Mitsubishi HC7000 - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 248 Old 02-23-2012, 08:57 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
StevenC56 is offline
post #242 of 248 Old 02-23-2012, 09:32 PM
Potetgullmannen's Avatar
Originally Posted by StevenC56 View Post
Anybody here still using an HC7000? Maybe not.
The HC 7000 was/is a good projector. I sold mine some months ago and bought a Sony VW95es. A good upgrade I think.
Potetgullmannen is offline
post #243 of 248 Old 02-23-2012, 10:19 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
What size screen were you using with the HC7000?
post #244 of 248 Old 02-24-2012, 01:07 AM
It was a 230cm wide, 2.35:1 format, white screen. 1.1 gain I think.
post #245 of 248 Old 02-24-2012, 07:07 AM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
If my calculation is correct that's about a 90" wide screen. Mine is a 105" wide 1.2 gain AT, so that may be a bit too large for this PJ in low lamp mode at least. Was brightness pretty limited in your opinion?
post #246 of 248 Old 10-12-2012, 05:31 AM
bobpaule's Avatar
Quoted: 42 Post(s)
Liked: 55
Mine still runs like a rock. Super sharp detail, on second lamp now, i keep wanting to replace it but don't
have the heart. It is really an awesome machine.
Check out what this guy wrote on WhatHiFi in Feb 2012:
http://www.whathifi.com/forum/tvs-and-projectors/mitubishi-hc7000-a-look-back
Hi all, just wanted to instill some optimism into the thread so here is my rant and results of extensive research. I am no pro, so bear with me.
First, this is February 2012, from UK's own at WhatHiFi, remarkable to see
something like this on a 2008 model:
You may have seen my unit for sale just earlier on the Classies, but i changed my mind and got a second OEM spare bulb instead, ater a week of frantic research and trips to showrooms, below is my experience in a nutshell.
Yes, the HC9000D is nice, but i find it hard to see any improvement apart from brightness for my batcave. The VPL-VW95ES is also very sweet, deeper blacks with good DI, but not as sharp as the 7000. Epson 6200 and Panny 8000 are clearly cheapo whirly (30 db, not above my seating position) and a PITA (pain U know where) to focus and adjust, how on God's Earth is one supposed to focus the pixels looking 2" from the screen and roll the lens(or play with joystick) at the same time? The cornucopia of models from JVC don't phase me either, tons of dead pixel posts and covergence issues.
Lastly, Mitsubishi Presentations Canada had two HT projector repairs in the year 2011 (per AVS member technician) alone, i just received an email from the guy i sold the HC5000 to years ago looking for an OEM bulb, yes it still works.
We are one lucky bunch, HC7000 for me until 4k2k PJs and material become ubiquitous unless someone sells a 4 digit priced VPL-VW1000ES:)
bobpaule is offline
post #247 of 248 Old 10-12-2012, 08:15 PM
cdika17's Avatar
I still have mine, still low hours, sitting in it's box waiting for theater 2.0 to be finished, will probably use it till I save up more for an upgrade.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #248 of 248 Old 01-27-2015, 02:28 AM
Liked: 0
HC7000 problem
Hei,
I am a owner of HC7000 and have problems to start up projector.I can hear the fun and i can see Mitsubishi logo in one second. After that status light is blinking green and power is blinking red and green. Controll panel doesnt work . Fans stop after 1 minute and projektor is blinking as described.
Just wonder if it can be lamp ballast power supply ?
Filter is clean and lamp cover is on place. If it is ballast what is a part number, can I use ballast from HC6800 ?
It looks like a protection is starting just before lamp is starting and lamp can not start light..Can it be other issues.
Sorry for my english , but I can not get any information
other place. They say main board failure and expensive repair -all on the background of led indications
Hope to get any suggestions ?
Best regards
Kemil
Kemil is offline
Mitsubishi Hc7000 Lcd Digital Video Projector
