AVS APL Study - Adjunct to AVS Contrast Project - Page 3 - AVS | Home Theater Discussions And Reviews
Old 07-21-2008, 01:49 PM - Thread Starter
stanger89's Avatar
Quoted: 511 Post(s)
Liked: 268
Originally Posted by tstites View Post
Seems to me that trying to arrive at some sort of function to evaluate how a unit will perform in a real environment is not going to be practical without modeling the entire visual environment.
FWIW, that wasn't my intent with this (and I doubt it was Mark's with his thread). The purpose was to gain a greater understanding of where real world content falls in terms of ADL. Since we've been gaining a greater understanding of how projectors perform across the Luminance range (thanks to Mark's efforts), it seemed appropriate that we should try to better understand where real world content falls on that "curve".
Oh, and I'll be off for a drive as soon as I tweak my front fender so I can turn again
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is offline
Old 07-22-2008, 09:10 AM
AVS Club Gold
Mark Petersen's Avatar
Mark,
I also do a lot of Dual Sport riding...have an '06 DRZ400S...some great trails and forest service roads all over N.Ga, E.Tn and W.Nc.
Fun Most of the riding out this way is desert and mountains. If you're out this way in the winter time drop me a line and I can show you some really interesting desert rides.
No, I don't think it's that far out there, just that with front projectors, they are part of a "system" that consists of the projector, screen and the room. Unless you are in a totally light absorbtive room, every room will give you a different response in terms measureable or perceived CR vs APL. The point at which a higher ANSI CR rating becomes imperceptible, and therefore irrelevant, in various rooms is going to be all over the map.
Seems to me that trying to arrive at some sort of function to evaluate how a unit will perform in a real environment is not going to be practical without modeling the entire visual environment. Not at all unlike the complexity of the acoustic modeling I used to do when designing commercial sound reinforcement systems for theaters and such.
It's very true that room effects play a huge role. When I first started the AVS contrast project the idea was to have two parts. The first part would measure projector performance and the second part would use screen measurements to see how various rooms also played a role. Ric (Lovingdvd) had started a thread along those lines where many people measured ANSI at the screen and some experimented with different room treatments to see how it affected their ANSI readings. Unfortunately the whole idea was a little too grandiose and it ended up being about a full time job just to capture some insights into projector performance.
Even still though I think both of these threads (the original thread and this adjunct) provide some useful information. As an example, most people agree that the room plays a huge role in final (screen) ANSI performance and less of a role in on/off. But what does this mean to the majority of scenes that people watch in their HT? Is the luminance generated from a ANSI pattern typical of most scenes or is it rare? What's the average luminance for typical movies and in dark scenes what is the norm? That's what this thread discussion is about. Armed with that information it's easier to relate projector performance and also room effects.
It's an interesting state of affairs that we have two measures of contrast (on/off and ANSI) and neither are particularly good at measuring contrast in the range of luminance for the vast majority of images that most people use. As stranger89 has mentioned these two threads help supply some information about the in between range. I realize that this sort of discussion isn't for everyone though
Mark Petersen is offline
Old 08-21-2008, 09:23 AM
Stereodude's Avatar
Quoted: 1154 Post(s)
Liked: 821
Isn't there a big fat problem in your AVIsynth script?
Shouldn't you be using the Decomb filter (telecide and decimate) to turn the interlaced footage back into the progressive frames with a real 24FPS frame rate? Also, why are you sampling only once per second, and cropping of the black bars? Unless you're doing this for a CIH setup the black bars are part of the image that the projectors use for DI calculations.
Stereodude is offline
Old 08-17-2009, 10:50 AM
poynton's Avatar
Ok, this is a few years late, but ...
APL, as the term is used by a video engineer, stands for average picture level, and refers to the mean of the Y' component (luma) component across the image area of a frame (or sequence, or movie, or whatever).
Average luminance - more correctly, average relative luminance - is the mean of the true CIE linear-light luminance across the image area of a frame or sequence, relative to reference white luminance.
The math that relates the two isn't simple, and it can't be done at all absent all three components R', G', and B' or Y', CB, and CR. Apart from the special case where R', G', and B' are all equal to either zero or one - notably, 100% colour bars - APL and average luminance differ, and sometimes dramatically.
At a display, video R', G', and B' signals (for our purposes, scaled to 0=reference black and 1=reference white) are each raised to a power of between 2.0 and 2.5 to yield linear-light RGB components that are directly related to luminance. That act maps 0.5 on the video scale to about 0.18 in relative luminance.
So: Don't mix up the two!
The APL of broadcast video is very roughly 50%; its average luminance is very roughly 18%.
The average luminance of a movie as presented in the cinema - and not necessarily a dark movie - is roughly 10%. I have this on extremely good authority, from a studio/DI guy who has access to DCI movie data and ran some perl scripts. (Sorry, I know that's gross, but he's an old awk/sed/grep kind of guy.)
The average luminance of a movie as transferred to DVD or Blu-ray is up for discussion, but I'd make a guess somewhere between 10% and 18%, say 14%.
- Charles
Charles Poynton
www.poynton.com
[author of "Digital Video and HD Algorithms and Interfaces," Second edition (2012) - if that sounds scary to you, don't read it!]
poynton is offline
Old 08-17-2009, 11:19 AM
darinp2's Avatar
Quoted: 158 Post(s)
Liked: 127
Hi Charles,
Just want to say thanks for the information and nice to see you post. I talked to you for a while a couple of months ago about some different things (like how things are setup for mastering) and appreciate your time.
As far as this:
I've been wondering whether any of the stuff that is ending up on Blu-ray has had all of its gamma related stuff (not counting bit depth changes or color gamut type changes) done for DCI and then not get adjusted for Blu-ray. That is, aimed more for 2.6 display gamma (you can correct me if I have that wrong for DCI), and this could impact the average luminance. It seems to me that if DCI content is converted to Blu-ray in a way that takes the different gammas into account then the average luminances should end up in the same ballpark on playback, although I haven't thought about it too deeply.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is online now
Old 04-11-2015, 08:02 AM - Thread Starter
stanger89's Avatar
Quoted: 511 Post(s)
Liked: 268
Darin,
Here's the analysis for The Dark Knight (Blu-ray source), same method as before. As you can see, TDK is pretty dark, 80% of frames are blow 10% Average Display Luminance.
Range Number Percent
100.00% 2035 0.95%
50.00% 1364 0.64%
40.00% 4535 2.12%
30.00% 10350 4.85%
20.00% 27719 12.98%
10.00% 36877 17.27%
5.00% 56623 26.51%
2.00% 31345 14.68%
1.00% 18099 8.47%
0.50% 17529 8.21%
0.20% 7084 3.32%
0.10% 6787 3.18%
Name:	The Dark Knight.png
Old 04-11-2015, 01:20 PM
darinp2's Avatar
Quoted: 158 Post(s)
Liked: 127
Thanks stanger89,
I appreciate it. It is interesting to consider that as dark as this one measured, it would be even darker overall on a 16:9 screen.
For those who just want to use ANSI CR to evaluate things like this I think it is interesting that less than 1% of the images measured brighter than the ANSI checkerboards and over 1/3rd of the frame called for less than 1/25th as much light as the ANSI checkerboards.
There is a question I've asked some industry professionals and I don't think any of them have actually answered it. I'm sure there are professionals who could, but it seems like the question gets avoided by the ones I've asked (ones making certain claims or being parts of a group making certain claims). I wonder if I'm being unreasonable to expect people who are considered contrast ratios experts by many to be able to answer a question like this and whether there are people here who could provide reasonable answers.
Here is an example (with an assumption of no dynamic iris or similar system and reasonable things not mentioned being equal, like reasonable calibrations):
1. A reference image from a popular movie is encoded to have an Average Display Luminance (ADL) of about 1%. There are 2 different front projector systems that will display this image and are equal except for their system contrast ratios. System A has a system ANSI CR of 20:1 and a system sequential (on/off) CR of 1000:1. System B has a system ANSI CR of 80:1 and a system sequential (on/off) CR of 250:1. Which system is likely to do a better job of retaining detail to human vision with this image and these conditions?
If that question is one that should be difficult for people who are claimed to be contrast ratio experts then I guess it would be better to know now.
If anybody wants any clarifications I could provide some. For instance, I think it is fine to assume that system ANSI CR is low mostly due to the room in this case and not because somebody put a glob of Vaseline on one of the projector lenses.
Darin
Old 04-12-2015, 02:24 AM
Soulnight's Avatar
Quoted: 31 Post(s)
Liked: 26
Are they really just 2 movie analysis available for the Adl (batman and Indiana Jones )?
It would be great to see more and for brighter movies or cartoons (pixar/disney).
Thank you for any input! :-)
Soulnight is online now
Old 04-12-2015, 07:25 AM - Thread Starter
stanger89's Avatar
Quoted: 511 Post(s)
Liked: 268
You can always do some yourself, there's "instructions" on the first page
Old 04-12-2015, 09:01 AM
darinp2's Avatar
Quoted: 158 Post(s)
Liked: 127
I'm going to change my question slightly:
1. A reference image from a popular movie is encoded to have an Average Display Luminance (ADL) of about 1%. There are 2 different front projector systems that will display this image and are equal except for their system contrast ratios. System A has a system ANSI CR of 20:1 and a system sequential (on/off) CR of 1000:1. System B has a system ANSI CR of 80:1 and a system sequential (on/off) CR of 250:1. Which system is likely to provide more intra-image CR for this 1% ADL image?
--Darin
Old 04-12-2015, 01:27 PM
Soulnight's Avatar
Quoted: 31 Post(s)
Liked: 26
I forgot to thank you for your work: so thank you very much!
I would love to do it myself... however I only possess blu-ray and not have an HTPC or even a computer with a blu-ray player. So I guess I can't do it myself.
But if others could do it, it would be great!
