Are RS10/20 ir and RS232 codes the same as the RS1/2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-17-2008, 07:06 PM - Thread Starter
ham
ham's Avatar
Anyone know if the RS232 and IR codes for the RS10/20 have been changed from the RS1/2? And if so, does anyone have Crestron drivers for the new codes?
If someone has a both PJs, an easy check would be to simply point one of your old remotes at your *new* PJ and see if it works.....
ham
ham is offline
post #2 of 2 Old 12-17-2008, 09:15 PM
Bulldogger's Avatar
Quoted: 204 Post(s)
Liked: 46
I looked at the document for the RS20 and they look the same. Of course the RS20 has more commands as it has more functions. I used a Pronto TSU9400 and RFX9600 extender to control my RS1 via RS232.
Never become so involved with something that it blinds you.
Bulldogger is offline
