Input Lag of various projectors - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 424 Old 03-13-2012, 03:25 PM
Hyper_Eye's Avatar
Assuming 60fps if my math is right those projector central numbers translate to:
Panasonic AR100U - 25ms
Mitsubishi HC7800 - 33ms
Acer H9500 - 41ms
Panasonic PT-AE7000U - 41ms
BenQ W7000 - 50ms
Epson 5010 - 91ms
With CFI things are significantly different:
Panasonic PT-AE7000U - 66ms
Mitsubishi HC7800 - 83ms
Epson 5010 - 141ms
Acer H9500 - 150ms
BenQ W7000 - 150ms
I don't know how accurate these numbers are but, if the 5010 is anything like the 8700UB I currently have, I believe 90-100ms is probably correct. That would make the AE7000 a significant upgrade over what I have as far as input lag is concerned. It also demonstrates that the Panny either does less with its CFI (which would be contrary to what I have read about it) or its CFI is very efficient.
These numbers ultimately don't line up well with the numbers posted above. I think quoting input lag as a frame delay does not mean much to a gamer who is used to seeing these sorts of measurements in milliseconds.
Hyper_Eye is offline
post #422 of 424 Old 03-13-2012, 03:38 PM
Bboy_jonno's Avatar
1 frame is roughly 16ms so your calculation is fine.
Keep in mind a lot of the numbers above have been tested using either a test that is controled by human reactions, such as GH using the calibration tool manually or there are no pictures for proof which is why the are "not confirmed".
Since the test above I have tested the HC7800 with the calibration sensor in rock band 2 and I was getting 32 ms. So I believe the projector central results are correct, I have one on order due to the results
Bboy_jonno is offline
post #423 of 424 Old 03-26-2012, 11:39 PM
Hyper_Eye's Avatar
Gaming on my PT-AE7000 so far has been great. It is much better than gaming on the 8700UB.
post #424 of 424 Old 06-26-2012, 08:38 AM
gnolivos's Avatar
Quoted: 357 Post(s)
Liked: 273
Can you briefly comment on the quality of both projectors when it comes to movie watching? one looked better than the other? Deeper blacks? Brightness? Pop? Thanks!!
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
Panasonic Pt Ar100u Lcd Projector Pt Ar100u , Mitsubishi Hc7800d Projector Full Hd 3d Projector , Acer H9500bd 3d 1080p Home Theater Projector , Panasonic Pt Ae7000u 1080p Full Hd Projector , Benq W7000 Home Projection System , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Home Cinema 8700 Ub Projector , Optoma Gt750 Projector , Sony Vpl Hw30es 300 Inch 1080p Front Projector , Epson Powerlite Home Cinema 8350 , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Benq W6000 1080p Dlp Projector
