What model Stewart screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-04-2001, 07:28 PM - Thread Starter
AnthonyS's Avatar
I am looking for an electric roll up Stewart screen for a 16:9 DLP projector. I plan on using the GreyHawk material. I saw a DLP on a fixed 100" Greyhawk fixed screen 16:9, and (it looked great)I have 2 basic questions.
1.) Do Stewart rollup screens compare in performance to the fixed ones?
2.) I need to wall mount the screen (12' ceiling height)and I want to have a custom valence built around the thing which holds the screen to match my in-wall bookshelves. What model am I looking for?
Thanks in advance
:confused:
AnthonyS is offline
post #2 of 8 Old 12-05-2001, 08:46 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
The Luxus SR-1 Electriscreen is designed for exposed mounting although others may work based upon your application. There are alot of options with these screens other than fabric. These would include the drop, black matting area, type of control, etc. You really need to work with a Stewart Dealer to get the right configuration for your particular requirements.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #3 of 8 Old 12-05-2001, 11:15 AM - Thread Starter
AnthonyS's Avatar
Any thoughts on performance as compared to a fixed model?
AnthonyS is offline
post #4 of 8 Old 12-05-2001, 04:35 PM
Quoted: 64 Post(s)
Liked: 100
They are made of exactly the same screen material.
post #5 of 8 Old 12-05-2001, 07:26 PM - Thread Starter
AnthonyS's Avatar
I'll try to be a little clearer. I was wondering do they maintain a straight and rigid form when down. You know how a fixed screen is never rolled up so it is always straight and flat. I was just wondering if the screens maintain their form as well as a fixed screen. Or do the edges curl? They are a lot of money so I was hoping someone had some experience with them and could report any drawbacks.
AnthonyS is offline
post #6 of 8 Old 12-05-2001, 07:42 PM
Jacksquat's Avatar
You don't have to worry about edges curling, etc. with electriscreen stewart screens. They are very high quality. My recessed Greyhawk is beautiful with my DLP.
Jacksquat is offline
post #7 of 8 Old 12-05-2001, 09:16 PM
scottyb's Avatar
Quoted: 18 Post(s)
Anthony, The pull down screens are tab tensioned and the electric ones have some sort of tensioning. They are GREAT screens. Contact Jason here at AVS for answer to your questions and also for a GREAT price on Stewart screens. You will be happy you spent the extra $ on this quality!!!
Scott
scottyb is offline
post #8 of 8 Old 12-06-2001, 10:09 PM
KFung's Avatar
I believe the electric screens are also tab-tensioned. You should not have any wrinkling/waving problems.
Kam Fung
KFung is offline
Closed Thread Screens
