of these...
1. Draper Luma with the "fiberglass matte white'' screen material
2. Dalite Model B with the "matte white" 1.1 gain material
3. Dalite Model B with the "Video Spectra" 1.5 gain material.
Before I order can you give me an opinon of how the Draper Luma
screen case compares to the Dalite Model B? Is one better than the other?
Do you have a preference between the Draper matte screen material and the Dalite matte screen?
Do you think I would be better off with the higher gain Dalite "Video Spectra" material.
Bob Wood
RobertWood is offline
Closed Thread Screens
