PT-AE2000U w/ big yellow spot. Dust blob? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 02-11-2014, 04:35 AM
goAMinD's Avatar
Hi all,
I too have the large horizontal oval yellow spot:
I did my own repair as well. With the service manual in hand for my Sanyo PLV-Z700 it was quite easy to disassemble and change the part. In my case I confirmed that the Blue Polarizer had severe burn. In bought a new Blue Polarizer and replaced it. The picture was greatly improved, but the yellowspot was still present, just not as noticable as before. In my case I now believe that also the Prism array holding the LCD's could have some burn damage. changing anything in the prism array concerning LCD's would be very cost full, so it's either living with it or replace the projector.
Anyway, I surely get tired of projectors before I even consider replacing it smile.gif
goAMinD is offline
post #32 of 32 Old 05-01-2014, 02:49 PM
gitongisip's Avatar
Quoted: 52 Post(s)
The blob on my ae2000 is just showing on black or dark background. The color is vlsed to green I the middle. Is it a poralizer issue. If it is, what color should I buy to replace.
gitongisip is offline
Pt Ae2000u Lcd Hd Proj 16k 1 1500 Lumens Hdmi Component Svid Ser
