9000 Screen Trigger Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-30-2001, 09:24 PM - Thread Starter
Bill d's Avatar
Screen trigger issue
I also have the 9000 and have my Da-Lite screen connected to the 9000 trigger.
I had the same screen connected to a Sharp UV96 LCD and it worked just fine.
When I turn off the 9000, the screen ascents fine, then when I turn off the projector the screen ascends ok. When the fan stops after cooling the projector, the screen descends about one inch the rises again into the casing.
Does any one out there know what might be causing this.
Thanks in advance for your help.
Bill d.
:confused:
Bill d
"Strength & Honor"
Bill d is offline
post #2 of 6 Old 12-14-2001, 08:43 PM - Thread Starter
Bill d's Avatar
BUMP!!!
Bill d
"Strength & Honor"
Bill d is offline
post #3 of 6 Old 12-15-2001, 12:57 PM
Jacksquat's Avatar
I have a 9000 with a 12v screen trigger to a stewart. Do not have your problem during bulb cooldown. At first I suspected the PJ since it's the source of the DC but since the screen worked fine with another PJ, I'm stumped. Sorry. Gary
Jacksquat is offline
post #4 of 6 Old 12-15-2001, 01:06 PM
Steven's Avatar
I have the same problem. I'm running a Stewart screen and after I turn the projector off the screen goes up no problem however after the fan shuts off the screen drops about 3-inches and goes right back up. Kind of weird. I thought might be the trigger on the Stewart but maybe it's the Sharp.
Steven is offline
post #5 of 6 Old 12-15-2001, 09:18 PM - Thread Starter
Bill d's Avatar
Sounds like the issue is with the projector.
If anyone has further suggestions on what or how I can correct this issue... I am all ears.
By the way, my screen drops about 1 inch then goes back up>
Bill d.
Bill d
"Strength & Honor"
Bill d is offline
post #6 of 6 Old 12-16-2001, 07:58 PM
Jacksquat's Avatar
I double checked my screen trigger because I'm out of the room by the time the cooling fan switches off. When I hung around, and the fan switched off there was no problem with the screen whatsoever. I think it's PJ related too. Good luck. Gary
Closed Thread Screens
