Official Planar PD8150 Owners Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
Old 04-09-2014, 06:43 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Yah, I'm aware of 0.003 spec. I usually do a trick with the cap of D3 when I want to take lens readings. Becase D3 doesn't take readings when the cap is on, you take it off but you don't move it out of the light's way. The cap should still be between the PJ and D3's 'eye'. I usually place the colorimeter close enough to reach 300 cd/m2 at 100% white. This way I can be sure that it gives me accurate readings all the way up to black on high contrast projectors. smile.gif
I also use an "offset" for target color temperature if I use this method. But that's a different story.
Elix is offline
Old 04-09-2014, 12:50 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
So here're the measurements: http://yadi.sk/d/XG4yVmZWM95ug (it's cd/m2). It's still around what I've measured previously. So I get number close to what Kris Deering got when he first reviewed PD8150 (on the old firmware). It's not close to what cine4home measured or what Kris got later on. Is it true there were different versions of PD8150 and that there were an optical path upgrade somewhere down the road?
Elix is offline
Old 04-09-2014, 01:00 PM
Seegs108's Avatar
Quoted: 4219 Post(s)
Liked: 2093
I think Kris's second unit had an "issue" with the DI where it was closing more than others which is why he was getting such high numbers the second time through. There was never any kind of major upgrade to the unit that would make for a several thousand number difference in contrast. The fixed aperture was the only "update" that I'm aware of and that was implemented VERY early on. Bob Williams told me there were some minor updates to the LS-5, but as you can see from those reviews, there also wasn't some major upgrade to the light engine that made a crazy difference in contrast.
Seegs108 is online now
Old 04-09-2014, 01:19 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Elix is offline
Old 04-09-2014, 06:49 PM
stanger89's Avatar
Quoted: 2676 Post(s)
Liked: 1363
I thought there was a firmware update that increased the dynamic contrast, probably a slightly more aggressive iris implementation or something.
stanger89 is online now
Old 04-09-2014, 06:54 PM
Seegs108's Avatar
Liked: 2093
There was only one firmware update for the PD8150 and it lists:
REVISION HISTORY
MP18 (6/18/08)
● Corrected the ability to adjust for crushing black and clipping whites for digital component
video signals.
● Corrected cadence reconstruction for 60Hz sources when the projector is set to 48Hz.
● Fixed aspect ratio issues during PIP functions.
● Corrected some RS232 command functions
● Improved ability to automatically detect appropriate color space.
● Numerous cosmetic improvements to the OSD.
● Numerous compatibility improvements for analog sources.
There wasn't an update to the DI software or algorithms as far as I'm aware unless it occurred before the projectors went retail. There may have been changes to pre-production samples that some reviewers got but as far as retail/production units go, that was the only software change put out.
Old 04-09-2014, 08:19 PM
zombie10k's Avatar
Quoted: 2827 Post(s)
Liked: 2787
that's the update I installed as soon as I got the 8130. Now the black level looks at least as good as the 4910 with the clamped iris... biggrin.gif
I would not trade this primo condition 8130 w/ 90 hours for these busted 8150's I keep reading about.. j/k cool.gif
now I'm curious to measure the contrast with the T10 after swapping the lenses. I'll post the #'s later.
zombie10k is online now
Old 04-09-2014, 08:21 PM
Seegs108's Avatar
Liked: 2093
Old 04-09-2014, 08:22 PM
zombie10k's Avatar
Liked: 2787
help me find one that isn't broken !! This projector has grown on me quite a bit, I can see why it was so popular in it's day.
Old 04-09-2014, 08:41 PM
Seegs108's Avatar
Liked: 2093
And that's why I defended my position for owning the PD8150 instead of a newer JVC for so long. Other than absolute contrast they are fantastic units. tongue.gif
Old 04-09-2014, 09:30 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Even the busted ones are awesome..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 04-09-2014, 09:50 PM
coderguy's Avatar
Quoted: 332 Post(s)
Liked: 288
You must drink energy drinks all day or something to get all this done. I'm going to be in your part of the world tomorrow VERY briefly, as I'm flying to DC tomorrow for a 2-hour layaway before I then hop on a little commuter plane to some ho-bunk town in upstate NY, wow I don't like the DC airport. Long story, but have to do some business stuff in the middle of nowhere. I have some time to kill but I'll be in the middle of nowhere waiting on this business thing, so I guess I'm just going to skip rocks off the front of TV's at the local electronics store (beats skipping rocks in the lake).
What fun, 8 hours at the airport and watching movies on a laptop just doesn't seem to cut it anymore.
I should have brought me a giant battery and a projector on the little commuter plane :smile.gif
Why did I post this and what does this have to do with anything, no idea (Boredom I suppose)...
Access HERE from this thread
coderguy is online now
Old 04-10-2014, 04:04 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Does 150$ look like too much for fixing horizontal lens shift (manufacturing of metal gears)?
Elix is offline
Old 04-10-2014, 04:38 AM
Kukulcan's Avatar
Quoted: 21 Post(s)
Liked: 25
Are you saying that you found a way to keep the iris of the Planar closed, clamped??? Or I got it wrong? I mean I'd like to use my 8150 with the DB off but with the iris full closed and not full open as it is when the DB is OFF. I mean as if it had a manual iris.
It looks like impossible from what I'm reading here until I read your post...
Kukulcan is offline
Old 04-10-2014, 05:19 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Elix is offline
Old 04-10-2014, 05:21 AM
Kukulcan's Avatar
Quoted: 21 Post(s)
Liked: 25
Originally Posted by Elix View Post
What do you mean? Does it sound strange to you that I prefer the DB OFF? Is it that?
Kukulcan is offline
Old 04-10-2014, 05:24 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
It's not that. JVC 4910 has around 60000:1 native contrast with iris clamped down (600000:1 with Dynamic Iris). Now do you believe a DLP projector could pull that off? smile.gif Zombie has obviously been ironic.
Elix is offline
Old 04-10-2014, 05:30 AM
Kukulcan's Avatar
Quoted: 21 Post(s)
Liked: 25
wait wait!!! eek.gif I didn't catch he was referring to a JVC (and joking of course).
I'm in Italy and here in Europe JVCs have different names, X900R I think...
I completely misinterpreted his post, thinking he had successfully clamped Planar's iris...
Kukulcan is offline
Old 04-10-2014, 06:05 AM
stanger89's Avatar
Liked: 1363
I'm almost positive that the firmware update improved contrast. I remember when it came out there was a bit of "discussion" about it not meeting it's 15k:1 spec, then there was a firmware update. I can't actually find a 100% iron clad reference, but I remember lots of comments like this:
http://www.avsforum.com/t/1188127/jvc-rs25-sim2-d80e-or-planar-8150/30#post_17373519
http://www.avsforum.com/t/1122246/planar-8150-follow-up-impressions/210#post_16325144
Tom's got measurements here:
http://www.avsforum.com/t/1122246/planar-8150-follow-up-impressions/210#post_16324507
Actually now that I think about it, I think that was basically the whole impetus for this thread:
http://www.avsforum.com/t/1122246/planar-8150-follow-up-impressions#post_15867713
Kris got a chance to see a newer 8150 with the new firmware after the initial review:
Originally Posted by Kris Deering
Hey everyone. I had the chance to look at another 8150 today and I must say I was even more impressed this time around than when I did my review last year. Planar has addressed the issues with clipping and contrast has been improved.
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Yeah, they have confusing model numbers for different markets. How RS49 relates to X-500, RS57 relates to X-700 and RS-67 relates to X-900 is above me.
Elix is offline
Old 05-19-2014, 09:10 AM
zombie10k's Avatar
Liked: 2787
Old 08-31-2014, 01:46 PM
dacoroman's Avatar
Do I have the deal for you guys...there's a listing for a PD 8150 on audiogon:
http://app.audiogon.com/listings/pro...4-stratford-ct
I made an offer of $1k and the sellers accepted. While I was waiting to hear back from him I jumped on a diff projector. If anyone is in the market for one I think this is a great deal.
dacoroman is offline
Old 08-31-2014, 05:41 PM
12GAGE's Avatar
Quoted: 43 Post(s)
Liked: 37
That is a smoking deal if the unit is in good condition. Someone will get an excellent unit.
12GAGE is offline
Old 09-01-2014, 09:19 AM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 286
I have a couple questions. I own a Planar 8150 and have a new home. The theater room isn't as long as my old one, but I'd like to continue to use the 8150 until I upgrade to 4K in the future. My current room is 19.5" long and 18.3 wide.
Does anyone know if the 8150 short throw lens is still available?
I was planning on getting a 130" Seymour Screen Excellence Absolute screen which is 141.1 inches diagonal.
I have a Panamorph M480SYS with motorized sled for the 2.35:1 screen.
It appears even with the short throw lens that I may not have enough real-estate for a screen that size, at least that's why I'm gathering from the projector calculator on projector central. suppose I don't have to use the full screen width with the matting ability. Is the short throw lens available after initial purchase? Any thoughts on this setup?
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
Old 09-01-2014, 12:42 PM
Seegs108's Avatar
Liked: 2093
It can be purchased through a Runco dealer. You just need to tell them it's for a Runco LS-5. The short throw lens is the same as the LS-5 as this is the same projector as the PD8150. The lens chassis will have a black accent piece on the front instead of a silver accent piece, but the glass optics and mounting solutions is exactly the same. You can even swap the silver piece for the black piece if you wanted to.
For that screen, the closest the projector lens could be (with the short throw lens being used) to the screen is 16.9 feet.
(1.56 x 130)/12= 16.9 feet
pgwalsh likes this.
Old 09-01-2014, 02:24 PM
pgwalsh's Avatar
Quoted: 392 Post(s)
Liked: 286
Thank you. That is good news.
Old 10-25-2014, 09:51 AM
shumi_9's Avatar
Quoted: 12 Post(s)
Imagine how much better it would look with a DC4 DMD.
Seegs108,
I am very much interested in upgrading my 8150 to the DC4 also. How is it done? Do I need to send it out?
shumi_9 is offline
Old 10-25-2014, 11:05 AM
zombie10k's Avatar
Liked: 2787
there are no services for this, it's actually quite difficult to locate a DC4 .95 panel since they were only in a handful of projectors.
I swapped mine out a few months ago. mine was an 8130 with the DC2+ panel, there was a bit of contrast improvement, it's certainly not day night difference. Just the cool factor of saying it's a DC4 Planar. I titled it the Planar 8170 ™
pgwalsh likes this.
Old 10-25-2014, 12:04 PM
Seegs108's Avatar
Liked: 2093
Originally Posted by shumi_9 View Post
Seegs108,
What Zombie said. You'd need to locate and install the DMD yourself.
Old 10-25-2014, 02:41 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Been watching for on since you did your...nutin yet!
Doug
