Optoma HD8200 - Page 36 - AVS Forum | Home Theater Discussions And Reviews
post #1051 of 1056 Old 11-14-2012, 02:24 PM
guida74's Avatar
Nobody?
guida74 is offline
post #1052 of 1056 Old 11-23-2013, 10:32 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Owners of hd82 !!
Should i get hd82 refurbished over hd30 / hd25e ?
I did see rbe on hd25e but only minor amounts, did not bother my movie watching though.
Hd82 would have longer throw and faster wheel.
Vaan Janne is offline
post #1053 of 1056 Old 02-15-2014, 09:30 PM
Quoted: 42 Post(s)
Just wondering if any one can help. This is my first higher type end projector and am wondering about changing any settings?
Are the out of box settings in cinema good enough. I have pure motion set to 1 and cinema 1 as well.
Just wondering if I should be adjusting colour contracts brightness and if so do I turn everything off and then turn dynamic black on etc? I have a test disc but not sure if I should even attempt it.
I have a pitch black dedicated theater room. Optoma said that this projector is already tuned.
discobanger is offline
post #1054 of 1056 Old 06-09-2014, 11:14 AM
yoyotaka14's Avatar
sorry i know this thread is old but I would like to know if you can help me I want to Know how do I know my firmwae version is there any manu or special key combination on teh remote to access, and how fo  Inter service menu.. Thanks in advance..
yoyotaka14 is offline
post #1055 of 1056 Old 06-09-2014, 12:05 PM
yoyotaka14's Avatar
post #1056 of 1056 Old 06-29-2015, 11:31 AM
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
my projector randomly will turn off for overtemperature. the problem is, it only happens when you first start it. cycling power to the pj will clear the fault. id say it does it every 5-6 power on cycles. ambient temp in the room is at 69 degrees all the time.
roccoleach is offline
Optoma Hd8200 1080p Dlp Hd Hdtv Theater Projector
