Dalite High Power or Acousticlly Transparent? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 72 Old 01-03-2013, 04:50 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
happy New year Cam Man. Talk about posting on an old thread. Man I miss Cold machine.
mark haflich is offline
post #62 of 72 Old 01-03-2013, 04:56 PM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
SMX was going to release a 2.0 gain AT screen but never did. I guess they couldn't get the yields high enough. I would have paid almost anything for that!!
erkq is offline
post #63 of 72 Old 01-04-2013, 11:02 AM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 423 Post(s)
Liked: 447
Cam Man is offline
post #64 of 72 Old 01-04-2013, 02:36 PM
noah katz's Avatar
Quoted: 1095 Post(s)
Liked: 380
Originally Posted by Cam Man View Post
From your mouth to the HT God's ears; the Holy Grail of screens. smile.gif I know that some AT screen makers have looked into coatings for weaves, but the issue is clogging the openings. You would think that they could make the fabric strands out of a High Power-like material, then weave it into a fine surface that would have gain.
Might be problematic weaving without damaging the coating.
Why not a perforated HP?
That could kill, or at least injure, two birds with one stone for some - the light lost to the perforations would effectively add a degree of grayness
noah katz is offline
post #65 of 72 Old 01-04-2013, 09:31 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
My understanding is that the Stewart screens only lose 10% of the light output due to the perforations. I've often wondered why Dalite doesn't offer a perfed high power. It would be awesome and I'd get one in a heartbeat.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #66 of 72 Old 01-05-2013, 04:47 AM
Liked: 1012
Perfing things right isn't easy, lots of hand labor and using an expensive machine with a very very expensive needlepoints die. .Stewart screens are expensive and the perfing adds considerably to the cost, perhaps about 30 to 40%. Perfing ala stewart to da-lite HP would probably by itself be multiple times the cost of a non perfed HP.
post #67 of 72 Old 01-05-2013, 05:12 AM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Not to mention the HP would look really bad..2.4 gain in one spot 0 in another.. I would think the holes no matter how small would stand worse than dead pixels.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #68 of 72 Old 01-05-2013, 10:31 AM
Cam Man's Avatar
Quoted: 423 Post(s)
Liked: 447
I think you all make good points. There are discussions to be had on the the comparative pros and cons of microperf and weaves. I have favored weaves such as SMX, Seymour, and Dragonfly for their acoustic benefits, mild gain, and fine texture which is invisible beyond about 8'. Even their 2K versions have far more and smaller openings per square unit than microperf. Microperfs can be seen farther away than the mentioned weaves.
There is plenty of evidence around over the years that microperf has acoustic issues, and weaves have few. Would we all find those microperf issues overwhelming or even noticable? I just don't have a ton of experience with microperf.
The gain coating
I actually have a source for a microperf 2.2 to 2.4 gain screen material. It is even approved for RealD passive 3D. I have never gone that path due to the issues above, and my preference for very good uniformity arcross the viewing area...plus the price being over $7K for a 125" wide 2.35AR screen.
Cam Man is offline
post #69 of 72 Old 01-05-2013, 10:35 AM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
They must hand-drill every perf! Not sure I'd pay that even for a weave. So, I guess I wouldn't pay anything...
erkq is offline
post #70 of 72 Old 01-05-2013, 10:44 AM
Liked: 1012
Perfs are punched using a die, I don't remember exact dimensions, 2 2 3x3 something like that. A zillion needels per sq inch and if one breaks, the die is useless and they cost around $40K to have made.
post #71 of 72 Old 01-05-2013, 12:57 PM
Cam Man's Avatar
Quoted: 423 Post(s)
Liked: 447
You would think that the weave screen makers could come up with an electrostatic-based painting process that attracted droplets so tiny that they settle onto the weave such that they are too small to fill the gaps detrimentally. A 2.0 gain woven screen that would retain some decent uniformity (like SMX may have been) would sure be a useful product.
Cam Man is offline
post #72 of 72 Old 01-05-2013, 01:30 PM
Browninggold's Avatar
Liked: 37
Originally Posted by scottyb View Post
I posted this here because I know allot of you already have one or the other of these and don't visit the screen forum.
I know these are kinda far apart in screen choices but it's where I am.
Total light control, Sony VW60, 92" wide screen.
Just looking for opinions and pros or cons.
I didn't read the whole thread just this one...anyways in a living room setup with picture window etc....I have a Vutec 110" AT screen that drops down from the ceiling (electric) paired with a Sony VW90ES and was plenty bright enough for TV daytime viewing.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
