Sony VPL-HW10 Owners AND Calibration Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 782 Old 04-15-2009, 12:38 PM
Oberron's Avatar
Hello,
SonyHome, thx for the information, i appreciate it. Is there a particular product/brand you or anyone else here has tried, that works well and has been used successfully? Thx!
Oberron is offline
post #632 of 782 Old 04-15-2009, 10:00 PM
SonyHome's Avatar
Originally Posted by Oberron View Post
Hello,
I just use soft eye glass cloth I got from Pearl optical. Picked up few extra during my last eye exam. Just use the cloth to lightly clean the lens as needed.
SonyHome is offline
post #633 of 782 Old 04-16-2009, 08:05 PM
jayfro4's Avatar
I just ordered a refurb unit. Crossing my fingers, but couldn't pass up the price. I am now struggling with the screen. I ordered a Elite Cinentesion2 in the 1.0 grey (106" 16:9). I have full light control in basement with no windows. However, with the low lumens on this unit, I am wondering if I should go with the 1.1 white screen instead of the grey. Any opinions or suggestions?
Jay Fro
jayfro4 is offline
post #634 of 782 Old 04-19-2009, 09:14 PM
Flyboy08's Avatar
Can anyone offer assistance please?
http://www.avsforum.com/avs-vb/showt...1#post16301319
TIA, Paul
12X12 room---Need seating!
Bose Lifestyle Surround Sound w/DVD
Sony VPL-HW10 Projector
84" wall screen
Blue Ray
Flyboy08 is offline
post #635 of 782 Old 04-20-2009, 03:23 AM
tarking's Avatar
TIA, Paul
How's your player connected HDMI, component,...? When you press Menu button how does HW10's menu look... in B/W or color?
tarking is offline
post #636 of 782 Old 04-20-2009, 04:42 AM
Flyboy08's Avatar
Yes, I'm using an HMDI connection and when I select menu, the options are in color.
84" wall screen
Blue Ray
Flyboy08 is offline
post #637 of 782 Old 04-20-2009, 07:35 AM
Flyboy08's Avatar
OK..how weird is this? My SVideo plug cam undone and this is the issue. Why would it play at all is beyond my knowledge.
All's back to normal now
84" wall screen
Blue Ray
Flyboy08 is offline
post #638 of 782 Old 04-25-2009, 05:31 AM
smithb's Avatar
Anyone know how to tell on the HW10 whether it is currently playing a PAL or NTSC signal?
I bought a new Marantz DV4001 DVD player for region free PAL support and it is working great but I'm curious as to whether it is outputting PAL straight or converting PAL to NTSC first. Since the HW10 can display both I can't tell which is happening. Also, the Marantz is not letting me into the TV Setting to force one or the other.
smithb is offline
post #639 of 782 Old 04-25-2009, 06:10 AM
andrewfee's Avatar
Menu then up on the remote will tell you what format is currently being played.
PAL will be 25/50Hz.
andrewfee is offline
post #640 of 782 Old 04-29-2009, 12:45 PM
ox1216's Avatar
Quoted: 20 Post(s)
I love this projector. My room is a totally dedicated room with & complete light control. Is this the right screen for this projector. In brilliant white.
http://www.carada.com/ProductInfo.as...N-SCREEN-H110P
Thanks for your help
ox1216 is offline
post #641 of 782 Old 04-29-2009, 12:48 PM
andrewfee's Avatar
I have a 118" Carada BW and it looks great with my HW10.
post #642 of 782 Old 04-29-2009, 05:54 PM
ox1216's Avatar
Quoted: 20 Post(s)
On a scale from 1-10 what would you give it?
ox1216 is offline
post #643 of 782 Old 04-30-2009, 04:18 PM
andrewfee's Avatar
Well I only have experience with Carada and Da-Lite samples and this is the only full screen I've used, so I don't know how I could rate it.
It's the most neutral screen I could find in my price range though, with it being neutral spectrally, and having a very smooth finish compared to most other materials.
If I could have fit it in my room, I would have preferred a Criterion rather than a Precision series screen, but that would have meant the picture was ≈10% smaller. (the screen is practically touching the side walls here)
So maybe an 8 or a 9, but I really don't know how it compares to a wider range of screens. (particularly higher end which have fancy coatings)
post #644 of 782 Old 05-02-2009, 11:11 AM
stefanelli73's Avatar
@ KABAL 223
Hello Kabal i'm Antonio from Italy, could you tell me your presets for the color "red"? Do you use CINEMA, STANDARD or DYNAMIC? the IRIS, COLOR MODE, COLOR TEMP....
stefanelli73 is offline
post #645 of 782 Old 05-03-2009, 03:48 PM
ox1216's Avatar
Quoted: 20 Post(s)
Thanks. . . .. it is helpfull. The Carada is just within my budget so I'll report back as soon as I have everthing set up.
ox1216 is offline
post #646 of 782 Old 05-15-2009, 12:26 PM
Dan P.'s Avatar
Is anyone using a Carada Classic Cinema White? I'm thinking about getting a HW10, but my screen size will be 92" (1.78:1) or less in a light controlled room. I expect this PJ to be quite bright at that size and would think the brilliant white would be too bright. What's the criteria for choosing btw the classic and brilliant with an hw10?
Dan P. is offline
post #647 of 782 Old 05-15-2009, 07:20 PM
boroman's Avatar
Hello everyone....My question about the hw10 is how is the lag or motion blur... i like to watch alot of pro football in HD would this projector work... from all your remarks it sound great, but that is a main concern for me... the only other PJ i am looking at is the epson 6500u with FI... how do the two compare...
thanks
boroman is offline
post #648 of 782 Old 05-17-2009, 04:22 AM
jaimemlg's Avatar
This projector is better than epson 2000?
jaimemlg is offline
post #649 of 782 Old 05-18-2009, 05:41 AM
boroman's Avatar
Is the 2000 the same as the 6500ub.
boroman is offline
post #650 of 782 Old 05-27-2009, 07:42 PM
caeci11ius's Avatar
Hi everyone,
I recently spent a good deal of time calibrating my projector with an eye-one device and colorHCFR. I am getting very good colour and colour temperature readings (flat track of 6500k from 10-100 with delta e less than 2 from 20-100% and less than 10 for 10%), but can't seem to get the gamma anywhere near tracking a 2.2 curve. I think this may be due to my poor viewing environment (perfect light control but glossy white paint walls, a white ceiling, white carpet etc). Gamma is close to 2.2 at the lower luminance levels, but quickly falls off as luminence increases. Is this just something i will have to deal with (i cant modify the viewing environment much as i rent) or is there another problem im missing?
I'm envious of the perfect gamma tracks some of you are posting and wonder what i have to do to get one myself...
Edit: For examples, see two posts down...
caeci11ius is offline
post #651 of 782 Old 05-28-2009, 04:15 AM
cc2
cc2's Avatar
Are you measuring with the iris on? Using the same tools, I was able to measure a flat gamma only with the iris off.
cc2 is offline
post #652 of 782 Old 05-28-2009, 04:33 AM
caeci11ius's Avatar
Iris set to manual but opened all the way to maximum...doesn't change with light intensity...
I will include screens of my calibration results below:
post #653 of 782 Old 05-28-2009, 07:16 AM
Dr. Spankenstein's Avatar
Quoted: 101 Post(s)
Liked: 70
What User Mode are you in? I would suggest Cinema or User 3.
Plus, try taking readings with Iris OFF instead of Manual @ 100. I found out the hard way that they can have different white balance presets in the Service Menu.
I would be surprized if the room effected your readings THAT much, but if they are white and glossy it may be. How far away from the screen is your meter when taking measurements? Sounds like you might be in a very small, square room. If so, You could try a LOW lamp setting so you aren't creating as bright secondary reflections.
You could get a handle on what is potentially happening by taking a look in the Service menu under W/B for each of the color temp settings (HIGH, MIDDLE, LOW, CUSTOM1. CUSTOM2 & CUSTOM3) just make sure you note which Iris mode you are in since those values can/will change depending on whether you are in OFF, MANUAL or Auto.
JVC X750R, 133" DaLite HP (2.8 gain), OPPO UDP 203
Denon X4300H, DIYSoundGroup Fusion 15 L/C/R, Mirage FS V2 Surround, Mirage Omnisat V1 Surround/Atmos
Dr. Spankenstein is online now
post #654 of 782 Old 05-29-2009, 08:28 AM
caeci11ius's Avatar
@Dr. Spankenstein:
Thanks so much for your suggestions.
You got it pretty much right; the room is small and square. About 3.2m * 3.2m. Bulb already in low light mode as screen is only 92" (big for a small room though :-D). There's not a lot of ideal in my setup...
Screen about...let's say 5-10cm (2-4 inches) from the meter. I did the calibration using Curt Palme's guide (http://www.curtpalme.com/forum/viewtopic.php?t=10457)...meter was adjusted for max light output, though I didn't move it up or down as this wasn't really possible the way I set it up. Still, was getting plenty of light output and adjusted it for the max I could get moving it left and right, closer and further from the screen (meter was about 1/3 of the way up the window in the middle of the screen on the Rec709 disc available on these forums).
I've been wondering if my service mode adjustments are different to other people's? I'm in Australia, it's possible they adjust them differently here. You mention you found out that there can be different white balance presets in service mode? I am already using User mode 3 with the color adjusted to flatten out on 6500k with the correct amounts of R/G/B. I had to add a LOT of red to the gain (that's the one on top, not bias, right? It's at about 26 out of a possible 30) to get it like that, is that normal? I read somewhere that projection bulbs are often red deficient, but most settings I've seen didn't need that much added...still, room setups influence these things a lot I imagine...
I will try it again with the iris switched off though. I left it on as I read somewhere it changes calibration a bit between switching it on and off, but that keeping it at a constant value shouldn't affect things...?
post #655 of 782 Old 05-31-2009, 11:29 PM
tarking's Avatar
Every projector has different values in service menu because those settings are used to calibrate the projector in the factory and every projector is different.
NOTE(!): If you change any values in service menu write down the values before you change them because once you do change and save them there's no going back - there is no factory defaults or any kind of memory or reset for them.
With HW10 it is normal that you'll need to add a lot of red gain. This however can cause ill side effects like purplish hue in high intensity whites. You'll be better off to lower blue/green gain instead of increasing red gain. A good guide on how to adjust white balance can be found in the first post of the thread (the method used by Sony factories/service centers taken from HW10 service manual)... just use user bias/gain settings found in normal menu instead of service menu settings.
I've found out that if I use Auto Iris then Gamma 1 gives me about 2.2 - 2.3 gamma (average) and if Auto Iris is off then Gamma 3 is close to 2.2 - 2.3 (average).
I've included my white balance and gamma curve after calibration was made using these settings: Cinema mode, Iris off, Gamma 3, Low lamp. As you can see my gamma is not flat 2.2 and I honestly do not know how I'd be able to do so.
EDIT: You have to set contrast and brightness before making WB calibration. In my case the Sony defaults were perfect. Have you changed them from the defaults?
tarking is offline
post #656 of 782 Old 06-13-2009, 06:55 AM
jaimemlg's Avatar
the blacks bars are really black? are blacker?
jaimemlg is offline
post #657 of 782 Old 06-15-2009, 03:23 PM
sikoniko's Avatar
I am set to receive my projector thursday but won't get around to set it up until saturday. Is the first post still the best starting point for this projector? It hasn't been updated in quite sometime, as I see he decided to abandon the thread.
ask not what you can do for your country, but what your country can do for you.
sikoniko is offline
post #658 of 782 Old 06-19-2009, 08:21 AM
Kabal223's Avatar
Ok, something weird on my unit... do I have to warm up the projector first to show the right colors?
Why Im asking this? well, I just installed a air conditioning system in my room and I like the room really cool, now (of course) the projector is really cool also and well ventilated, but the colors doesnt seem to be accurate, all have a blue tint (especially the reds), the only way to fix this is warm up the projector first and turn off (or raise the temperature) the air conditioning system.
Is this normal?, I mean, too cool is bad for the projector?
(btw, sorry for my bad english, im from spain)
Kabal223 is offline
post #659 of 782 Old 06-19-2009, 08:45 AM
Kabal223's Avatar
Originally Posted by stefanelli73 View Post
@ KABAL 223
Im using:
Color mode: normal
Color temp: Custom 3 (blue bias -5)
Iris: auto 2
Kabal223 is offline
post #660 of 782 Old 06-22-2009, 05:53 AM
northrob's Avatar
Quoted: 53 Post(s)
Liked: 46
In my unit it take´s about half an hour for the colours to settle. It´s watchable after 10 minutes of warming though.
LG OLED 55B6V, Finnsat FST03PVR, Seagate 2T HDD, Genelec 6010B, BK XLS200-DF MK2
JVC DLA-X35BE, PS3, Apple TV3, Yamaha RX-V383, Tannoy Mercury F2, Tannoy Mercury F1, BK Monolith
northrob is offline
Sony Vplhw10 3 Lcd Home Theater Projector
