Official JVC RS20 / HD750 Calibration and CMS thread (NEW FIRMWARE V1.1) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1636 Old 04-28-2009, 08:28 AM - Thread Starter
Manni01's Avatar
Quoted: 2685 Post(s)
Liked: 2166
[EDIT 06-05-09: I have edited this first post to add some info from the first calibration thread and to make it a useful table of content to the new calibration and CMS thread]
This thread is a continuation of the original official RS20/hd750 calibration and CMS thread here http://www.avsforum.com/avs-vb/showt...8#post15314888.
As the old calibration thread is mostly obsolete regarding CMS calibration with the arrival of the new firmware, we have decided to start afresh!
First things first, you need to upgrade the firmware before using the tips available in this thread.
A - NEW FIRMWARE
Where to get the firmware update (and common installation issues): http://www.avsforum.com/avs-vb/showt...8#post16355768
CAUTION: the new firmware erases ALL settings, so if you have general settings or calibration settings you wish to keep, make sure you make note of them before upgrading.
There is a wealth of knowledge regarding greyscale and gamma calibration in the original calibration thread. So here is a list of the most important posts which are still mostly relevant with the new firmware:
B - GREYSCALE: (from original thread, but info still relevant)
Before we get into CMS settings, the first thing to do is to get the best possible greyscale using only color temps adjustments, as this will make a huge difference with THX (and other presets). As already reported, some excellent tips are available here to achieve this from Mark Petersen Official JVC RS20 / HD750 Calibration and CMS thread - Page 22 - AVS Forum and also from Googer and others in the rest of the thread, here is one of Googer's great posts about gamma: http://www.avsforum.com/avs-vb/showt...#post15522847]
C - TWEAKED THX (from original thread, but info still relevant)
Once you have a custom color temp that gives you as perfect a greyscale as possible, the next step is to select the THX preset and enter the service mode (up/down/right/left/enter as fast as possible, either on the remote or the pj). [DISCLAIMER: be very careful when in this mode, you enter it at your own risks, if you make a mistake, don't blame me!]. You can then select a different color temp (for example the custom one you've just tweaked), and this will be the color temp used by THX. You can now exit the service mode. This will make a HUGE difference to the ootb THX preset, as it will use a greyscale which is likely to be pretty good from 30 IRE up to 100 IRE, instead of a greyscale which is quite flat but off badly over the whole range, whether in normal or high lamp. More info about achieving this here Official JVC RS20 / HD750 Calibration and CMS thread - Page 29 - AVS Forum
If you like this "tweaked THX" preset, which is very close to rec709 - although slightly undersaturated for some - with a standard gamma, you can stop here and enjoy your PJ. If you do find it undersaturated, you can add anything from 1 to 12 - depending on your taste - to the general color control (I personally add 1-5 depending on source). That's it. Job done.
If you want to go one step further, and be able to use a custom gamma, sharpness and detail enhancement controls and adjust the gamut to Rec709, SMPTE-C or to your own taste, then have fun with the next section which is mostly about custom CMS settings...
D - CUSTOM SETTINGS, REPORTS and CALIBRATION TIPS with the NEW FIRMWARE
As members post reports/settings and calibration tips in the thread, I'll try to update this section with the most significant contributions (in chronological order).
Please let me know if I have forgotten something or if I get sloppy updating...
Reports from the pros:
GregR : http://www.avsforum.com/avs-vb/showt...7#post16360087
Tom Huffman: http://www.avsforum.com/avs-vb/showt...3#post16383023
Tom Huffman#2: http://www.avsforum.com/avs-vb/showt...9#post16431819
Settings:
Manni01 (1.4 gain screen): http://www.avsforum.com/avs-vb/showt...7#post16365507
JeffY: http://www.avsforum.com/avs-vb/showt...3#post16371803
Karrih: http://www.avsforum.com/avs-vb/showt...4#post16380924
008: http://www.avsforum.com/avs-vb/showt...9#post16383359
Nelson4u: http://www.avsforum.com/avs-vb/showt...7#post16388557
Ignace: http://www.avsforum.com/avs-vb/showt...7#post16389657
LovingDVD: http://www.avsforum.com/avs-vb/showt...6#post16482286
Lawguy: http://www.avsforum.com/avs-vb/showt...2#post16428562
Manni01 (1.2 gain screen): http://www.avsforum.com/avs-vb/showt...1#post16431351
MarcelW: http://www.avsforum.com/avs-vb/showt...9#post16433669
Lawguy LT vs i1Pro http://www.avsforum.com/avs-vb/showt...8#post16438408
RickS (HDMI Enhanced): http://www.avsforum.com/avs-vb/showt...4#post16630004
Manni01: back to 1.1 gain/new lamp, and HDMI Enhanced, settings for Rec709 and SMPTE-C http://www.avsforum.com/avs-vb/showt...0#post16662220
Manni01: updated Rec709 and SMPTE-C calibrations, along with a PAL calibration: http://www.avforums.com/forums/dlp-l...ml#post9767111
Calibration Tips:
Classic beginner's mistake and link to Tom Huffman's CMS calibration tutorial and GregR's calculator thread: http://www.avsforum.com/avs-vb/showt...3#post16370193
How to use filters to check brightness (LovingDVD): http://www.avsforum.com/avs-vb/showt...7#post16372917
When/why NOT to use filters (GregR & Tom Huffman): http://www.avsforum.com/avs-vb/showt...7#post16373717 and http://www.avsforum.com/avs-vb/showt...1#post16380651
dE discussion: http://www.avsforum.com/avs-vb/showt...5#post16374865
Tom Huffman's spreadsheet for CIELUV: http://www.avsforum.com/avs-vb/showt...7#post16378927
GregR's DisplayCalibration Calculator: http://www.avsforum.com/avs-vb/showt...2#post16382042
Get a screenshot in HCFR: http://www.avsforum.com/avs-vb/showt...8#post16383268
Which USB cable for the firmware upgrade?: http://www.avsforum.com/avs-vb/showt...7#post16383437
Training a meter to another in HCFR: http://www.avsforum.com/avs-vb/showt...4#post16384494
Adjusting greyscale (GregR): http://www.avsforum.com/avs-vb/showt...0#post16387960
Link to Calibration for Dummies: http://www.avsforum.com/avs-vb/showt...9#post16402839
Use of filter and calibration tips (Darinp2): http://www.avsforum.com/avs-vb/showt...9#post16431819
Saturation levels explained (Tom Huffman): http://www.avsforum.com/avs-vb/showt...2#post16439382
Sharpness/focus adjustment tips (GregR / LeDahu / Deanbob): http://www.avsforum.com/avs-vb/showt...2#post16689752
Great tips/tools for gamma calibration (LovingDVD / LeDahu): http://www.avsforum.com/avs-vb/showt...8#post17017488
Gamma tweaking V1.2 (english translation and VERY IMPORTANT SPECIAL PROCEDURE): http://www.avsforum.com/avs-vb/showt...9#post17045339
Gamma tweaking V2 (Le Dahu): http://www.avsforum.com/avs-vb/showt...6#post17060116
Contrast and RGB (Tom Huffman et al): http://www.avsforum.com/avs-vb/showt...8#post17150298
REST OF INITIAL POST:
I have done a first attempt with the new firmware, and the news is mostly good!
- The range for the controls has been extended from -60 to 60 (instead of -30 to 30), which gives enough range to dial the gamut perfectly without touching the general color control. Well done JVC!
- The linearity is good but not perfect. Most colors stay where they should, but green seems to be a bit oversaturated at 75% when calibrating at 100%. Nothing compared to the first firmware, but still not perfect. [edit: this was due to an error on my side, there is NO LINEARITY problem with the new firmware].
- I had only time for a quick calibration today, so I'll post more later. I attach my HCFR files for those who want to have a look at the details (EDIT: I used a brand new i1pro to calibrate).
If you want to try my settings (only after upgrading the firmware), here they are:
[EDIT: please do not use these settings, I and others have posted updated settings, see links above].
Contrast=0
Brightness=0
Color=0
Tint=0
Color temp (new lamp, probably not useful for most of you)
Gain R=-24, G=0, B=-54
Offset R=-1 G=-3 B=0
CMS (H,S,B)
Red -4 -23 7
Yellow 22 -44 38
Green -5 -39 44
Cyan -3 -48 39
Blue 37 -8 -4
Magenta -6 0 -3
I didn't have time to do any fine-tuning on gamma etc...
New firmware.zip 153.3935546875k . file
Manni01 is offline
post #2 of 1636 Old 04-28-2009, 08:32 AM
JeffY's Avatar
I had a quick play, colour ramps look good, no clipping going on.
JeffY is offline
post #3 of 1636 Old 04-28-2009, 08:35 AM - Thread Starter
Manni01's Avatar
Liked: 2166
Yes, clipping is fine, but did you find the same slight oversaturation for green at 75%?
Manni01 is offline
post #4 of 1636 Old 04-28-2009, 08:49 AM
Shepardos's Avatar
Quoted: 51 Post(s)
I have similar results as Manni but totaly differnt CMS settings. Please have a look on this results. It should be ok? I'm not a expert maybe I miss something?
CMS (H,S,B)
Red 9 -21 8
Yellow 0 -46 36
Green -3 -44 33
Cyan -2 -51 40
Blue 56 -2 -4
Magenta 5 -25 12
Where comes the big difference?
Shepardos is offline
post #5 of 1636 Old 04-28-2009, 08:55 AM - Thread Starter
Manni01's Avatar
Liked: 2166
CMS (H,S,B)
Red 9 -21 8
Yellow 0 -46 36
Green -3 -44 33
Cyan -2 -51 40
Blue 56 -2 -4
Magenta 5 -25 12
I have no idea. I used a brand new i1 pro to calibrate, which meter are you using?
Also could you post your data for primaries and secondaries, the second .jpg shows up blank on my PC.
Manni01 is offline
post #6 of 1636 Old 04-28-2009, 09:00 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 612
It is not just oversaturation. Green is also too bright.
100% 75%
R 1.4 1.1
G 0.1 8.8
B 1.9 1.6
Y 0.6 2.5
C 0.9 0.8
M 0.4 1.0
It all looks good, except for green. 8.8 is a very large CIE94 error. You should try calibrating at 75% and then see how 100% measures. You might get better results.
Other than green, everything else looks good. Yellow is a little high, but that is mostly a hue error, which should be easy to fix.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #7 of 1636 Old 04-28-2009, 09:09 AM
JeffY's Avatar
I've not measured it yet, just looking at test patterns.
JeffY is offline
post #8 of 1636 Old 04-28-2009, 09:17 AM
Shepardos's Avatar
Quoted: 51 Post(s)
I use a i1 LT meter but I think this should not be the big differnce!? I attached again the measures for primary and secondary. The results should be ok!?
Can somebody exlpain how to messure 75% Colors and what is the benefit?
I do the mesures on High Lamp maybe this makes also some difference?
post #9 of 1636 Old 04-28-2009, 09:17 AM - Thread Starter
Manni01's Avatar
Liked: 2166
100% 75%
R 1.4 1.1
G 0.1 8.8
B 1.9 1.6
Y 0.6 2.5
C 0.9 0.8
M 0.4 1.0
Thanks for the feedback Tom.
I did this quite quickly, so there is definitely a margin for progression!
I'll try to calibrate at 75% and see if it helps with green.
But it's already a fantastic improvement, it's great to have a working CMS!
Manni01 is offline
post #10 of 1636 Old 04-28-2009, 09:22 AM
JeffY's Avatar
CMS (H,S,B)
Red 9 -21 8
Yellow 0 -46 36
Green -3 -44 33
Cyan -2 -51 40
Blue 56 -2 -4
Magenta 5 -25 12
Your blue looks highly suspect, thats a huge change in hue and I'd expect lower saturation and higher brightness needed. The other figures look plausible.
Jeff
JeffY is offline
post #11 of 1636 Old 04-28-2009, 09:22 AM
R Harkness's Avatar
Quoted: 1927 Post(s)
Liked: 1626
Guys,
I'd like to know what real-world, perceptible, visual, subjective difference you are seeing...or expect to see...with this CMS fix.
When I asked in the older thread "What is it that's wrong with the current CMS?" I got technical explanations on the order of "you can't adjust X parameter without affecting Z parameter". Unfortunately for someone like me who has never used a CMS it's still "Greek to me." I'm interested to know the end result of the issues - how things look.
How would we expect the new CMS to improve the images?
Many thanks.
R Harkness is offline
post #12 of 1636 Old 04-28-2009, 09:26 AM
JeffY's Avatar
Guys,
When I asked in the older thread "What is it that's wrong with the current CMS?" I got technical explanations on the order of "you can't adjust X parameter without affecting Z parameter". Unfortunately for someone like me who has never used a CMS it's still "Greek to me." I'm interested to know how things look, not measure.
Many thanks.
With my settings I couldn't get high brightness/low saturation scenes to have enough saturation in them. Average scenes looked OK.
JeffY is offline
post #13 of 1636 Old 04-28-2009, 09:31 AM
Shepardos's Avatar
Quoted: 51 Post(s)
Jeff
Do you had a look on the results?
Blue
x 0.153474
y 0.062591
Y 3.705049
dE 3.8
dxy 0.004
dlu -1.8%
Should be good or do you see anything wrong?
post #14 of 1636 Old 04-28-2009, 09:35 AM
JeffY's Avatar
I didn't look at the results, it's just the settings that look odd. It could be an indication that the probe is inaccurate/faulty.
JeffY is offline
post #15 of 1636 Old 04-28-2009, 09:36 AM - Thread Starter
Manni01's Avatar
Liked: 2166
Guys,
Many thanks.
The new CMS allows you to get accurate colors without losing control over the other elements of the picture (primarily sharpness and gamma).
Until now, you could have accurate colors with THX, but no custom gamma and no advanced controls (sharpness, detail enhancement).
If you wanted to adjust the color gamut to your taste, you had to compromise on accuracy as clipping occured when some controls were used in user mode.
Now you can get the best of both worlds: dial the gamut the way you like (bang on Rec709 or to your own taste) and keep control on all the other elements of the picture.
The main visual difference if you want accurate colors will be the use of a custom gamma with THX-accurate colors. In a bat cave, many felt the 2.1 gamma of THX was too low.
So basically, the new CMS offers freedom and accuracy!
Manni01 is offline
post #16 of 1636 Old 04-28-2009, 09:44 AM
stereomandan's Avatar
This is great news for you guys! Once you are happy with a calibration with the new firmware, could one of you measure all the saturation windows (all 30 of them) using HCFR and the AVSHD disc? Then post the HCFR file? I just want to make sure the CMS is truely fixed, and that lower saturations aren't severely impacted.
Dan
stereomandan is offline
post #17 of 1636 Old 04-28-2009, 09:51 AM - Thread Starter
Manni01's Avatar
Liked: 2166
Dan
I'll do this when I try calibrating at 75% and will post results in the HCFR files.
Manni01 is offline
post #18 of 1636 Old 04-28-2009, 09:54 AM
BIGLook's Avatar
Hi,
Is this a UK issue only ?
JVC US said the US version of the RS20 has a correctly working CMS and this does not apply.
Thanks for any clarification.
-BB
BIGLook is offline
post #19 of 1636 Old 04-28-2009, 09:56 AM
Lawguy's Avatar
Originally Posted by BIGLook View Post
Hi,
-BB
Whoever told you that is wrong.
Affable Nitwit
Lawguy is offline
post #20 of 1636 Old 04-28-2009, 09:56 AM
Guys,
Many thanks.
Maybe one of the guys here can take some screen photos before and after like I did in my Epson Calibration guide (link provided below). I think I have these original photos on a disc so I could upload the originals here. Then anyone can load them onto a PS3, or a CD to view on a Blu-ray player...
http://www.avsforum.com/avs-vb/showt...1#post16166541
Dan
post #21 of 1636 Old 04-28-2009, 10:07 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
The UK is US allie, why would they tell you its only the british verson that was wrong? No real foul though.
mark haflich is offline
post #22 of 1636 Old 04-28-2009, 10:08 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
Manni, Is it possible to use a Mac to do the new FW upgrade?
millerwill is offline
post #23 of 1636 Old 04-28-2009, 10:19 AM - Thread Starter
Manni01's Avatar
Liked: 2166
Not as far as I know, the upgrade software is a PC .exe, and all the drivers are for XP/Vista.
It may work with parallel, but I wouldn't risk bricking an rs20 with an experiment like this!!!!
Manni01 is offline
post #24 of 1636 Old 04-28-2009, 10:21 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
OK, will borrow my daughter's PC.
post #25 of 1636 Old 04-28-2009, 10:22 AM - Thread Starter
Manni01's Avatar
Liked: 2166
Sounds safer!
Manni01 is offline
post #26 of 1636 Old 04-28-2009, 10:24 AM
BIGLook's Avatar
Hi,
That is my question/confusion..
I have spoken with JVC US several times on this issue... last week and today.
They insist the 'US MODEL' does not have a CMS issue and that they are 'not' working on any firmware updates at this time.
Maybe no one has complained.. and they just don't know..
The only reason I care is because I have a calibration scheduled and want to nail this issue first, for obvious reasons.
If any US users do apply the firmware with success, I would appreciate any feedback.
Thanks all !
-BB
BIGLook is offline
post #27 of 1636 Old 04-28-2009, 10:28 AM
R Harkness's Avatar
Liked: 1626
Thanks for the replies about the CMS and it's results on the picture.
Go thread go!
post #28 of 1636 Old 04-28-2009, 10:31 AM
heja's Avatar
Downloaded the file from JVC but are not able to run it? Any tips? The file seems not to have an extention (exe) that makes it possible to run it...
heja is offline
post #29 of 1636 Old 04-28-2009, 10:33 AM
Mike_WI's Avatar
Quoted: 123 Post(s)
Liked: 76
Hi,
Thanks all !
-BB
I'm also getting a calibration soon, so I think this is of general interest.
Also, is this not a JVC (US) supported FW update?
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
post #30 of 1636 Old 04-28-2009, 10:36 AM
JeffY's Avatar
rename the file to add the .exe
JeffY is offline
