sound proof projector box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-29-2009, 08:46 PM - Thread Starter
randyogrady's Avatar
Does any one know where I can get a sound proof box for my projector. I live in langley bc and want to just go buy one rather than wait for something on line.
randyogrady is offline
post #2 of 4 Old 05-29-2009, 08:54 PM
Quoted: 3254 Post(s)
Liked: 2743
Lot's of guys just make something that fits in with the rooms decor. If you search for hush boxes down in the dedicated theater building forum you will find some examples. The biggest problem is HEAT. the box will need some form of through ventilation bringing in room temp air and sending the hot air someplace.
post #3 of 4 Old 05-30-2009, 12:18 AM
Davecraze's Avatar
Quoted: 158 Post(s)
Liked: 55
http://whisperflow.smugmug.com/galle...25042792_MUpQP
i loved my old whisperflow but it was custom and took a few weeks to come in
Davecraze is offline
post #4 of 4 Old 01-17-2013, 11:44 AM
tinzo's Avatar
love it, going to build the same. only i use a termostat for the fans
tinzo is offline
