Sony VPL-HW10 Just Arrived! - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 845 Old 06-15-2009, 09:14 AM
sikoniko's Avatar
this thread has seemed to of slowed down to a stop. Any owners alive? Did I make a bad choice buying this projector?
ask not what you can do for your country, but what your country can do for you.
sikoniko is offline
post #812 of 845 Old 06-16-2009, 03:52 AM
tarking's Avatar
Yes, we are still alive. IMO you made a very good choice and with HW10 you can expect a nice improvement over your old Sanyo.
I have been very satisfied with my purchase. Maybe it is quiet here because we do not have any major problems with our HW10s (no dust blobs, etc.) or maybe it is because of the current economy, probably both.
tarking is offline
post #813 of 845 Old 06-16-2009, 07:41 AM
tlastrange's Avatar
We're watching movies. You made a good choice.
Tom L.
tlastrange is offline
post #814 of 845 Old 06-18-2009, 02:16 PM
Kabal223's Avatar
Yep, we are a bunch of happy owners without problems to post in here, that's why this thread is dead.
Kabal223 is offline
post #815 of 845 Old 06-18-2009, 02:20 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3077 Post(s)
Liked: 3002
Silence is Golden in this case !!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #816 of 845 Old 06-18-2009, 07:21 PM
sikoniko's Avatar
so I got the projector hooked up tonight. OOTB it is BEAUTIFUL! destroys my Sanyo PLV-Z5! so very much brighter, which is something I wasn't really expecting to be honest. The size is a lot more substantial than my Sanyo. Makes the Sanyo feel like a toy.
I am very happy with this purchase and I've only had it setup for 2 hours!
I do wish the screws came with it to mount the projector to the mount. I had to make an Ace Hardware run to get the correct (5M) screws.
sikoniko is offline
post #817 of 845 Old 06-18-2009, 07:23 PM
sikoniko's Avatar
btw, do you guys put the lens cap back on after use? Seems like it would be easy to knock it out of focus by doing that. I'm used to the Sanyo's automatic door.
sikoniko is offline
post #818 of 845 Old 06-18-2009, 09:57 PM
iwanrs's Avatar
Quoted: 48 Post(s)
How about BRIGHTNESS/Lumens compare to all other Sony previous models?
iwanrs is offline
post #819 of 845 Old 05-13-2010, 05:51 PM
pglover19's Avatar
Quoted: 21 Post(s)
I received my sony projector today from another store (transfer) and the power cord that was sent does not fit.. They sent a power cord that has a L shape at the end that plugs into the projector. I need a power cord that is straight at the end that plugs into the projector. For those we have the projector already, can someone please send me the specs for the power cord (amps, volts, length, etc.). I am thinking I can use the same power cord that is used for one of my PC monitors.
pglover19 is offline
post #820 of 845 Old 05-13-2010, 05:52 PM
hjones's Avatar
Nothing special. A PC power cord will certainly carry the current - similar power consumption.
hjones is offline
post #821 of 845 Old 01-06-2011, 10:04 AM
mrtbig's Avatar
Any input on those cheaper oem bulbs?? How do they compare to the original lmp-h201?
mrtbig is offline
post #822 of 845 Old 01-06-2011, 11:20 AM
dragonbud0's Avatar
Quoted: 106 Post(s)
Liked: 49
mrtbig,
You do get what you paid for; I won't use a cheaper oem bulb, unless it is manufactured in Japan.
If you follow some of the other threads, quality control or lack of, is a major source of early bulb failure or dimness.
dragonbud0 is offline
post #823 of 845 Old 12-16-2012, 07:14 PM
Robster1958's Avatar
So my HW10 up and died...its last signature was this screen:
I just replaced it with a Panny 8000; before i throw it out, would anyone have an interest in this for parts?
Robster1958 is offline
post #824 of 845 Old 12-19-2012, 02:30 PM
hjones's Avatar
I went thru a HW10, which was replaced by a HW15 under an extended Sony warranty when the HDMI board failed. Sony claimed they could not get the board even from Japan. Then the HDMI board failed on the HW15. I gave up and bought the Panny 8000 also and never looked back. Two failed Sony projectors within 5 years is not good enough for me!
hjones is offline
post #825 of 845 Old 03-26-2013, 05:56 PM
conanb's Avatar
Quoted: 13 Post(s)
I've been enjoying mine for years now... with really long bulb life.
conanb is offline
post #826 of 845 Old 04-03-2013, 08:44 PM
Tony~M's Avatar
Quoted: 39 Post(s)
Liked: 31
Hello All,
Hope you are all well.
My HW10 is still going strong. We are now on our 3rd lamp without any problems. Everyone that sees it wants a 'room like ours', and we love the picture it throws up.
After owning an LCD projector I am so glad I switched to the SXRD, have had zero dust issues that so plagued the LCD unit we had.
Probably will not upgrade until 4k with HDMI 2.0, hopefully with some form of disk or solid state media for the content, downloading is not an option with a 250gb monthly cap on data!
Later,
Tony
Tony~M is offline
post #827 of 845 Old 04-16-2013, 11:44 PM
conanb's Avatar
Quoted: 13 Post(s)
How many hours left on the original sony bulb?
conanb is offline
post #828 of 845 Old 04-17-2013, 02:58 PM
mrtbig's Avatar
I have a yellowish smear across the screen, someone told me it might be the lcd? Any thoughts about this? Price to repair??
mrtbig is offline
post #829 of 845 Old 04-17-2013, 09:29 PM
neonsky's Avatar
Photos?
neonsky is offline
post #830 of 845 Old 04-22-2013, 03:26 AM
conanb's Avatar
Quoted: 13 Post(s)
Can anyone tell me how to make the projector continue to use bulbs that have reached the 3,000 hour cutoff limit?
conanb is offline
post #831 of 845 Old 04-25-2013, 02:23 PM
dragonbud0's Avatar
Quoted: 106 Post(s)
Liked: 49
Is there a reset timer function to fool the HW10 projector?
post #832 of 845 Old 04-27-2013, 02:35 PM
conanb's Avatar
Quoted: 13 Post(s)
I have that the key is to unplug the projector for at least 5 minutes.
conanb is offline
post #833 of 845 Old 08-11-2013, 08:35 PM
hordouts's Avatar
Will there be a HW model above the HW10? They could be referring to vw70. thank you KswUgB
hordouts is offline
post #834 of 845 Old 05-27-2014, 03:55 PM
pjp
pjp's Avatar
Quoted: 36 Post(s)
Hello,
I replaced the bulb on HW10 with an official Sony OEM bulb (not aftermarket) less than a year ago, and now with just over 1000 hours on the new bulb, it seems to have failed. I'm getting a flashing red light error with 3 flashes, which according to the manual means the bulb has either "reached the end of its useful lifespan" or that the bulb has overheated. I tried unplugging the power, but the 3 flashing red light error is still there. Has anybody had this type of early failure with an OEM replacement bulb? Is there something else wrong?
My original bulb last more than 2500 hours and was still working fine when I replaced it, so I am shocked to see this one fail in just over 1000 hours.
pjp is offline
post #835 of 845 Old 06-01-2014, 06:09 PM
conanb's Avatar
Quoted: 13 Post(s)
Talk to Sony, and get a refund if the bulb is still under the 90 day warranty period.
I buy a new Sony bulb when my current bulb reaches about 2200 hours, and install it immediately to make sure it works for the warranty period, saving the old one as an emergency replacement.
I also buy the bulbs with a credit card that doubles the warranty period.
conanb is offline
post #836 of 845 Old 06-02-2014, 09:03 AM
Mike Garrett's Avatar
Quoted: 5615 Post(s)
Liked: 3599
Originally Posted by pjp View Post
Hello,
Overheated? Will the projector work after you have let it cool or is the lamp completely shot? If it works after cooling, then it is the projector, not the lamp that has the problem.
mjgarrett100@gmail.com
Mike Garrett is offline
post #837 of 845 Old 06-02-2014, 09:26 AM
pjp
pjp's Avatar
Quoted: 36 Post(s)
Thanks -- good tip on buying with CC to extend warranty
Thanks, it does look like the projector was confused. I had shut it down and unplugged it before I posted and the problem persisted. I then shut it off and unplugged it overnight and it was fine the next morning. When it failed, it had only been on for a minute or two, so I'm not sure why it was confused. My son was using it at the time it failed and he thought he heard the fan running, but isn't positive. It has been working reliably ever since I did the overnight powerdown though, so hopefully the issue is resolved.
pjp is offline
post #838 of 845 Old 06-02-2014, 09:56 AM
conanb's Avatar
Quoted: 13 Post(s)
I have read of the "unplugging" cure. Make sure your son knows that any display using a bulb should not be turned on or off within at least a half hour of each event.
Did the unplugging change the number of hours of bulb use?
conanb is offline
post #839 of 845 Old 06-02-2014, 01:51 PM
Liked: 3599
Your issue is not bulb related.
post #840 of 845 Old 06-02-2014, 02:15 PM
pjp
pjp's Avatar
Quoted: 36 Post(s)
Not sure what you mean about not turning on or off for at least 1/2 hour -- what event are you referring to? Regarding the hours on the bulb timer, I don't think they changed. My recollection was that it was just over 1000 hours when the issue happened, but I couldn't check the hours when it wasn't working. I just checked it now (about 5 days after the issue) and it is showing 1140 hours. I was expecting something closer to 1000, so either my memory of how many hours on it was wrong or it jumped about 120 hours.
Thanks. Hoping this is good news and it was a one-time event with the projector getting confused.
pjp is offline
