JVC-HD1 --> How To Reset to Default Settings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2009, 10:37 AM - Thread Starter
penguin killer's Avatar
I've been messing with my JVC-HD1 and now it's in a state where I'm not sure if I really like the picture. I followed some of the RS-1 calibration settings that folks recommend, but I want to compare that now with the out of the box picture I had. Does anyone know if there's a way to reset the projector to it's default settings?
A second question I have is that appears that I have a bit of a ghosted image, particularly on SD content. I've tried changing the focus to see if that would help, but it doesn't look like it does. I didn't notice the difference until recently, so I'm wondering if some of the settings I changes actually caused this.
Appreciate any help here.
Sean
penguin killer is offline
post #2 of 6 Old 01-28-2009, 05:29 PM
hrd
hrd's Avatar
Sean
Do you know how to get into the service menu? The RS20 has a reset option in the service menu. I would not be surprised if the RS1 does as well.
hrd is offline
post #3 of 6 Old 01-28-2009, 06:18 PM - Thread Starter
No, I don't. I think I found a pdf file for installing an update of the firmware that indicated you press up down left right enter really quick. Is that correct?
post #4 of 6 Old 01-29-2009, 04:46 AM
Sherardp's Avatar
See post 1 for service menu access
http://www.avsforum.com/avs-vb/showthread.php?t=813550
Click the link to see pics of my home theater
http://s450.photobucket.com/albums/q...oom/?start=all
Sherardp is offline
post #5 of 6 Old 01-29-2009, 12:52 PM - Thread Starter
Got it. Did it last night. Worked like a charm.
post #6 of 6 Old 01-30-2009, 07:07 AM
Jason Turk's Avatar
How did it compare to your settings?
Jason Turk is offline
