manufacturing problems with Mitsu HC7000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-15-2009, 10:39 PM - Thread Starter
smckinnon's Avatar
hi guys, first time poster. I just recently had a home theatre setup installed in my condo, with the Mitsubishi HC7000 as the centerpiece. The picture was incredible, except for a strange "blob" of neutral light at the bottom of the picture which was infuriating (it kind of looked like someone was shining a small flashlight at the bottom of the screen). I returned the projector to the AV installer which he tested and confirmed the defect. The Mits rep said that occasionally a projector will have a small defect that allows light to "leak" out of the light path and create this problem. The Mits dealer sent a new unit to my AV guy, which he tested before taking to my place, and lo and behold it had the same problem, only in a different spot on the screen. So now I'm waiting for my third HC7000 to arrive. I'm just wondering if anyone here has had this problem with another projector, or heard of the 7000 having lots of defects? Thanks for any input.
smckinnon is offline
post #2 of 4 Old 06-24-2009, 05:06 PM - Thread Starter
smckinnon's Avatar
Finally got my projector back. Apparently the problem was actually caused by a dust blob, which was there right out of the box, as well as the second one they ordered. My dealer who also has one in his HT room had the same problem about a month after he installed his. Hopefully this was just crazy bad luck and not a sign that this proj will get blobs all the time. At least until then the picture looks fantastic on my 100" da-lite HC cinemavision.
post #3 of 4 Old 10-02-2012, 06:50 PM
schumy's Avatar
hi
I got my new HC7800 a few days ago and it has this problem, is that the same as yours?
schumy is offline
post #4 of 4 Old 10-04-2012, 05:05 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
See the other Mitsu thread.
mark haflich is offline
Mitsubishi Hc7000 Lcd Digital Video Projector
