MicroPerf Stwart Screen - What distance from speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-28-2001, 05:16 PM - Thread Starter
flavioleoni's Avatar
I've just received my Sharp 9000 and now, after reading some threads here at AVS, I'm going to get the screen. I'm going with the Stwart GrayHawk (as recommended by Mr. Stwart himself). I would like to go with the MicroPerf and place the center speaker (or even all the front speakers) behind the screen.
What is the minimum distance that the speaker should have from the screen? Is it supposed to be right behind the screen ("touching it") or is there a minimun space that should be kept between them in order not to loose sound quality?
I looked for such information on Stwarts web page but couldn't find it.
flavioleoni is offline
post #2 of 4 Old 11-30-2001, 12:06 AM
REW
REW's Avatar
try it and place where it sounds best.
Methinks 3 people believe you have already lost.:) :)
Ron
"Your priorities will be different-its the weighting that counts!-only if its done by FET!"
REW is offline
post #3 of 4 Old 11-30-2001, 05:15 AM
jkv
jkv's Avatar
The front of my center is about 4" behind the screen (if I remember correctly). I did remove the front cover (grill cloth) before I set it back there. The screen (Stewart) came with a equalizer for the center, but I never used it. Sound from my center is crisp and I am quite happy with it.
Riverside Cinemas
jkv is offline
post #4 of 4 Old 11-30-2001, 10:24 AM
Minman's Avatar
I have the exact same setup you are going to have Sharp 9000 and Stewart Micoperf Greyhawk. All 3 of my speaker are behind the screen and the set about 3 to 4" inches back from the screen. I also didn't use the supplied equalizer because to my ears anyway the sound is fantastic.
Minman is offline
Closed Thread Screens
