AVS APL Study - Adjunct to AVS Contrast Project - Page 4 - AVS | Home Theater Discussions And Reviews
 10Likes
post #91 of 115 Old 05-16-2015, 12:04 PM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
Originally Posted by Soulnight View Post
But the tutorial above is not enough for me. Could someone detail the steps for someone who has never used any of this software?
Great to see that you want to do this too. I just got this setup last weekend, but sorry that I didn't keep track of the steps I had to take. You may have figured it out by now, but one important step I recall finding in a thread here about this (probably the original CR thread stanger89 was referring to) was that I had to put DGDecode.dll from DGIndex in \Program Files (x86)\AviSynth 2.5\plugins.
Does it only work with vob files? (dvd?)
How do you proceed with blu-ray/m2ts/mkv files?
The above does only work with DVD level. My goal today was to get this working for HD. I found DGAVCIndexNV, but not sure if that version will work on my PC. When I went to try it a few days ago I got an error that I needed to download some more stuff from a DG toolkit, which I plan to look into today.
Since the first tools were limited to DVD I got "Any Video Converter" to convert HD files to mpeg2. I remember that my virus scanner caught something trying to download an ad program and I think it might have been this one, but I'm not sure. In any case, I would prefer to analyze the original instead of converting first, so hopefully can get this process working for HD files.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is online now
post #92 of 115 Old 05-16-2015, 12:37 PM - Thread Starter
stanger89's Avatar
Quoted: 571 Post(s)
Liked: 294
For HD, there are a few options. For AVC there's:
http://www.digital-digest.com/software/DGAVCDec.html
ffmpeg source can load just about anything:
http://avisynth.nl/index.php/FFmpegSource
The easiest way may be StaxRip:
http://staxmedia.sourceforge.net/
It includes all the source plugins you're likely to need, and the simple step of opening a video in it will perform whatever steps are necessary to create an avs file. Though one thing to watch out for, it seems to like to default to expanding video to PC levels, so be aware of that.
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is online now
post #93 of 115 Old 05-16-2015, 02:39 PM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
I downloaded Staxrip.
Seems like a magic tool...but I'm not a magician!
I would need your help.
What do I need for an .avs file? How do I use it?
How do I run a script? With which software? Is it with the avsfile?
Do I need to te reencode (lossy) the mkv I made from the m2ts blu-ray file?
Thank you!
Soulnight is online now
post #94 of 115 Old 05-16-2015, 04:01 PM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
OK guys, I got it to run. Still runs... but I could already look at the first results Blu-ray Django unchained!). But... I'll tell you only when it's finished!
I do have question:
Is the average luma given in the text file already gamma corrected (with a gamma or 2.2)?
It seems so because the value are so small (range about 9% Avg luminance).
But I do not see where in the script is it written!
post #95 of 115 Old 05-16-2015, 05:29 PM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
I don't believe so.
I'll have to get back to this, but from an mkv I've gotten a .raw file that I ran through DGAVCIndex by following these instructions for avidemux:
RAW: specialist needs, not handled by avidemux afterwards in this format.
extracting the video only to raw:
leave both video and audio output set to [Copy]
set Output Format to [Video Only]
now use save and give it a name, don't add an extension.
The video should be saved with extention .raw
Now I need to get this to run through avisynth. I don't recall whether I need a special version of that for HD.
--Darin
post #96 of 115 Old 05-17-2015, 03:05 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
So here is what worked for me in the end:
I used StaxRip, opened the mkv in it and got from that this avs script in the temp files folder:
Code:
LoadPlugin("D:\Video\Software\StaxRip\Tools\Plugins\ffms2\ffms2.dll")
FFVideoSource("D:\Video\Django_Unchained\Django_Unchained_t00.mkv", cachefile = "D:\Video\Django_Unchained\Django_Unchained_t00 temp files\Django_Unchained_t00.ffindex", fpsnum = 24000, fpsden = 1001)
Crop(0, 140, -0, -140)
Unfortunately it didn't work like that. So I downloaded the ffms2 plugin separately and changed the path in LoadPlugin to the new ffms2.dll.
The complete avs script (that I opened with media player classic) is:
Code:
LoadPlugin("D:\Video\Software\ffms2-2.20-icl\x86\ffms2.dll")
filename = "Django"
ConvertToRGB()
Levels(16,0.4545,235,0,255,coring=false)
ConvertToYV12()
Selectevery(24,0)
AssumeFps(240)
colon = " : "
WriteFile(filename, "current_frame", "colon", "YPlaneMin", "colon", "YPlaneMax", "colon", "AverageLuma" )
WriteFileStart(filename, """ "AverageLuma for Django" """)
WriteFileStart(filename, """ "Frame : MinLuma : MaxLuma : AverageLuma" """ )
WriteFileEnd(filename, """ "End" """)
ConvertToYUY2()
One thing I'm wondering about is the line AssumeFps(240). Why are we doing this?
Thanks again for your help!
post #97 of 115 Old 05-17-2015, 03:25 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
Arrow
Here the results for Django unchained (blu-ray) attached:
Average movie ADL: 8.10%
post #98 of 115 Old 05-17-2015, 03:55 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
And here the results for Django unchained if you DO take into account the black bars into the ADL analysis (so uncropped).
Average movie ADL: 6.00%
post #99 of 115 Old 05-17-2015, 04:00 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
I do have question:
I Do know now! I found it.
Code:
This line converts the APL of each pixel into ADL with a approximation of the gamma 2.2 (which is 1/0.4545).
post #100 of 115 Old 05-17-2015, 05:12 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
Here the results for one bright movie/animation: ICE AGE 4
Uncropped:
Cropped:
ID:	721562   Click image for larger version
Elix likes this.
post #101 of 115 Old 05-17-2015, 06:55 AM - Thread Starter
stanger89's Avatar
Quoted: 571 Post(s)
Liked: 294
I think I did that originally so it would "run" faster. If you open an AVS script in a media player (WMP, etc) they'd play it at 24fps, which would take the whole runtime to finish. Of course if you use something that ignores the source frame rate that line doesn't do anything.
post #102 of 115 Old 05-17-2015, 09:37 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
I just analysed Alien as well.
I change the format of the graph to present the results more clearly and to show fairly the distribution in the luminance.
It's crazy how much there is below 3% in the 3 films!
Without black bars (cropped) results:
With black bars (uncropped) results:
ID:	721850   Click image for larger version
Elix likes this.
post #103 of 115 Old 05-17-2015, 09:52 AM - Thread Starter
stanger89's Avatar
Quoted: 571 Post(s)
Liked: 294
IMO you really don't want to include the bars, that just skews the results, they're just an artifact of the encoding of the movie.
post #104 of 115 Old 05-17-2015, 11:02 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
I just "take them into account" afterwards because I know how I much I "cropped". And I know that they have pure black, so it's pretty simple to have this others ADL.
And I DO think that it's as important as the other ones..since on almost all consumers blu-rays+projectors, you will display the black bars as well, and so the ADL in each frame is decreasing a bit.
And then you can really compare contrast measurement of the projector (1920*1080p) with the picture ADL of the film with the black bars that the projector will display anyway...
post #105 of 115 Old 05-18-2015, 11:15 AM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
It looks to me like we are losing information for some low levels due to lack of precision. For instance, a full image encoded at level 20 (and even some distance higher than that) looks like it would get releveled to be the same as a full image encoded at level 16. Does anybody know how to increase the precision, like have things done in at least the 10 bit space from the point of applying gamma on?
Darin
post #106 of 115 Old 05-18-2015, 11:35 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
Darin
Why do you think so? How did you test it?
Because as I said, I checked on a grayscale calibration video, and except for the small adjustement on the level function to go along the 0-255 range, it was in very good accordance!
Maybe your method to check it isn't right. (hoping )
post #107 of 115 Old 05-18-2015, 11:53 AM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
As an example, when I made a video with a 5% video level window on black my result was 16.000000.
I can check some more numbers later, but I have the feeling that all pixels encoded up to about video level 8% are treated as if they are encoded at black (for that color primary at least).
For instance, take encoding 34 in video space. That is 18 out of 219, or 0.082. Apply 2.2 gamma and that goes 0.004. Multiply by 219 and the result is 0.9. Level that to 8 bit space with a 16 offset and unless there is rounding it is now 16.
Did you check to see what it would give you if you considered those calibration images to be video levels? For instance, a full image encoded at video level 20? I sent you an example.
I would like to be wrong too.
--Darin
post #108 of 115 Old 05-18-2015, 01:57 PM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
You are right, there is a small mistake which is done...but when you do the histogramms every 1% ADL, you actually don't do (or almost) any mistakes. (I checked, the tool does round).
See below:
ID:	724922   Click image for larger version
ID:	724930   Click image for larger version
ID:	724938   Click image for larger version
ID:	724946   Click image for larger version
post #109 of 115 Old 05-18-2015, 02:11 PM - Thread Starter
stanger89's Avatar
Quoted: 571 Post(s)
Liked: 294
These might be helpful for processing at greater than 10 bit
http://avisynth.nl/index.php/High_bi..._with_Avisynth
http://forum.doom9.org/showthread.php?t=170509
http://forum.doom9.org/showthread.php?t=154971
It sounds like AVISynth, while being limited to 8-bit can handle two stacked 8-bit clips effectively giving it 16 bit precision. I haven't investigated to understand how to make use of it. But SmoothAdjust has a SmoothLevels filter that has a gamma parameter.
post #110 of 115 Old 05-18-2015, 07:36 PM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
Thanks. I saw some indications of that after I posted, so figured it essentially crushes things encoded at about video level 6 and below with 2.2 gamma.
See below:
Nothing shows up here for me.
Darin
post #111 of 115 Old 05-18-2015, 10:48 PM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
It should work now.
post #112 of 115 Old 05-19-2015, 12:03 AM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
It should work now.
For some dark images that I was trying to get the ADL for I'm thinking that maybe I could learn more by leveling the 16 to 235 levels to 128 to 347, or something like that, if I don't figure out how to do this in higher than 8-bit space. Seems like at the least I should be able to get a more accurate value for the min, max, and median values for these images that way, where I think many of them don't have any pixels even approaching 50% video level.
I've also estimated ADLs I was getting before by measuring how bright the light is bouncing off the walls in my living room setup, but that quickly goes lower than I can measure and is somewhat crude with directionality issues. I wonder if I could defocus the image, then measure off the screen and get reasonable ideas of what I'm actually getting for average luminance as displayed that way. I could always try it with some test patterns.
--Darin
post #113 of 115 Old Yesterday, 11:03 AM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
The Art of flight
The brightest film of all!
The Art of flight! Snow, snow, snow...
Elix likes this.
post #114 of 115 Old Today, 02:40 PM
darinp2's Avatar
Quoted: 167 Post(s)
Liked: 141
Interesting results from The Art of Flight. Given the limits of cameras and human vision I wonder how much ANSI CR off the screen really matters for that material even though it does have a lot of images that are brighter than the ANSI checkerboards. For example, if ANSI CR is say 20:1 to 30:1 because of white walls then a little bit of black in a mostly white scene could be 1/20th of the white around it and still look very dark to human vision. It might be that certain ANSI CR differences are more noticeable in 25% ADL scenes than 75% ADL scenes in general.
Soulnight,
Does that include the credits? I don't know how the credits are displayed for that one, but if they are like a lot of content then they could account for much of the under 5% ADL frames.
Darin
post #115 of 115 Old Today, 02:47 PM
Soulnight's Avatar
Quoted: 43 Post(s)
Liked: 31
No I removed the credits from the analysis already!
