I need a quick cheap 107x60 DIY Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-13-2001, 05:49 PM - Thread Starter
Cain's Avatar
Quoted: 333 Post(s)
Liked: 182
I want a quick, fast, easy DIY screen 107 wide by 60 tall to test out my projector mounting location, and check sight lines, throw angle, etc.
Then I will decide what size Stewart screen I will purchase.
I'd be happy with a sheet, or something I can hang.
Any ideas folks??
Thx in advance,
-- Cain
Cain is offline
post #2 of 3 Old 12-14-2001, 11:58 PM
jkaiser's Avatar
I've been using a painters drop cloth from home depot, about $12 (144" x 108"). I think it is actually some form of the infamous blackout cloth (rubberized on one side). Mine had seams, of which I could get a 56 X 108 seamless section. If yours is just temporary, seams might be ok.
After you are done with the test, you can still use it as a drop cloth. I marked mine up with a sharpie pen to get the dimensions, but who cares after you spill a little paint on it.
Failure is not an option. It comes bundled with every Microsoft product
jkaiser is offline
post #3 of 3 Old 12-15-2001, 12:05 AM - Thread Starter
Cain's Avatar
Quoted: 333 Post(s)
Liked: 182
That sounds good to me.
Thx for the reply, I'll check this out.
-- Cain
Cain is offline
Closed Thread Screens
