16' or 18' throw for AE3000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-28-2008, 08:31 AM - Thread Starter
Stu Pedaso's Avatar
So it's gonna be here this afternoon. I have my choice of two potential mounting locations. One is ~16', the other is ~18'. Screen size is 120"
Would one be preferable to the other?
And then...
Stu Pedaso is offline
post #2 of 11 Old 10-28-2008, 08:40 AM
ResOGlas's Avatar
Definitely go for the 16', you'll get a brighter image with the shorter throw.
ResOGlas is offline
post #3 of 11 Old 10-28-2008, 08:43 AM - Thread Starter
Stu Pedaso's Avatar
And then...
post #4 of 11 Old 10-28-2008, 09:26 AM
pottscb's Avatar
Quoted: 140 Post(s)
Liked: 75
Or if you're a black level/contrast fanatic, go with the longer throw as it will throw higher apparent contrast, at the expense of brightness!
pottscb is offline
post #5 of 11 Old 10-28-2008, 09:48 AM
MaxBench's Avatar
lol...you guys are mean! Playing with him like that.
MaxBench is offline
post #6 of 11 Old 10-28-2008, 10:34 AM
Jason Turk's Avatar
The difference in both light output and contrast over a 2' throw is so negligable I wouldn't even worry about it. Go with what is easiest to do and what works best in your room.
Jason Turk is offline
post #7 of 11 Old 10-28-2008, 10:41 AM
ResOGlas's Avatar
But you'll always think about that negligible amount in the back of your mind...
ResOGlas is offline
post #8 of 11 Old 10-28-2008, 10:48 AM
JOHNnDENVER's Avatar
I vote brightness (closer) as well if both locations have an equal PITA factor.
JOHNnDENVER is offline
post #9 of 11 Old 10-28-2008, 11:40 AM
Jason Turk's Avatar
I'd bet we are talking less than 50 lumens difference.
post #10 of 11 Old 10-28-2008, 11:41 AM - Thread Starter
Stu Pedaso's Avatar
Yeah, it's truly a horse a piece, I mount it on one truss or the other. The conduit and power are right in between the two. Might as well take that extra 50 lumens.
And then...
post #11 of 11 Old 10-28-2008, 11:44 AM
Jason Turk's Avatar
There you go then. Case closed.
