Benq w6000 - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #2431 of 2460 Old 11-19-2014, 11:45 AM
Charles R's Avatar
Liked: 629
Originally Posted by runekc View Post
Is that the only way to turn down the light? What about the iris is there any tricks?
If you search this thread you'll find your way into the service menu where you can tame the brightness all you want... down to total darkness.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #2432 of 2460 Old 11-19-2014, 11:48 AM
runekc's Avatar
Hi, yes I have been in the service menu and adjusted the DB setting but nothing "sticks" it reverts to standard after power cycle, plus I am not 100% sure which parameter to adjust.
Cerwin Vega 1215 MK II, CLSC-15S, VE-5C, VE-5M, Denon POA-6600Ax2, AVR-X4100W
runekc is offline
post #2433 of 2460 Old 11-19-2014, 12:02 PM
Charles R's Avatar
Liked: 629
Benq w6000
Benq w6000
Adjust Max to kill the brightness and Min to reduce the black level. As far as sticking I don't remember... just that the color wheel speed never stuck.
post #2434 of 2460 Old 11-21-2014, 05:19 AM
runekc's Avatar
Hi again, well I can't get the iris settings to "stick" but for now I live with it but another issue I have is the ISF settings, after calibration in the ISF menu it doesn't "load" the ISF profile after power cycle, is there any setting I have overlooked? Thank you in advance
Best regards
Rune
runekc is offline
post #2435 of 2460 Old 02-25-2015, 06:40 PM
HingisFan's Avatar
Can someone help me out? My bulb that I replaced recently blew and was still under warranty. I just got the replacement back in the mail, but I have misplaced the piece of paper telling me which side of the connector is positive. I have to install the bare bulb into the housing. I know the wire coming off the back of the bulb is the positive, I'm just not sure which wire coming from the black connector is positive and negative. The connector end only fits in one way, so I know it will be correct going from housing to PJ. I also had written down the orientation of the bulb within the housing, but I'm not sure if that matters or not.
Help!
HingisFan is offline
post #2436 of 2460 Old 02-28-2015, 04:12 PM
predator314's Avatar
Help!
Do you have a link as to where you bought the bulb?
All BenQ lamps come with the housing included. The knock offs require you to install a bulb in the housing. BenQ lamps are 2year 2000 hour warranty on these W6000's there's docs still somewhere if you google indicating as such.
How much did you pay?? My genuine BenQ ones have been $263 Canadian, but I have had 2 that blew within 200 hours. My W6000 is currently around 12,500 hours. Would be interested in saving some money in the future.
As for your question, the polarity of the bulb should not matter as it is just 2 electrodes that arc to fire the gas inside the bulb then maintain a voltage to keep it illuminated. The electrodes do not physically touch or have a filament. In fact, I believe it is a high voltage AC current that runs the bulb so polarity really wouldn't matter in that case. They are very similar to HID head lights, just more precise and calibrated manufacturing for color and output.
How did these 'aftermarket' bulbs work compared to the original BenQ lamp? I typically see a noticable drop off in brightness at 1500 hours, and almost unusable past 1700 in Economy mode.
predator314 is offline
post #2437 of 2460 Old 03-01-2015, 06:36 AM
HingisFan's Avatar
So, it doesn't matter where I put positive or negative, or which way I have the bulb turned???
This is my first bulb replacement in this one, I was told that genuine bulbs are pretty much all phillips or osram anyway so I thought I might as well just buy the bare bulb. Bought from Exclusivebulbs on amazon, they seem to have a good rep and good customer service.
post #2438 of 2460 Old 03-01-2015, 08:34 AM
talon95's Avatar
Quoted: 133 Post(s)
Liked: 65
Help!
Looked at the housing from the plug side, bulb facing downward, the leads are on the right (which is also the side *without* the dust screen on the housing). The leads are different lengths, longer one obviously goes to the lamp tab furthest from the plug.
Also, looking at the housing in the same orientation, the short wire is on the left side of the plug. Maybe that's what you really needed? Both are black, dunno which is positive.
talon95 is offline
post #2439 of 2460 Old 03-02-2015, 03:00 PM
HingisFan's Avatar
Sorry can you explain that again? I'm holding the housing, bulb pointing to the floor, plug at 12 o'clock. Metal honeycomb thing is at 3 o'clock side. Would leads go to 9 o'clock side then? Thanks so much!
post #2440 of 2460 Old 03-05-2015, 07:20 AM
talon95's Avatar
Quoted: 133 Post(s)
Liked: 65
Yes, opposite side of the honeycomb.
talon95 is offline
post #2441 of 2460 Old 03-06-2015, 01:20 PM
HingisFan's Avatar
post #2442 of 2460 Old 09-14-2015, 06:42 PM
thxave's Avatar
Best regards
Rune
Anyone able to adjust the iris setting and get it to stick? I want it at 75 but I have to manually set it every time I turn the projector on.
It reverts to 60 which I find is not clamping down enough.
thxave is offline
post #2443 of 2460 Old 09-17-2015, 07:36 AM
talon95's Avatar
Quoted: 133 Post(s)
Liked: 65
You are aware that it subtracts 13 after changing it and power cycling?
talon95 is offline
post #2444 of 2460 Old 10-02-2015, 12:22 PM
patrickoneal's Avatar
Quoted: 40 Post(s)
Liked: 38
I'm hoping someone here can help with what might be a stupid question...
I'm trying to disable the iris on my projector, at least temporarily for calibration purposes. I'm using the ISF menu to adjust my picture.
I have dynamic black turned off. However, when a movie is silent, I can hear a sound from the projector when the screen goes immediately to/from a light to dark scene. The best I can describe it is like the noise from a mechanical hard drive. Is this the iris or something else entirely? I seem to remember the iris being a high pitched sound, so I'm thinking it's something else.
patrickoneal is offline
post #2445 of 2460 Old 10-02-2015, 01:14 PM
talon95's Avatar
Quoted: 133 Post(s)
Liked: 65
That's weird, it should be off but that is exactly what it sounds like. It can be disabled in the service menu too.
talon95 is offline
post #2446 of 2460 Old 10-03-2015, 04:46 PM
Quoted: 40 Post(s)
Liked: 38
Thank you! I disabled it in the service menu, and heard it open up to what I presume is the "off" position, I think that solves it for me if the setting sticks.
post #2447 of 2460 Old 01-31-2016, 11:33 AM
ERuiz's Avatar
Quoted: 524 Post(s)
Liked: 166
Benq w6000
Anyone here that uses his/her W6000 mostly for gaming and FPS games such as Battlefield, can elaborate on the input lag of this projector?
I am shopping around for a gaming 1080p projector and I have narrowed it down to the BenQ W6000 and Sony HW40ES. I can get a used W6000 for about $800 (less than 10 hours on lamp) and the Sony 40ES can be found used for ~$1500. Basically, I can save HALF by going with the W6000.
All I need to know is if the input lag on the W6000 is low. The Sony 40ES's input lag on game mode has been clocked at 24ms.
FOR SALE: Sony HW40ES / BIC Acoustech PL-200 sub / nVidia Shield TV Pro (2017) 500GB Edition
LG 65C7P / Denon AVR-X4300H / Klipsch RP-280F / Klipsch RP-450C / Klipsch RP-150M (x4) / Klipsch RP-140SA (Atmos) / HSU VTF-3 MK5 DualDrive / PS4 Pro / Oppo 203 / Logitech Harmony Elite
ERuiz is offline
post #2448 of 2460 Old 03-08-2016, 08:47 PM
cgott42's Avatar
Quoted: 154 Post(s)
Does anyone know what the model # of the Philips(?) bulb used in the W6000 is? thx
cgott42 is offline
post #2449 of 2460 Old 03-31-2016, 08:09 AM
cgott42's Avatar
Quoted: 154 Post(s)
Can someone PM me how to access the service menu to get to the various testing patterns
thx
cgott42 is offline
post #2450 of 2460 Old 05-02-2016, 08:45 AM
project1971's Avatar
Wink
thx
on menu screen go to info menu last to the right and press up-down -up-down .be very carefull in there . good idea to shoot photos of original settings before change something.
project1971 is offline
post #2451 of 2460 Old 05-02-2016, 12:09 PM
cgott42's Avatar
Quoted: 154 Post(s)
thanks
cgott42 is offline
post #2452 of 2460 Old 07-06-2016, 08:25 AM
temeone's Avatar
Quoted: 17 Post(s)
Has anyone replaced their bulb recently with one NOT from BenQ? Looking for an OEM bulb, but thinking I *might* be able to get it cheaper than the $300 BenQ is asking.
temeone is offline
post #2453 of 2460 Old 08-22-2016, 09:37 PM
I have purchased 6 bulbs now from this seller. They work fine, and for the price I've been swapping them out every 500 hours to keep that 'like new' clarity/brightness. I've ran one up to 1350 hours, at which point it was about on part with a BenQ at 1500 hours.
Price is right, especially when you order 2-3 at a time. They take anyways from 6 to 9 weeks to arrive to Canada when I've ordered.
Seller is great, I've had a tab on one bulb that wasn't threaded for the screw. They asked me to snap a photo so they could confirm and send a replacement for free. Turns out I managed to thread a different screw in and use it anyways.
I'm at 16,634 lifetime hours on my W6000. I've fully disassembled and reassembled it 3 times over the last 6 years to fully clean it and haven't really had any major issues. Some minor annoyances from time to time with iris stopping in a dumb spot on start up (even when disabled), but easily corrected.
See my next post for link.
post #2454 of 2460 Old 08-22-2016, 09:37 PM
https://www.aliexpress.com/item/Compatible-bare-projector-lamp-bulb-5J-J2605-001-for-W5500-W6000-W6500/32284186236.html?spm=2114.13010608.0.54.htcrX6
Just a note, the price on this is super low now, $33USD.. They used to be about $117. I've noticed no drop in quality, and I have tried both their genuine OEM bulb (Osam/Phillips) and compatible bulbs. They look slightly different for how the leads were, but performed pretty much identical, so went with compatible for all future orders.
post #2455 of 2460 Old 08-22-2016, 10:06 PM
Aperature Min is what you'll want to change to limit the 'brightest' or wide open position of the aperture/iris. 12-13 is typically the default.
See latest reply about the service menu for tips on DB Aperture.
post #2456 of 2460 Old 08-22-2016, 10:06 PM
I figured I'd put together my own thoughts on the DB Aperture menu since so many people are having trouble using it or keeping settings. Hopefully this explains things a bit and helps someone.
DB Aperture menu - This is found in the Service menu, do so at your own risk -- Menu, Information tab, Up, Down, Up, Down
DB Aperture Position - This displays the current position (this value does not update in real time, you must exit the DB Aperture menu and re-enter it to see the updated current position)
DB Aperture Max. - This sets the maximum (closed) position Dynamic Black (iris) will use
DB Aperture Min. - This sets the minimum (wide open) position Dynamic Black (iris) will use (This is the position the aperture is moved to on power up when Dynamic Black is disabled.
DB Reset - This resets the aperture to 0, then to the aperture min position. This is useful after a sudden power loss, or if the aperture position appears to be 'drunk' (too open or too closed at all times -- screen super dim from a power on) For some reason, you can run this 3 times, and each time it ends up at a different 'home' position, one of them being correct.
DB Enable - Turns Dynamic Black on or off without leaving the menu
Reset DB Max/Min Aperture - Clears all DB Aperture values back to default for your firmware (after you select this, exiting the DB aperture menu and them re-selecting it will show all default values)
DB Aperture Position Calibration - This will attempt to calibrate the position of the aperture (metal disc in light path with a slot that widens the light path as it's rotated). Be warned that this will exit the service menu after running, and there's a chance you'll end up with the aperture disc completely blocking the light path. You can sometimes power up and down (removing plug after full power down) to get the aperture to rotate to the 'home' or 0 position.
Quick tips:
- Aperture Min and Max will have no realtime affect if DB Enable is Off
- Aperture Position manually moves the aperture, but will only work if DB Enable is Off, otherwise DB holds the aperture where it desires
Quick steps to tweak this area as a starting point:
- Set DB Enable to Off
- Adjust the aperture position up and down to see how the values affect the picture in realtime.
* Note * the 'Aperture position' value listed does not update as the aperture position changes, if you hit exit then re-enter the DB Aperture menu, that value gets updated, it is for informational purposes only.
- You should notice the image is brightest around 13, if this isn't the case, the aperture disc is likely out of position, and you may benefit from selecting DB Reset until it is bright when positioned at 13.
- You should also notice the image is it's darkest around 55-60.
- Take note of what point you want as your brightest and power on point, set your DB Min to this, typically 13.
- Take note of what point you want as your lower light output, set this as your DB Max, typically around 54.
- You can now set DB Enable On and it will auto adjust the aperture position
- If you didn't achieve your desired effect, try Reset DB Min/Max Aperature to set settings back to defaults, or the other settings mentioned in this thread.
It would be a good idea to carefully note the key presses to enter the Service menu and enter the DB Aperature menu, then select the DB Reset option. If you run in a scenario where the aperture disc is blocking the light path from power on, you can press that key sequence to regain enough light to use the on-screen menu again and recover.
post #2457 of 2460 Old 09-20-2016, 08:55 AM
isamu's Avatar
Quoted: 34 Post(s)
How are these bulbs working out for you so far? I just took a chance and ordered a couple of 'em for my BenQ W7500 at $55USD each. Hope they're as good as you say
isamu is offline
post #2458 of 2460 Old 09-20-2016, 01:02 PM
They are still working fine. Although I think it's about time to replace my beloved W6000. The last couple weeks, at almost 17,000 hours I'm having light engine (ballast) issues. Have a genuine BenQ lamp installed, and it's about 70% brightness after only 80 hours, had another that was barely usable with only 450 hours (again another genuine lamp), any other new lamp has also done the same, OE or cheapie from online. Sometimes, I receive a Lamp error on power on, even on a new bulb. Unplugging the projector for a couple minutes resolves the issue, but still low light output after 70-80 hours on any lamp is not acceptable. I've tried the same lamps in another W6000 and they are fine.
post #2459 of 2460 Old 03-18-2017, 09:43 AM
innatetech's Avatar
Hello all!
I know this thread has slowed significantly, but hopefully people are still subscribed.
I purchased a supposedly factory-correct replacement lamp/housing assembly from LampsPros.com:
http://www.lampspros.com/benq-w6000-projector-lamp.html -- at $80 I found it hard to resist, the site looked reasonably legit, and they're local to me. Although it turns out this item was drop-shipped from their supplier. (With terrible packaging: no outer box, unsealed plastic stretch-wrap inside securing the assembly to a piece of cardboard.)
After about 10h of Zelda on eco-mode, the lamp blew up. Blew. Up. In the PJ.
The replacement was warrantied for 90d so I've initiated a return, but I have some concerns:
(1) There seems to be some sooty residue inside the chamber that holds the housing, although it does not seem to be in the optical path (if that's the right phrasing) -- so should I just let it be? Or swab it off with a Q-tip, avoiding the aperture?
(2) Can I reinstall & continue using the factory lamp for now? It has 3k+ hours on it and I did reset the lamp timer when I made the replacement. Not sure if that's asking for more trouble. I'm being kind dumb here, maybe, but I'd really prefer not to have the PJ out of service for however long this takes to resolve, it's my primary display for everything entertainment related.
(3) Even if not safe to use w/a reset timer (not sure if the PJ steps down power after 3k hours), should I reinstall the factory assembly to keep particulate from infiltrating the interior of the PJ, etc? Or is having the cover in place enough?
(4) Are there any discounted suppliers worth their salt, without having to rewire the assembly myself, or is B&H the best bet right now?
Pics attached.
Any & all thoughts appreciated, as I'm not a PJ expert, can't afford to replace the W6000 currently (haven't seen another short throw with lens shift that isn't super expensive lately) and this is a little scary.
Thanks much.
ID:	2033873   Click image for larger version
ID:	2033881   Click image for larger version
ID:	2033889   Click image for larger version
ID:	2033905   Click image for larger version
innatetech is offline
post #2460 of 2460 Old 03-27-2017, 04:50 AM
Liked: 0
Hi, I bought this projector recently.
And I would like to know how to save something in the service menu? He always goes back to the original values.
GabrielX is offline
