Official JVC RS20 / HD750 Calibration and CMS thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1782 Old 12-16-2008, 04:50 PM - Thread Starter
Mark Petersen's Avatar
This thread is the official calibration thread for the RS20 and HD750. Please post any CMS and other calibration (greyscale, gamma, etc.) tips, techniques and tweaks into this thread. Please use the owners thread and other RS20/HD750 threads for other discussions not relevant to calibration. As time goes on I'll update this post with links to key posts and other references related to calibration.
Due to lack of time I haven't been able to post a formal writeup that recaps most of what is in this thread. Manni01 has graciously taken the time to do this though and you can read his write up here:
http://www.avsforum.com/avs-vb/showt...6#post15654856
When the final writeup is done I'll be sure to maintain the link above and also add any new links that come along.
Mark Petersen is offline
post #2 of 1782 Old 12-17-2008, 10:32 AM - Thread Starter
post #3 of 1782 Old 12-17-2008, 06:06 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 44
Mark wil you be posting your settings?
kutlow is offline
post #4 of 1782 Old 12-17-2008, 06:12 PM
Lawguy's Avatar
I wonder if the service menu has anything we can play with that might help us use the CMS?
Affable Nitwit
Lawguy is offline
post #5 of 1782 Old 12-17-2008, 06:50 PM - Thread Starter
Good question, JVC has changed the remote keystrokes to get into the service menu. Looks like we'll have to dig for it
edit: SM keystrokes are exactly the same, but it's harder to use than the RS1 because the remote is balky.
post #6 of 1782 Old 12-17-2008, 06:56 PM
Lawguy's Avatar
I was afraid of that.
Affable Nitwit
Lawguy is offline
post #7 of 1782 Old 12-17-2008, 07:00 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Perhaps there will be some settings in there helpful for taming the CMS...
lovingdvd is offline
post #8 of 1782 Old 12-17-2008, 07:03 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Until someone posts the raw xyY data, it is hard to tell much of anything. A CIE chart by itself is not very helpful, and even luminance graphs don't help much either unless you know the chromaticity points.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #9 of 1782 Old 12-17-2008, 08:51 PM
mark meyers's Avatar
Makes perfect sense to me!
mark meyers is offline
post #10 of 1782 Old 12-17-2008, 08:53 PM
Kris Deering's Avatar
Quoted: 1578 Post(s)
Liked: 2478
Does this help Tom? This was for the THX mode.
coordinates.doc 33.5k . file
My Home Theater
Kris Deering is offline
post #11 of 1782 Old 12-17-2008, 09:44 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
So using Kris's numbers and Gregr's color calculator I come up with the following dE's
White 10.7
Red 13.2
Green 2.5
Blue 13.6
Yellow 10.2
Cyan 14.2
Magenta 8.9
I wonder how much a grayscale calibration would help those numbers. These weren't really good.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #12 of 1782 Old 12-17-2008, 10:10 PM
lovingdvd's Avatar
Liked: 360
White 10.7
Red 13.2
Green 2.5
Blue 13.6
Yellow 10.2
Cyan 14.2
Magenta 8.9
Color dE aside, it seems very odd that white would have a dE of 10.7. I think this indicates the grayscale is quite off, at least at 75% or 100% or whatever level was used to measure the color.
Speaking of which Kris - for reference did you use 75% or 100% levels, and were these fields or windows? Thanks.
EDIT: Yes indeed the grayscale is off. Tom Hoffman nailed it just by looking at the hue shift in the CIE chart. Nice work Tom. I'm basing this off of what Kris posted here: http://www.avsforum.com/avs-vb/showt...3#post15325743 . Note the dE of 10 in that chart at 100% which matches the dE reported in Kris's white point reading in the .doc he posted above. So that also answers my question - the gamut measurements were taking at 100%. It would be interesting to try at 75% which has a dE of about 7 and see if the readings improve a tad, just as an experiment.
post #13 of 1782 Old 12-17-2008, 10:18 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Kris: Very much so.
OK, we have a good idea now what the THX mode offers.
dE Performance (CIE94: 1.0 minimum perceptible error, 1.5 maximum acceptable error)
Chromaticities
LSH Analysis
Luminance Performance
As presets go, the chromaticities are pretty good, though red is more orangy than I would like.
The dEs are more of a problem. None of the colors, except green, are within a reasonable set of calibration targets, though it is certainly a big improvement over the RS1/2. The secondary dEs would be much better after a gray scale calibration. Here the white point is shifted away from blue. But the red and blue dEs are about double of what I would like to see and gray scale calibration wouldn't help these.
The biggest problem is the brightness of the the colors along the line of purples. Oddly, the remaining colors are nearly perfect. This is what takes the dEs of red, blue, and magenta considerably above what they should be.
The LSH analysis shows exactly where the errors lie. The Lightness errors are different from the Luminance errors because they are based on a perceptually uniform brightness scale compared to the Rec. 709 standard. The luminance errors are based on linear brightness compared to the expected values from measured primaries, rather than the Rec. 709 ideal.
Again, this is a preset, not a post-calibration result, which I assume would be better.
Note: I also compared these numbers against a SMPTE-C reference. It made little difference. The performance was better in some ways, worse in others, but all in all about the same.
Tom Huffman
Springfield, MO
post #14 of 1782 Old 12-17-2008, 10:28 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Kris: If you could also post the raw xyY data for the grayscale, we can get a better idea of both gamma and grayscale performance in the THX mode.
Tom Huffman
Springfield, MO
post #15 of 1782 Old 12-18-2008, 01:10 AM
Liked: 2478
Color was done with 75% windows, that is what the program (Calman) is setup for. Grayscale was also done with windows. I used the AVS Blu-ray disc for source and a PR650 for the measuring.
My Home Theater
post #16 of 1782 Old 12-18-2008, 01:13 AM
Liked: 2478
I'm such a push over sometimes.
grayscale xyY.doc 28.5k . file
My Home Theater
post #17 of 1782 Old 12-18-2008, 06:06 AM
lovingdvd's Avatar
Liked: 360
Thanks Kris. Based on this data it yields a dE of about 9.3 - 11.3 across the range. It is about 10% short on blue across the range, about 1% high on green from 20-80 and about 2-3% short on red from 20-60. This assumes no errors with the source patterns or instrumentation.
If you have it handy, can you post the default 6500 xyY measurements for the default non-THX mode (non calibrated so we can see what that mode is OOTB).
I should have my RS20 today with some preliminary info posted tonight so we can compare.
EDIT: Also meant to add that giving it credit for a perfect Y value at 10 IRE (only data for 20-100 was supplied) the gamma for this data works out to 2.22.
post #18 of 1782 Old 12-18-2008, 06:10 AM
Lawguy's Avatar
White 10.7
Red 13.2
Green 2.5
Blue 13.6
Yellow 10.2
Cyan 14.2
Magenta 8.9
These numbers are typical of (perhaps a little worse than) the numbers we were getting using the Lumagen HDQ, which in reality did a very good job even when compared to my RS1 calibrated with a Radiance.
Still, I think that we have to be able to do better.
My RS20 has apparently been delivered to my office but I am out of town until tomorrow night!
It will be a busy Saturday.
Affable Nitwit
Lawguy is offline
post #19 of 1782 Old 12-18-2008, 06:21 AM
DIY Guy's Avatar
Are you guys forgetting to take into account that you're taking measurements from a fresh bulb and haven't factored in the lamp decay down to it's linear portion of the lamp's output?
Hopefully JVC is using a predictive model in their calibration process to account for this.
Steve
DIY Guy is online now
post #20 of 1782 Old 12-18-2008, 06:37 AM
lovingdvd's Avatar
Liked: 360
This is a very good point to consider.
post #21 of 1782 Old 12-18-2008, 06:42 AM
lovingdvd's Avatar
Liked: 360
Here is a reference by Tom I like to go by:
For CIELUV, a reasonable set of tolerances are 2.5 for the minimum perceptable error and 5.0 as the maximum acceptable error. For real-world performance, any display whose pri/sec colors are below 10 is quite good performance, but if you have a CMS, I'd try to get that under 5.0.
The values posted in the thread above by mrlittlejeans are based on CIELUV. It seems likely we will be able to get this closer to (and perhaps even under) 5 with custom calibration. So in THX mode we have red, blue and cyan over the 10 "quite good" threshold. This could be for Kris' particular bulb, or as DIY Guy suggests perhaps this will improve as the bulb wears in.
post #22 of 1782 Old 12-18-2008, 07:12 AM
Quoted: 146 Post(s)
Liked: 246
I'm going to pick mine up from AVS tomorrow. Jason calibrated it so I'll measure it this weekend with my I1LT with HCFR and see what I come up with (time allowing). I was also wondering whether JVC was taking into account bulb aging in the auto calibration process. It seems reasonable that they would, but who knows.
Kris - do you have xyY data for your calibration for grayscale and gamut? Thanks for your feedback so far. Very helpful to those of us who haven't received theirs yet.
post #23 of 1782 Old 12-18-2008, 08:40 AM
pmeyer's Avatar
That's raises a good question:
Has anybody gotten a Jason calibrated projector and done measurements yet? I'm guessing not, because anybody that could do the detail color measurements themselves would likely lean away from the Jason calibration. I'm curious how close Jason was able to get.
In some ways I'm glad I don't yet have my eyeOne. I have *no* other projector to compare it to, and no way to measure it's accuracy or black levels other than 'it looks great!', or maybe the t-shirt or sock-puppet test.
I suspect I'll be much happier this way.
Paul
Paul Meyer
Bee Cave (Austin), TX
The MeyerHT is open for business!
pmeyer is offline
post #24 of 1782 Old 12-18-2008, 09:14 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
One could argue that the color performance of the THX is reasonably good for a preset. I wouldn't say that about the grayscale performance.
Gamma
90% - 2.30
80% - 2.26
70% - 2.24
60% - 2.23
50% - 2.23
40% - 2.20
30% - 2.19
20% - 2.18
Ave. 2.22
This is spot on to the THX standard of 2.2.
Grayscale
ΔE (CIELUV)
20% - 10.9
30% - 10.6
40% - 10.1
50% - 9.9
60% - 10.4
70% - 9.3
80% - 10.6
90% - 10.4
100% - 11.3
Ave. - 10.4
The dE is much too high, at least double of what one would look for.
Blue is much too weak across the entire range, which would give the image a yellowish/greenish bias. I've seen considerably better grayscale results than this on other presets (the Panasonic plasma Warm mode or Pioneer Kuro plasma Movie mode, for example), but the gamma is good.
The grayscale numbers are a little disappointing. Unless you can do a custom grayscale adjustment, I wouldn't recommend the THX preset on the RS20. It really needs custom calibration.
Tom Huffman
Springfield, MO
post #25 of 1782 Old 12-18-2008, 09:29 AM
Lawguy's Avatar
Blue is much too weak across the entire range, which would give the image a yellowish/greenish bias. I've seen considerably better grayscale results than this on other presets (the Panasonic plasma THX or Cinema mode for example) and the gamma is not even close.
These numbers are disappointing. If they are typical, I wouldn't recommend the THX preset on the RS20. It really needs custom calibration.
This explains the yellow/green tinge that apparently had been reported by some as a gamut error. The gamut needs work too, unfortunately.
There is no getting around the need for a real calibration.
I just can't explain the thinking that went into not letting users tweak the THX setting.
Affable Nitwit
Lawguy is offline
post #26 of 1782 Old 12-18-2008, 09:29 AM
Hughman's Avatar
Hi Tom,
Your gamma numbers are a little funky, when I put the numbers into HCFR gamma is fairly good around 2.2-2.3. I looks like you may have entered the incorrect values starting at 30% continuing to 70%, appears you entered 20%values at the 30% window etc.
Hughman is offline
post #27 of 1782 Old 12-18-2008, 09:33 AM
Liked: 2478
I was going to say the same thing. According to Calman the gamma tracked nearly perfect at 2.2 in the THX mode. Unlike the RS2, this thing does track gamma almost perfectly in its presets. So if you select a 2.4, it actually is 2.4.
My Home Theater
post #28 of 1782 Old 12-18-2008, 09:42 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Correction. I forgot that I have an extra data point in my spreadsheet, so the numbers were off by one level. I revised the numbers. This is much closer to the 2.2 standard. My mistake.
Tom Huffman
Springfield, MO
post #29 of 1782 Old 12-18-2008, 09:51 AM
Hughman's Avatar
I consider the gamma tracking issue of considerable significance and is something I've been fairly vocal about. Unlike your RS2 both my RS1 and RS2 initially tracked perfectly but within several hundreds hours they both developed the declining gamma issue. Thankfully I can calibrate the RS2 to reasonably flat but at about 400 hours I can't get anything much over 2.2 with it and am concerned about what the next several hundred hours will bring. Using only the 2.6 preset without "the considerable tweaking" now provides an average gamma of a little under 2, 2.3-2.4 at 10-20% and declines signif from there.
Hopefully Darin and others will measure the gamma performance over time and report any anomalies.
Hughman is offline
post #30 of 1782 Old 12-18-2008, 11:51 AM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
Wouldn't it get worse and not better? I was under the impression that the bulb loses red as it ages? If the red luminance numbers are already low wouldn't that get worse?
Never become so involved with something that it blinds you.
Bulldogger is offline
