Optoma 8200 Review - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 211 Old 12-07-2012, 09:46 AM
guida74's Avatar
Originally Posted by clrv View Post
I am using a Stewart Studiotek 130G3. Projector is 15ft back and Ceiling Mounted. Disregard below 30 as the i1Pro does not read correctly under 30.
Mode - User
Contrast - 41
Brightness - 41
Color - 57
Tint - 47
Sharpness - 2
Noise Reduction - 0
Gamma - Standard *Curve type 4, offset -1*
Color Temp - Warm
Red Gain 5
Green Gain -3
Blue Gain -5
Red Bias 0
Green Bias 1
Blue Bias -1
Pure color Off
Pure Detail Off
I am trying to determine the correct gamma setting for this projector and I don't have test equipment to verify. I have calibrated the Refernce Mode which defaults to film gamma. I noticed you changed the standard gamma defult values in your settings. Are those the correct gamma settings (curve type & offset) for a linear 2.2 gamma on this projector? I don't want to spend extra money on a meter or professional calibration just to verify gamma since I am happy with my current settings. Comments/ help would be much appreciated.
guida74 is offline
Optoma Hd8200 1080p Dlp Hd Hdtv Theater Projector
