Sony VPL-HW10 Just Arrived! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2008, 11:03 AM
Ingeborgdot's Avatar
Quoted: 145 Post(s)
Liked: 27
Where can I find a throw distance calculator for the HW10?
Ingeborgdot is offline
Old 09-29-2008, 04:06 PM
HoustonHoyaFan's Avatar
European Review up at TrustedReviews
http://www.trustedreviews.com/tvs/re...D-Projector/p1
They seem to imply that the HW10 has MotionFlow??
What makes the HW10 particularly exciting, though, is the amount of features Sony has managed to get into it without pushing the price higher – including the ‘intriguing’ MotionFlow processing first discovered on Sony’s high-end VPL-VW200 projector.
HoustonHoyaFan is offline
Old 09-29-2008, 04:24 PM
PierreP's Avatar
Not available yet but for 16 :9 aspect, try this formula :
L = distance from lens to screen
L minimum (inch) = ((31.1781 X screen diag in inch)-46.1543)*0.0394
L maximum (inch) = ((47.0644 X screen diag in inch)-42.3308)*0.0394
Example:
For 100 inch screen
121 = ((31.1781 X 100)-46.1543)*0.0394
183.76 = ((47.0644 X 100)-42.3308)*0.0394
For 120 inch screen
145.6 = ((31.1781 X 120)-46.1543)*0.0394
220.85 = ((47.0644 X 120)-42.3308)*0.0394
PierreP is offline
Old 09-29-2008, 07:28 PM
interfx's Avatar
I'm not sure if I'm allowed to post this question - "but does anyone have these in stock?" AVS still seems to be back ordered...
Thanks -
interfx is offline
Old 09-29-2008, 09:47 PM
wohlstad's Avatar
They also claim HW10 supports anamorphic mode. Hmm ...
wohlstad is offline
Old 09-30-2008, 01:57 AM
tarking's Avatar
The HW10 Operating Instructions that can be downloaded from Sony website does not mention these features at all but then it does not show f.ex. what settings can be found under Color Temp. -> Custom N menu item. Typical Sony manual... half of the stuff is not explained in the manual at all and user has to work through trial and error to figure out how their devices work in practise.
I do not believe that these features are supported but if they are WOW!
Edit: maybe these features are included in the European HW10 version and US gets stripped down HW10 version? That would explain why the Operating Instructions does not have them explained or listed at all (downloaded from Sony US website).
tarking is offline
Old 09-30-2008, 09:05 AM
PierreP's Avatar
The VPL-HW10 has 3 new menus in the Expert mode window:
New Expert settings
1-MPEG Noise reduction
2-Film Mode
3-X.V Color
Would the film mode be something like MotionFlow ?
Here is the description from the manual:
Film Mode:
According to the film source you have selected, make a setting for playback.
Auto: Reproduces a 2-3 or 2-2 Pull-Down format video signal, such as film sources, in a smooth picture movement. When a video signal other than 2-3 or 2-2 Pull-Down format is input, the picture is played back in progressive format.
Off : Plays back the picture in progressive format without detecting video signals automatically.
After checking the VPL-VW60 manual, it sounds like a new name for the DDE (Dynamic Detail Enhancer) Mode...
PierreP is offline
Old 09-30-2008, 10:18 AM
tryingtimes's Avatar
New Expert settings
2-Film Mode
3-X.V Color
Film Mode:
That's just standard 3:2 pulldown detection and removal. i.e with it switched on, 60i film material is output at 24fps. with it switched off, 60i is shown as 60p retaining the original 3:2 judder.
tryingtimes is offline
Old 09-30-2008, 11:57 AM
wfrick's Avatar
Does the review link not work? I coudn't get it to work.
Warren
wfrick is offline
Old 09-30-2008, 12:09 PM
Warren
They've pulled it, due to the technical inaccuracies (read nonsense). We'll see if it emerges again, with corrections.
Old 09-30-2008, 01:09 PM
wfrick's Avatar
Warren
wfrick is offline
Old 09-30-2008, 01:18 PM
nilsp's Avatar
Kinda makes you wonder if they even had the projector for review....
NilsP
Life is better in HD.
nilsp is offline
Old 09-30-2008, 01:22 PM
tvted's Avatar
Quoted: 23 Post(s)
Think they will drop the "trusted" from their site name?
ted
tvted is offline
Old 10-01-2008, 11:31 AM
gbickle's Avatar
gbickle is offline
Old 10-01-2008, 11:40 AM
Originally Posted by gbickle View Post
http://209.85.171.104/translate_c?hl...RyKfSoWBOzIy3A
Another review of the HW10...
Nice - thanks for posting.
It translates quite well and seems to match with everyone's expectations.
Old 10-01-2008, 11:46 AM
Jacko05's Avatar
I can only see the opening page. Where is the rest of the review?
Jacko05 is offline
Old 10-01-2008, 11:53 AM
Quoted: 145 Post(s)
Liked: 27
Click on the side options and it will take you to the other parts.
Old 10-01-2008, 12:04 PM
davelefc's Avatar
This unit ships from the UK from a reputable store for 2,422.96 USD.
VPL-HW10: 1,495 GBP
Subtract 17.5% VAT -222.66 GBP
Total: 1,272.34 GBP
FedEx Express 91.00 GBP
Total: 1363.84 GBP (or 2,422.96 USD).
Finally the question, has anyone successfuly wired a UK projector at 240 volts? They made it clear to me that the unit comes in 240v only.
Thoughts?
davelefc is offline
Old 10-01-2008, 12:21 PM
Uther's Avatar
VPL-HW10: 1,495 GBP
Total: 1,272.34 GBP
Thoughts?
Or you could just call Jason at AVS and get one that is wired for the U.S. and comes with a warranty. I'm sure the price will be competitive.
Uther is offline
Old 10-01-2008, 02:13 PM
circumstances's Avatar
isn't it time for a shootout between the HW10, the VW40 and the VW60? especially since i want to buy a projector in the very near future?
(and i have no need for 2:35 capability)
circumstances is offline
Old 10-01-2008, 03:10 PM
Docray1's Avatar
I agree! What do you think, Jason? (Hint, hint!)
Docray1
Docray1 is offline
Old 10-02-2008, 03:32 PM
Jacko05's Avatar
How silly of me. Thanks.
Jacko05 is offline
Old 10-03-2008, 04:15 AM
Jacko05's Avatar
This would be very interesting for me as it should clear up one point, at least, about the relative image sharpness.
Jason gives the impression that the HW10 is very sharp, whereas Art Feierman, on the other hand, criticised the VW60 because of its relative softness. They use the same lens, but the HW10 uses the Bravia 2 engine. Could this be the difference?
Jacko05 is offline
Old 10-03-2008, 04:22 AM
interfx's Avatar
I keep reading all these great reviews, but can not seem to find this model in stock ANYWHERE? Suggestions?
Thanks -
interfx is offline
Old 10-03-2008, 08:54 AM
PierreP's Avatar
IN stock at Sonystyle.com as of today...
PierreP is offline
Old 10-03-2008, 09:33 AM
cc2
cc2's Avatar
and shipping Monday...hopefully!
cc2 is offline
Old 10-03-2008, 12:10 PM
PierreP's Avatar
CC2 Unfortunately, Sonystyle.com not .ca...
PierreP is offline
Old 10-06-2008, 07:27 AM
worf666's Avatar
whats new?
Ok, while waiting for this thing to ship... can you guys recommend a cheap screen for this PJ, which is not too cheap to decrease the picture qualitiy? In other words: Since this PJ is too expensive for my wallet, but I'll buy it anyway, I have to watch my money on that screen now. So what screen is cheap but still good?
edit: I just saw this is my first post, so : WHAAASUUUUUUUUP? Im a bug fan of y'all, really, been reading alot around here, all great people. Far out.
How can I add those funny smilies?
worf666 is offline
Old 10-06-2008, 08:01 AM
kc10kevin's Avatar
"Cheap" is a relative term. I'm getting this PJ and am pairing it with a Carada 118" Bright White (1.4 Gain). To me, that screen is "cheap" compared to a Stewart.
So, what price range are you looking at?
BTW, Jason recommended to me a higher gain screen for this PJ, even though my theater is 100% light controlled.
Originally Posted by worf666 View Post
whats new?
Ok, while waiting for this thing to ship... can you guys recommend a cheap creen for this PJ, which is not too cheap to decrease the picture qualitiy? In other words: Since this PJ is too expensive for my wallet, but I'll buy it anyway, I have to watch my money on that screen now. So what screen is cheap but still good?
kc10kevin is offline
Old 10-06-2008, 09:10 AM
PierreP's Avatar
Mustang pulldown screens are really cheap...
PierreP is offline
