Sony VPL-HW10 Just Arrived! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 845 Old 09-07-2008, 07:22 PM
Drewbert's Avatar
Originally Posted by Andrew P View Post
What is a good scaler to pair this projector with in order to get 2.35:1?
Bump
Drew
Drewbert is offline
post #182 of 845 Old 09-07-2008, 08:00 PM
Zip3kx07's Avatar
Liked: 29
How about the new DVDO Edge with a $799 MSRP.
Josh at DVDO says it can do a 33% stretch with the zoom feature for use with an anamorphic lens.
Zip3kx07 is offline
post #183 of 845 Old 09-07-2008, 08:50 PM
circumstances's Avatar
Originally Posted by rogo View Post
I can't because only the HW10 was set up at CEDIA and so any direct comparison would be at best lightly informed.
Without drawing on actual picture-quality comparisons, I'd say one thing almost immediately, though. Are you an upgrader? If so, get the HW10. There is room for improvement that will likely be achieved over the next year or two. If you are looking to set-and-forget for a while, the extra investment might be justified now, however.
I do think having the inexpensive and more expensive Sony along with both JVCs in a 4-way shootout would be fascinating for the nitpickers.
i'm a reluctant upgrader. when i buy something i'm usually looking to get more than a couple of years utility out of it. i have no problem buying the VW60, but if the HW10 surpasses it in some ways it would be nice to save some money for once.
circumstances is offline
post #184 of 845 Old 09-08-2008, 12:12 AM
chipvideo's Avatar
Quoted: 13 Post(s)
I think this is going to be my next Projector. I have the 2.35 pamamorph UH440 lens setup in use with my panny 900u and this pj looks like the best bang for the buck. I like the convergence option on each color. I just hope that panny and others force the price of this bad boy down into the $2500 range for christmas.
With this mortgage crisis looking worse than ever it is possible there could be some REALLY good christmas deals.
chipvideo is offline
post #185 of 845 Old 09-08-2008, 05:59 AM
cbaseuser's Avatar
Quoted: 54 Post(s)
Originally Posted by castaño View Post
VPL-HW10 is In Stock on SonyStyle page and ready to ship. The VW70 is Coming Soon.
BTW the HW10 is rated 30000:1.
http://www.sonystyle.com/webapp/wcs/...52921644515290
Bye
What is the NATIVE CR on the w10? We keep dancing around it but does anyone know? Jason says "The rep told me 15:000 to 1" above, but i don't think he's refering to native contrast.
cbaseuser is offline
post #186 of 845 Old 09-08-2008, 06:08 AM
anidabi's Avatar
Quoted: 45 Post(s)
Hi!
I have been following this thread for some time now and Jasons test was very interesting and informative. However there are some guestions I would like to have answer.
1. Was the tested contrast ~17000:1 with dynamic iris or not?
2. Is there some where more of the tests done by Jason Turk, so I can cross compare results between vw60 and hw10(also other projectors too)?
3. How noisy is hw10 compared to vw60?
4. How much more light output is there compared to vw60?
Don't get me wrong, I liked vw60 pq, but the light output wasn't impressive when compared to HD80 side by side. This is my main concern at this point. Will it be enought?
anidabi is offline
post #187 of 845 Old 09-08-2008, 08:03 AM
bsntn99's Avatar
I look at the HW10 as essentially equivalent to the VW60. It has the same chip size and lamp wattage, so I expect the brightness to be similar and will probably vary more with throw distance and iris auto/manual settings. Max brightness probably around 800 lumens calibrated or ~500 in low lamp with the auto iris activated. WSreview had a great write up on the VW60. Following this, native contrast should be ~4000 and on/off ~16,000-19,000 calibrated at D65. So, I don't think Jason's numbers are far off. Hopefully, Cine4home or WSReview will do a review on this shortly to get confirmation.
bsntn99 is offline
post #188 of 845 Old 09-08-2008, 08:08 AM
cc2
cc2's Avatar
Do we know if the HW-10 can use the same mount as the vw-40, 50, 60,...?
cc2 is offline
post #189 of 845 Old 09-08-2008, 08:27 AM
3 perf's Avatar
According to the press release, they mention the same mount (PSS-H10)...
3 perf is offline
post #190 of 845 Old 09-08-2008, 08:56 AM
cc2
cc2's Avatar
cc2 is offline
post #191 of 845 Old 09-08-2008, 07:21 PM - Thread Starter
Jason Turk's Avatar
Good news. I figured out my mistake on the contrast...better results. Please reread the review if interested.
Jason Turk is offline
post #192 of 845 Old 09-08-2008, 10:09 PM
WaveyD4vey's Avatar
nice! almost 25k to 1...mmmmm...me like!
WaveyD4vey is offline
post #193 of 845 Old 09-08-2008, 11:52 PM
anidabi's Avatar
Quoted: 45 Post(s)
Impressive results indeed, but still I'm a bit confused. Did you measure it with iris on or off? As for light output, did you use high lamp or low lamp mode?
Better yet, why not release all the information of how did you do the measurements. Distance, screen size, test equipment, etc. Also are your measurements comparable to earlier measurements, what you have done?
anidabi is offline
post #194 of 845 Old 09-09-2008, 01:36 AM
chipvideo's Avatar
Quoted: 13 Post(s)
How inky are the blacks. I am using a panny900u and I am tired of gray blacks.
Also I am tired of convergence issues with 3 chip units. Is the convergence movement on this unit mechanical or is it done digitally? In other words how good is it corner to corner. Also have a UH440 pamamorph lens and throwing onto a 128 2.35 screen 14 feet throw distance.
post #195 of 845 Old 09-09-2008, 06:38 AM
mcleanda's Avatar
Does anyone have the official Throw ratios for this PJ ??
mcleanda is offline
post #196 of 845 Old 09-09-2008, 06:44 AM
Steve Wright's Avatar
What mistakes?
Ditto
Steve Wright is offline
post #197 of 845 Old 09-09-2008, 07:41 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
mistake was that more units would sell at 25000:1 contrast then 17000:1 contrast. Wait for that German site to get a unit they always post contrast numbers.
conan48 is offline
post #198 of 845 Old 09-09-2008, 07:58 AM
HoustonHoyaFan's Avatar
Thanks for the redo. At 25,000:1 if Sony continued with their historical SXRD lens iris multiplier we would expect ~5,000:1 iris open and ~8,000:1 iris closed/panel contrast. Are those numbers close to what you measured.
HoustonHoyaFan is offline
post #199 of 845 Old 09-09-2008, 08:09 AM
madshi's Avatar
Quoted: 611 Post(s)
Liked: 591
@Jason, do you think the HW10 would work well with an ISCO II? CIH scaling would be done by my HTPC. Thanks!
madshi is offline
post #200 of 845 Old 09-09-2008, 08:45 AM
BBB_63's Avatar
How long until we start to see "shoot outs" done with the HW10 against other PJs?
I'd love to see this compared to the new Panny and Epsons..
BBB_63 is offline
post #201 of 845 Old 09-09-2008, 09:11 AM
barth2k's Avatar
Quoted: 728 Post(s)
Liked: 528
do these measured CR numbers really mean anything, except as a mean to compare this with other Sony SXRD PJs, let alone the JVCs or DLPs and LCDs.
barth2k is offline
post #202 of 845 Old 09-09-2008, 09:32 AM
I am not clear what you are asking. Are you asking what does on/off CR tell us about picture quality?
post #203 of 845 Old 09-09-2008, 10:34 AM
ditto. i'd love to see it against the VW60, and the new JVC 350/RS10.
post #204 of 845 Old 09-09-2008, 11:32 AM
Bill Best's Avatar
I'm also looking at picking up this projector, so hopefully there will be a powerbuy.
Now to determine the cost of the lamp.
Bill Best is offline
post #205 of 845 Old 09-09-2008, 02:43 PM
gbickle's Avatar
I guess the "mistake" was 17,000:1 contrast was calibrated, and 25,000:1 was uncalibrated (factory setting) :=)
gbickle is offline
post #206 of 845 Old 09-09-2008, 02:46 PM
gbickle's Avatar
cmon man... 25,000:1 with autoiris off? ... i dont think so!
gbickle is offline
post #207 of 845 Old 09-09-2008, 03:09 PM
Dr. Spankenstein's Avatar
Quoted: 101 Post(s)
Liked: 70
Same exact convergence ability as the VW60. Near as I can tell, the VW60 has better contrast and motorized lens. But the HW10 is sharper, better light output (VW40 was in the 500 range and VW60 was in the upper 500), and NR.
I was curious about this statement now that the "numbers" have been corrected.
Were you stating this from your personal IQ standpoint or purely based on specification?
I'm inquiring because I'm trying to nail down which model to get next month. My throw will be around 12.5' to a 100" wide Wilsonart DW scope screen from a ceiling mount @ only 7'. I only plan on zooming to get the scope aspect.
Can anyone chime in as to why I wouldn't want to go with the VW60 over the HW10? Could I potentially zoom faster with a manual zoom? Are the motors prone to failure or noise?
JVC X750R, 133" DaLite HP (2.8 gain), OPPO UDP 203
Denon X4300H, DIYSoundGroup Fusion 15 L/C/R, Mirage FS V2 Surround, Mirage Omnisat V1 Surround/Atmos
Dr. Spankenstein is offline
post #208 of 845 Old 09-10-2008, 03:41 PM
kepople's Avatar
This looks like the projector for me...
How do you feel it will do with a 120" screen at about 14' either a 1.2 or 2.4 gamma white screen?
THanks
Kirby
kepople is offline
post #209 of 845 Old 09-10-2008, 06:30 PM
kevivoe's Avatar
Why do 25000:1 and 17000:1 still not equal 30000:1 advertised.
kevivoe is offline
post #210 of 845 Old 09-10-2008, 07:40 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Are you being serious? or have you been not keeping up to date with any video tech for the last 5 years?
When has ANY tech actually met it's advertised spec? Im sure that 10000000:1 Panny plasma actually measures that and maybe exceeds it The only manufacturer that seems to post numbers close to what it can do is JVC (native) everything else is trickery with DI, and they still can't meet there own tricked out specs by cheating.
conan48 is offline
