What's the deal with glass beaded screens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-04-2001, 09:21 AM - Thread Starter
dinode's Avatar
I've seen a lot of these for sale for pretty good prices. They claim a gain of 2.5. What are the advantages/disadvantages of using this material with a DLP projector.
dinode is offline
post #2 of 10 Old 12-04-2001, 10:29 AM
RBRAGA's Avatar
I'm deciding about the da-lite High Power. I need it to be fixed HDTV format 58" x 104. My projector is an LT150. Does anybody have a cheap source solution?
Rodrigo Braga
RBRAGA is offline
post #3 of 10 Old 12-04-2001, 03:42 PM
RBRAGA's Avatar
I'm learning towards shopcousinsvideo.com for the high power screen and then diy my own frame. Does any body have tryied this approach? How hard is to work with their High Power material? I've heard that it does not stretch! Please help!
Rodrigo Braga
RBRAGA is offline
post #4 of 10 Old 12-05-2001, 06:34 AM
Grant Smyth's Avatar
Rodrigo,
I removed the Hi-power screen material from the pulldown mechanism and tacked it flat to my wall. You should be able to build a wooden frame for it and tack (thumb tack) it to the frame without a problem.
Cheers,
Grant
Grant Smyth is offline
post #5 of 10 Old 12-05-2001, 02:24 PM
JonnyBravo's Avatar
I purchased the Da-mat High Contrast from cousins and made my own frame. Saved serious money and it came out awesome. Stretched out the fabric over a wood frame and stapled it to the frame.
JonnyBravo is offline
post #6 of 10 Old 12-06-2001, 09:00 PM
MrWigggles's Avatar
If you are going to go glass beaded the only screen worth considering is the Da-Lite hi-power which uses microscopic beads.
All other glass beaded screen are not suitable for anything shy of 20' wide. The beads are just too big and cause sparkles.
-Mr. Wigggles
PS. I bought one of my screens from Jason here at AVS - very helpful.
The Mothership is now boarding.
MrWigggles is offline
post #7 of 10 Old 12-06-2001, 10:46 PM
Robert Clark's Avatar
Quoted: 49 Post(s)
Liked: 47
But unless I'm multiplying wrong, the bare screen material is more expensive than the same with a manual pull down screen Model B?
Robert Clark
Robert Clark is offline
post #8 of 10 Old 12-07-2001, 06:03 AM
KBK
KBK's Avatar
That's my understanding. it's cheaper to buy the finished screen and pul the fabric off.
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
post #9 of 10 Old 12-08-2001, 05:59 AM
Novanus's Avatar
DaMat High Contrast is not available in pulldown -- perm wall or tensioned only.
novanus@hotmail.com
Sanyo XW15 MiniFAQ
Novanus is offline
post #10 of 10 Old 12-14-2001, 01:33 PM
JonnyBravo's Avatar
I picked the fabric up from Cousins Video when it came out... only $3.00 a sq/ft. 60" x 80" = $90. Frame Home Depot @$7. Great screen for under $100.
Closed Thread Screens
