Official JVC RS20 / HD750 Calibration and CMS thread - Page 51 - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2009, 01:39 PM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
lovingdvd, you are correct, I forgot this step (pretty easy for a newbie). Thanks for the tip, I'll re-do it tonight.
deandob is offline
Old 02-22-2009, 01:45 PM
Highlander_AVS's Avatar
Just to report, last night I've seen the Last Indy and the chrystal skull, and needed to lower so much the master color from the usual +6 with RecJVC v1 to the new -5 value
The image was too oversatured and microdetails has become "dirty" and lost so was necessary to lowered the master color in order to get all propotionally balanced.
This way the movie looks like the HD trailer I learned and fixed in my memory as a reference
Strange ... an oversaturated tranfer ??
Do someone have noticed this overbust on this movie ??
Highlander_AVS is offline
Old 02-22-2009, 02:35 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
That is odd. I really enjoyed this movie with Rec Ldvd rev3 settings and did not have to make any adjustments movie-specific.
lovingdvd is offline
Old 02-22-2009, 02:53 PM
Thanks Ric ... But the strange thing is that I tried too your v3 that I use with color -5 and with Indy yours too I must lowered setting color to -10 ...
I really think it's the transfer Maybe a different European ?? or my RS20 that is near to 80 hours lamp and is changing ??
Old 02-22-2009, 03:42 PM
Tim Glover's Avatar
Quoted: 83 Post(s)
Liked: 44
I may be the only one here that uses the lamp on High. On my screen and room etc...I prefer (by a large margin) the image when the lamp is set to High. My screen is very low gain DIY AVS Forum-Home Depot SilverStar paint job. Actually it looks great and very natural. Very light grey...but whites are white and blacks are black-ish.
The iris is on -5 or -7 for most content.
Tim Glover is offline
Old 02-22-2009, 04:35 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
I use Color = -5 with Rec Ldvd rev3 for everything; gives a very natural result to my eye. But as I've noted, it's become clear to me that I really don't things with much over saturation. (Maybe I've listened to Bob Sorel too much, but I really do like the natural look.)
millerwill is offline
Old 02-23-2009, 02:08 AM
Just to report, this night I've seen Deja Vu ( great details and porosity on my screen !! ) and I'm back to original color settings ( -5 RecLDVD v3 and +5 RecJVC v1 ) so, was Indy tranfer for shure to gave me that sensations before.....
Old 02-23-2009, 07:01 AM
mdrew's Avatar
Quoted: 13 Post(s)
LovingDVD,
This question was directed to you. I am interested in what your tricks are when using the i1Pro and this projector to get reliable readings under 20 IRE. Actually, I have trouble under 30.
Originally Posted by mdrew View Post
I use the i1Pro as well. However, I have not been able to get repeatable readings below 20 IRE. What's your trick to get this thing to behave?
I did experiment quite a bit with positioning it to the projector. I found through trial and error that if I keep the meter pointed directly at the projector, I had trouble getting it close enough to be at the max range (approx 3200) before it would over saturate and refuse to give me a reading. If I angled it slightly (moving from parallel towards perpendicular), I could move the meter closer to the projector without it becoming over saturated. Aiming it directly at the projector, the max reading I could get was about 2500. With a slightly angled position, I could get a max reading of about 2800.
I was not successful, no matter what I tried, to get repeatable results below 20%. I'd be real interested in any tips you may have to share with using this meter.
mdrew is offline
Old 02-23-2009, 08:38 AM
lovingdvd's Avatar
Liked: 360
LovingDVD,
I've covered this multiple times in previous posts in this thread and others. Bottom line is that I use HCFR to train a Spyder 2 to an Eye One pro.
Old 02-23-2009, 09:24 AM
mdrew's Avatar
Quoted: 13 Post(s)
For someone who continues to councel others to post their RS20 calibration questions on this thread, you sure do know how to make someone feel like an idiot for asking.
mdrew is offline
Old 02-25-2009, 12:29 PM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
I bought my RS20 last month and since then I wasn't able to tweak it to my satisfaction. To my eyes THX mode image look very flat, so I experimented with the popular settings posted around here.
Last night, Gregg Loewen came to calibrate my RS20. He examined my settings and took some measurements.
As you can see in my attachment, D65 wasn't that off, color gammut was right on spot with REC709, and gamma was almost perfect at 2.2.
The first thing he did, was to set the iris properly such that the black levels were accurate. Then he continued doing the contrast and brightness settings. Afterwards, he adjusted the greyscale in such away that it could reduce the DE's below 1, and he succeded in doing so. Finally, adjusted the color and hue. We then took measurements (as post it in the attachment).
We then adjusted the pioneer 51fd, since it was clipping wtw. Then we moved on to watching some demo material, and explained to me about the
different CMS presets and how the THX works properly.
The image now looks flipping great... It really looks very closely to what you actually see in the movie theater, with the exception that it has by far more detailed...
To everyone that ones to have the most of their RS20 I recommend you have Gregg Loewen calibrate it...
Christian Gonzalez Pre.pdf 126.5185546875k . file
Christian Gonzalez post.pdf 125.009765625k . file
Chris. My DVD UHD Blu Ray and Blu Ray collection
JVC DLA-X750R (calibrated with calman 5 and c6 hdr meter), ST 100 (100") screen, B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W CCMM682s in-ceiling speakers (4), B&W DB1 subwoofer, Marantz AV8802A preamp, Parasound Halo A51+(2xA21)+(2xA23) amps, Oppo UDP 203 player, Roku Ultra and Harmony Elite remote.
gonzalc3 is online now
Old 02-25-2009, 03:18 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Thanks for your calibration report. I've started a new list for the RS20 in post #1 of the link at the bottom of your report.
UMR is the other owner/calibrator who has posted several impressions of the RS20. I'm looking forward to visiting one in the near future.
UMR has had the same reaction based on one of the finest theaters in the country.
Enjoy.
htwaits is offline
Old 02-25-2009, 04:00 PM
drj2000's Avatar
It sounds like Gregg only made adjustments to the THX mode which means he could not use the CMS at all. Is this correct or am I just not following your explanation?
drj2000 is offline
Old 02-26-2009, 07:08 AM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
Gregg did not use the CMS.. The colors were already within specifications...
Old 02-26-2009, 07:18 AM
John Ballentine's Avatar
Which means he calibrated the THX mode (as much as is possible) ...right?
So - is THX what you are using right now to watch movies?
John Ballentine is offline
Old 02-26-2009, 08:06 AM
gonzalc3's Avatar
Quoted: 173 Post(s)
Liked: 143
Yes....
Old 02-26-2009, 09:45 AM
Care to share what settings he arrived at for THX (color, brightness, contrast, gain, offset). (I realize they are not transferable and may be different for every machine)
Old 02-26-2009, 02:02 PM
leDahu's Avatar
color, brightness, contrast: NO.
Play with green and blue gains in order to achieve the lowest delta-luma for the 3 primaries (within +/- 1%) and balanced values on secondaries.
Don't care with dE (6 to 8 is correct)
Color temp should follow.
leDahu is offline
Old 02-26-2009, 08:04 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
correct me if I am wrong but cant you get a better picture by getting out of THX and going from there?
kutlow is offline
Old 02-27-2009, 01:26 AM
leDahu's Avatar
This procedure will set and optimize the THX mode only.
If you can read french or translate, all the details are here
http://www.homecinema-fr.com/forum/v...03803&start=30
leDahu is offline
Old 02-27-2009, 02:53 AM
Manni01's Avatar
Quoted: 2704 Post(s)
Liked: 2190
Great write up, Le Dahu
Manni01 is offline
Old 02-27-2009, 10:01 AM
The good thing about using THX mode (for me) is it keeps me from constantly fiddling around w/ the many various RS20 picture controls. When not in THX mode - I find myself constantly pausing the movie to do this (I drive myself crazy).
For me now, I have everything zeroed out in THX mode (color bumped up 8 notches), applied User1 color temp controls and I am done. No CMS, gamma, sharpness or detail controls to entice me to constantly fiddle.
I'm trying to get back to where I was w/ my RS1 - which is just watching movies (un-interrupted) and w/o constantly wondering if I can improve some aspect of the picture.
Old 02-27-2009, 10:28 AM
LOL John
There's a function in the menues to lock the buttons so you can live without the temptation to play with them during the projection
Old 02-27-2009, 11:09 AM
Mike_WI's Avatar
Quoted: 123 Post(s)
Liked: 76
LOL John
Or he could just put on some big mittens.
Sorry, I'm in WI.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is offline
Old 02-27-2009, 01:15 PM
WOLVERNOLE's Avatar
Quoted: 58 Post(s)
Liked: 27
Sorry, I'm in WI.
Mike
Yea, Mike, I was thinking "boxing gloves."
WOLVERNOLE is offline
Old 02-27-2009, 10:17 PM
mark meyers's Avatar
I have just been told that grayscale cannot be adjusted in the THX mode according to the pdf operating manual. Is this correct?
mark meyers is offline
Old 02-28-2009, 12:34 AM
karrih's Avatar
Not without going to service menu. Please follow the link specified in the first post of this thread if you want to know more.
karrih is offline
Old 02-28-2009, 10:50 AM
Thanks. Tomorrow I have a calibrator coming who is familiar with the rs1 and rs2 but not the rs20. Until there is a fimware fix on the CMS and until my bulb burns in for 150 hours I dont want a full calibration. I told him that I wanted to just tweak the greyscale in THX mode for now. But he saw on the operation manual that it is not possible in the user menus to access the necessary adjustments. Thanks for the lead on how to get into the service menu.
Old 03-01-2009, 04:27 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
You can tweak the grayscale for the THX mode if you read the work around posted.
Never become so involved with something that it blinds you.
Bulldogger is offline
Old 03-03-2009, 01:37 AM
psychdoc's Avatar
Quoted: 121 Post(s)
Liked: 197
For the experts/well informed out there....
What 120" screen would be recommended for this JVC projector in the neighborhood of 1.3 gain on a 16:9 ratio. I can't imagine spending more than 5k on it so consider that one variable (less would be better). I'm reading a lot of posts here on this projector but not much recommended as far as screens go. With some minimal ambient light at times (some times it will be very dark), is 120" a good choice? Thanks....
psychdoc is online now
